35#if !defined (_RTEMS_RTL_ALLOCATOR_H_)
36#define _RTEMS_RTL_ALLOCATOR_H_
87#define RTEMS_RTL_ALLOC_TAGS ((size_t) (RTEMS_RTL_ALLOC_READ_EXEC + 1))
284 void** const_base,
size_t const_size,
285 void** eh_base,
size_t eh_size,
286 void** data_base,
size_t data_size,
287 void** bss_base,
size_t bss_size);
308 void** const_base,
size_t const_size,
309 void** eh_base,
size_t eh_size,
310 void** data_base,
size_t data_size,
311 void** bss_base,
size_t bss_size);
323 void** eh_base,
void** data_base,
rtems_rtl_alloc_tag rtems_rtl_alloc_bss_tag(void)
Definition: rtl-allocator.c:299
void rtems_rtl_alloc_indirect_new(rtems_rtl_alloc_tag tag, rtems_rtl_ptr *handle, size_t size)
Definition: rtl-allocator.c:225
rtems_rtl_alloc_tag rtems_rtl_alloc_text_tag(void)
Definition: rtl-allocator.c:275
void rtems_rtl_alloc_unlock(void)
Definition: rtl-allocator.c:182
void * rtems_rtl_alloc_resize(rtems_rtl_alloc_tag tag, void *address, size_t size, bool zero)
Definition: rtl-allocator.c:113
void rtems_rtl_alloc_initialise(rtems_rtl_alloc_data *data)
Definition: rtl-allocator.c:62
rtems_rtl_allocator rtems_rtl_alloc_hook(rtems_rtl_allocator handler)
Definition: rtl-allocator.c:215
void rtems_rtl_alloc_wr_enable(rtems_rtl_alloc_tag tag, void *address)
Definition: rtl-allocator.c:147
enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag
Definition: rtl-allocator.h:64
void rtems_rtl_alloc_del(rtems_rtl_alloc_tag tag, void *address)
Definition: rtl-allocator.c:99
Definition: rtl-allocator.h:87
void rtems_rtl_alloc_module_del(void **text_base, void **const_base, void **eh_base, void **data_base, void **bss_base)
Definition: rtl-allocator.c:435
Definition: rtl-allocator.h:52
@ RTEMS_RTL_ALLOC_READ
Definition: rtl-allocator.h:56
@ RTEMS_RTL_ALLOC_READ_EXEC
Definition: rtl-allocator.h:58
@ RTEMS_RTL_ALLOC_EXTERNAL
Definition: rtl-allocator.h:55
@ RTEMS_RTL_ALLOC_SYMBOL
Definition: rtl-allocator.h:54
@ RTEMS_RTL_ALLOC_READ_WRITE
Definition: rtl-allocator.h:57
@ RTEMS_RTL_ALLOC_OBJECT
Definition: rtl-allocator.h:53
void rtems_rtl_alloc_wr_disable(rtems_rtl_alloc_tag tag, void *address)
Definition: rtl-allocator.c:198
void * rtems_rtl_alloc_new(rtems_rtl_alloc_tag tag, size_t size, bool zero)
Definition: rtl-allocator.c:71
void(* rtems_rtl_allocator)(rtems_rtl_alloc_cmd cmd, rtems_rtl_alloc_tag tag, void **address, size_t size)
Definition: rtl-allocator.h:103
rtems_rtl_alloc_cmd
Definition: rtl-allocator.h:69
@ RTEMS_RTL_ALLOC_UNLOCK
Definition: rtl-allocator.h:74
@ RTEMS_RTL_ALLOC_DEL
Definition: rtl-allocator.h:71
@ RTEMS_RTL_ALLOC_NEW
Definition: rtl-allocator.h:70
@ RTEMS_RTL_ALLOC_WR_ENABLE
Definition: rtl-allocator.h:75
@ RTEMS_RTL_ALLOC_LOCK
Definition: rtl-allocator.h:73
@ RTEMS_RTL_ALLOC_WR_DISABLE
Definition: rtl-allocator.h:76
@ RTEMS_RTL_ALLOC_RESIZE
Definition: rtl-allocator.h:72
bool rtems_rtl_alloc_module_resize(void **text_base, size_t text_size, void **const_base, size_t const_size, void **eh_base, size_t eh_size, void **data_base, size_t data_size, void **bss_base, size_t bss_size)
Definition: rtl-allocator.c:375
rtems_rtl_alloc_tag rtems_rtl_alloc_data_tag(void)
Definition: rtl-allocator.c:293
rtems_rtl_alloc_tag rtems_rtl_alloc_eh_tag(void)
Definition: rtl-allocator.c:287
rtems_rtl_alloc_tag rtems_rtl_alloc_const_tag(void)
Definition: rtl-allocator.c:281
void rtems_rtl_alloc_lock(void)
Definition: rtl-allocator.c:164
bool rtems_rtl_alloc_module_new(void **text_base, size_t text_size, void **const_base, size_t const_size, void **eh_base, size_t eh_size, void **data_base, size_t data_size, void **bss_base, size_t bss_size)
Definition: rtl-allocator.c:305
void rtems_rtl_alloc_indirect_del(rtems_rtl_alloc_tag tag, rtems_rtl_ptr *handle)
Definition: rtl-allocator.c:253
RTEMS Run-Time Linker Indirect Pointer Management allows memory compaction in the allocator.
Definition: rtl-allocator.h:111
rtems_rtl_allocator allocator
Definition: rtl-allocator.h:113
Definition: rtl-indirect-ptr.h:48
This union represents a chain control block.
Definition: chain.h:96
