RTEMS 6.1-rc6
stm32h7xx_hal_swpmi.c File Reference
SWPMI HAL module driver. This file provides firmware functions to manage the following functionalities of the Single Wire Protocol Master Interface (SWPMI). More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and Configuration
  • Data transfers functions
  • DMA transfers management
  • Interrupts and flags management
Attention
                       ##### How to use this driver #####
    The SWPMI HAL driver can be used as follows:
   (#) Declare a SWPMI_HandleTypeDef handle structure (eg. SWPMI_HandleTypeDef hswpmi).
   (#) Initialize the SWPMI low level resources by implementing the HAL_SWPMI_MspInit() API:
       (##) Enable the SWPMIx interface clock with __HAL_RCC_SWPMIx_CLK_ENABLE().
       (##) SWPMI IO configuration:
           (+++) Enable the clock for the SWPMI GPIO.
           (+++) Configure these SWPMI pins as alternate function pull-up.
       (##) NVIC configuration if you need to use interrupt process (HAL_SWPMI_Transmit_IT()
            and HAL_SWPMI_Receive_IT() APIs):
           (+++) Configure the SWPMIx interrupt priority with HAL_NVIC_SetPriority().
           (+++) Enable the NVIC SWPMI IRQ handle with HAL_NVIC_EnableIRQ().
       (##) DMA Configuration if you need to use DMA process (HAL_SWPMI_Transmit_DMA()
            and HAL_SWPMI_Receive_DMA() APIs):
           (+++) Declare a DMA handle structure for the Tx/Rx streams.
           (+++) Enable the DMAx interface clock.
           (+++) Configure the declared DMA handle structure with the required
                 Tx/Rx parameters.
           (+++) Configure the DMA Tx/Rx streams and requests.
           (+++) Associate the initialized DMA handle to the SWPMI DMA Tx/Rx handle.
           (+++) Configure the priority and enable the NVIC for the transfer complete
                 interrupt on the DMA Tx/Rx streams.
   (#) Program the Bite Rate, Tx Buffering mode, Rx Buffering mode in the Init structure.
   (#) Enable the SWPMI peripheral by calling the HAL_SWPMI_Init() function.
   Three operation modes are available within this driver :
   *** Polling mode IO operation ***
     (+) Send an amount of data in blocking mode using HAL_SWPMI_Transmit()
     (+) Receive an amount of data in blocking mode using HAL_SWPMI_Receive()
   *** Interrupt mode IO operation ***
     (+) Send an amount of data in non-blocking mode using HAL_SWPMI_Transmit_IT()
     (+) At transmission end of transfer HAL_SWPMI_TxCpltCallback() is executed and user can
         add his own code by customization of function pointer HAL_SWPMI_TxCpltCallback()
     (+) Receive an amount of data in non-blocking mode using HAL_SWPMI_Receive_IT()
     (+) At reception end of transfer HAL_SWPMI_RxCpltCallback() is executed and user can
         add his own code by customization of function pointer HAL_SWPMI_RxCpltCallback()
     (+) In case of flag error, HAL_SWPMI_ErrorCallback() function is executed and user can
         add his own code by customization of function pointer HAL_SWPMI_ErrorCallback()
   *** DMA mode IO operation ***
     (+) Send an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Transmit_DMA()
     (+) Receive an amount of data in non-blocking mode (DMA) using HAL_SWPMI_Receive_DMA()
     (+) Stop the DMA Transfer using HAL_SWPMI_DMAStop()
   *** SWPMI HAL driver additional function list ***
     Below the list the others API available SWPMI HAL driver :
     (+) HAL_SWPMI_EnableLoopback(): Enable the loopback mode for test purpose only
     (+) HAL_SWPMI_DisableLoopback(): Disable the loopback mode
   *** SWPMI HAL driver macros list ***
     Below the list of most used macros in SWPMI HAL driver :
     (+) __HAL_SWPMI_ENABLE(): Enable the SWPMI peripheral
     (+) __HAL_SWPMI_DISABLE(): Disable the SWPMI peripheral
     (+) __HAL_SWPMI_TRANSCEIVER_ENABLE(): Enable the SWPMI peripheral transceiver
     (+) __HAL_SWPMI_TRANSCEIVER_DISABLE(): Disable the SWPMI peripheral transceiver
     (+) __HAL_SWPMI_ENABLE_IT(): Enable the specified SWPMI interrupts
     (+) __HAL_SWPMI_DISABLE_IT(): Disable the specified SWPMI interrupts
     (+) __HAL_SWPMI_GET_IT_SOURCE(): Check if the specified SWPMI interrupt source is
         enabled or disabled
     (+) __HAL_SWPMI_GET_FLAG(): Check whether the specified SWPMI flag is set or not
   *** Callback registration ***
     The compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS when set to 1
     allows the user to configure dynamically the driver callbacks.
     Use function HAL_SWPMI_RegisterCallback() to register a user callback. It allows
     to register the following callbacks:
     (+) RxCpltCallback     : SWPMI receive complete.
     (+) RxHalfCpltCallback : SWPMI receive half complete.
     (+) TxCpltCallback     : SWPMI transmit complete.
     (+) TxHalfCpltCallback : SWPMI transmit half complete.
     (+) ErrorCallback      : SWPMI error.
     (+) MspInitCallback    : SWPMI MspInit.
     (+) MspDeInitCallback  : SWPMI MspDeInit.
   This function takes as parameters the HAL peripheral handle, the callback ID
   and a pointer to the user callback function.
   Use function HAL_SWPMI_UnRegisterCallback() to reset a callback to the default
   weak (surcharged) function.
   HAL_SWPMI_UnRegisterCallback() takes as parameters the HAL peripheral handle,
   and the callback ID.
   This function allows to reset following callbacks:
   By default, after the HAL_SWPMI_Init and if the state is HAL_SWPMI_STATE_RESET
   all callbacks are reset to the corresponding legacy weak (surcharged) functions:
   examples HAL_SWPMI_RxCpltCallback(), HAL_SWPMI_ErrorCallback().
   Exception done for MspInit and MspDeInit callbacks that are respectively
   reset to the legacy weak (surcharged) functions in the HAL_SWPMI_Init
   and HAL_SWPMI_DeInit only when these callbacks are null (not registered beforehand).
   If not, MspInit or MspDeInit are not null, the HAL_SWPMI_Init and HAL_SWPMI_DeInit
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
   Callbacks can be registered/unregistered in READY state only.
   Exception done for MspInit/MspDeInit callbacks that can be registered/unregistered
   in READY or RESET state, thus registered (user) MspInit/DeInit callbacks can be used
   during the Init/DeInit.
   In that case first register the MspInit/MspDeInit user callbacks
   using HAL_SWPMI_RegisterCallback before calling HAL_SWPMI_DeInit
   or HAL_SWPMI_Init function.
   When the compilation define USE_HAL_SWPMI_REGISTER_CALLBACKS is set to 0 or
   not defined, the callback registering feature is not available
   and weak (surcharged) callbacks are used.
