67 bool always_set_to_false,
74#define RTEMS_TEST_INITIAL_EXTENSION \
75 { NULL, NULL, NULL, NULL, NULL, NULL, NULL, rtems_test_fatal_extension, NULL }
82 RTEMS_TEST_STATE_PASS,
83 RTEMS_TEST_STATE_FAIL,
84 RTEMS_TEST_STATE_USER_INPUT,
85 RTEMS_TEST_STATE_INDETERMINATE,
86 RTEMS_TEST_STATE_BENCHMARK
89#if (TEST_STATE_EXPECTED_FAIL && TEST_STATE_USER_INPUT) || \
90 (TEST_STATE_EXPECTED_FAIL && TEST_STATE_INDETERMINATE) || \
91 (TEST_STATE_EXPECTED_FAIL && TEST_STATE_BENCHMARK) || \
92 (TEST_STATE_USER_INPUT && TEST_STATE_INDETERMINATE) || \
93 (TEST_STATE_USER_INPUT && TEST_STATE_BENCHMARK) || \
94 (TEST_STATE_INDETERMINATE && TEST_STATE_BENCHMARK)
95 #error Test states must be unique
98#if TEST_STATE_EXPECTED_FAIL
99 #define TEST_STATE RTEMS_TEST_STATE_FAIL
100#elif TEST_STATE_USER_INPUT
101 #define TEST_STATE RTEMS_TEST_STATE_USER_INPUT
102#elif TEST_STATE_INDETERMINATE
103 #define TEST_STATE RTEMS_TEST_STATE_INDETERMINATE
104#elif TEST_STATE_BENCHMARK
105 #define TEST_STATE RTEMS_TEST_STATE_BENCHMARK
107 #define TEST_STATE RTEMS_TEST_STATE_PASS
130#define RTEMS_TEST_PARALLEL_PROCESSOR_MAX 32
141 rtems_id worker_ids[RTEMS_TEST_PARALLEL_PROCESSOR_MAX];
184 size_t active_workers
200 size_t active_workers,
218 size_t active_workers
244static inline bool rtems_test_parallel_stop_job(
248 return _Atomic_Load_ulong(&ctx->stop, ATOMIC_ORDER_RELAXED) != 0;
261static inline bool rtems_test_parallel_is_master_worker(
size_t worker_index)
263 return worker_index == 0;
274static inline rtems_id rtems_test_parallel_get_task_id(
279 return ctx->worker_ids[worker_index];
#define RTEMS_NO_RETURN
Tells the compiler in a function declaration that this function does not return.
Definition: basedefs.h:386
CPU_Uint32ptr rtems_task_argument
This integer type represents task argument values.
Definition: tasks.h:100
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
Watchdog_Interval rtems_interval
This type represents clock tick intervals.
Definition: types.h:114
Internal_errors_t rtems_fatal_code
This integer type represents system termination codes.
Definition: extension.h:162
Internal_errors_Source
This type lists the possible sources from which an error can be reported.
Definition: interr.h:63
void rtems_test_gcov_dump_info(void)
Dumps the gcov information as a base64 encoded gcfn and gcda data stream using rtems_put_char().
Definition: testgcovdumpinfo.c:65
void rtems_test_busy_cpu_usage(time_t seconds, long nanoseconds)
Performs a busy loop for the specified seconds and nanoseconds based on the CPU usage of the executin...
Definition: testbusy.c:36
RTEMS_NO_RETURN void rtems_test_exit(int status)
Exit the test without calling exit() since it closes stdin, etc and pulls in stdio code.
Definition: testexit.c:43
const char rtems_test_name[]
Each test must define a test name string.
Definition: init.c:6899
RTEMS_NO_RETURN void rtems_test_run(rtems_task_argument arg, const RTEMS_TEST_STATE state)
Runs the test cases of the RTEMS Test Framework using a default configuration in the context of a tas...
Definition: testrun.c:83
void rtems_test_fatal_extension(rtems_fatal_source source, bool always_set_to_false, rtems_fatal_code code)
Fatal extension for tests.
Definition: testextension.c:43
void(* rtems_test_parallel_worker_setup)(rtems_test_parallel_context *ctx, size_t worker_index, rtems_id worker_id)
Worker task setup handler.
Definition: test-info.h:157
RTEMS_TEST_STATE
Test states.
Definition: test-info.h:81
void rtems_test_parallel(rtems_test_parallel_context *ctx, rtems_test_parallel_worker_setup worker_setup, const rtems_test_parallel_job *jobs, size_t job_count)
Runs a bunch of jobs in parallel on all processors of the system.
Definition: testparallel.c:136
int rtems_test_begin(const char *name, const RTEMS_TEST_STATE state)
Prints a begin of test message using printf().
Definition: testbeginend.c:56
int rtems_test_end(const char *name)
Prints an end of test message using printf().
Definition: testbeginend.c:93
This header file provides the interfaces of the Atomic Operations.
This header file provides the interfaces of the SMP Barriers.
SMP barrier control.
Definition: smpbarrier.h:67
Definition: inftrees.h:24
Internal context for parallel job execution.
Definition: test-info.h:137
Basic parallel job description.
Definition: test-info.h:166
rtems_interval(* init)(rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
Job initialization handler.
Definition: test-info.h:181
void * arg
Job specific argument.
Definition: test-info.h:224
void(* body)(rtems_test_parallel_context *ctx, void *arg, size_t active_workers, size_t worker_index)
Job body handler.
Definition: test-info.h:197
void(* fini)(rtems_test_parallel_context *ctx, void *arg, size_t active_workers)
Job finalization handler.
Definition: test-info.h:215
bool cascade
Job cascading flag.
Definition: test-info.h:233
