RTEMS 6.1-rc6
DelayBlock Low Layer HAL module driver. More...
#include "stm32h7xx_hal.h"
============================================================================== ##### DelayBlock peripheral features ##### ============================================================================== [..] The Delay block is used to generate an Output clock which is de-phased from the Input clock. The phase of the Output clock is programmed by FW. The Output clock is then used to clock the receive data in i.e. a SDMMC or QSPI interface. The delay is Voltage and Temperature dependent, which may require FW to do re-tuning and recenter the Output clock phase to the receive data. [..] The Delay Block features include the following: (+) Input clock frequency range 25MHz to 208MHz. (+) Up to 12 oversampling phases. ##### How to use this driver ##### ============================================================================== [..] This driver is a considered as a driver of service for external devices drivers that interfaces with the DELAY peripheral. The DelayBlock_Enable() function, enables the DelayBlock instance, configure the delay line length and configure the Output clock phase. The DelayBlock_Disable() function, disables the DelayBlock instance by setting DEN flag to 0.
