RTEMS
6.1-rc6
libdl
rtl-find-file.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* COPYRIGHT (c) 2012-2013 Chris Johns <chrisj@rtems.org>
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#if !defined (_RTEMS_RTL_FIND_FILE_H_)
37
#define _RTEMS_RTL_FIND_FILE_H_
38
39
rtems.h
40
rtems/chain.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
/* __cplusplus */
45
56
bool
rtems_rtl_find_file
const
char
* name,
57
const
char
* paths,
58
const
char
** file_name,
59
size_t
* size);
60
61
#ifdef __cplusplus
62
63
#endif
/* __cplusplus */
64
65
#endif
chain.h
This header file provides the Chains API.
rtems.h
rtems_rtl_find_file
bool rtems_rtl_find_file(const char *name, const char *paths, const char **file_name, size_t *size)
Definition:
rtl-find-file.c:61
