RTEMS 6.1-rc6
reg_sci.h
2
11/* The header file is generated by make_header.py from SCI.json */
12/* Current script's version can be found at: */
13/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15/*
16 * Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17 *
18 * Czech Technical University in Prague
19 * Zikova 1903/4
20 * 166 36 Praha 6
21 * Czech Republic
22 *
23 * All rights reserved.
24 *
25 * Redistribution and use in source and binary forms, with or without
26 * modification, are permitted provided that the following conditions are met:
27 *
28 * 1. Redistributions of source code must retain the above copyright notice, this
29 * list of conditions and the following disclaimer.
30 * 2. Redistributions in binary form must reproduce the above copyright notice,
31 * this list of conditions and the following disclaimer in the documentation
32 * and/or other materials provided with the distribution.
33 *
34 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38 * ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44 *
45 * The views and conclusions contained in the software and documentation are those
46 * of the authors and should not be interpreted as representing official policies,
47 * either expressed or implied, of the FreeBSD Project.
48*/
49#ifndef LIBBSP_ARM_TMS570_SCI
50#define LIBBSP_ARM_TMS570_SCI
51
52#include <bsp/utility.h>
53
54typedef struct{
55 uint32_t GCR0; /*SCI Global Control Register 0*/
56 uint32_t GCR1; /*SCI Global Control Register 1*/
57 uint32_t GCR2; /*SCI Global Control Register 2*/
58 uint32_t SETINT; /*SCI Set Interrupt Register*/
59 uint32_t CLEARINT; /*SCI Clear Interrupt Register*/
60 uint32_t SETINTLVL; /*SCI Set Interrupt Level Register*/
61 uint32_t CLEARINTLVL; /*SCI Clear Interrupt Level Register*/
62 uint32_t FLR; /*SCI Flags Register*/
63 uint32_t INTVECT0; /*SCI Interrupt Vector Offset 0*/
64 uint32_t INTVECT1; /*SCI Interrupt Vector Offset 1*/
65 uint32_t FORMAT; /*SCI Format Control Register*/
66 uint32_t BRS; /*Baud Rate Selection Register*/
67 uint32_t ED; /*Receiver Emulation Data Buffer*/
68 uint32_t RD; /*Receiver Data Buffer*/
69 uint32_t TD; /*Transmit Data Buffer*/
70 uint32_t PIO0; /*SCI Pin I/O Control Register 0*/
71 uint32_t PIO1; /*SCI Pin I/O Control Register 1*/
72 uint32_t PIO2; /*SCI Pin I/O Control Register 2*/
73 uint32_t PIO3; /*SCI Pin I/O Control Register 3*/
74 uint32_t PIO4; /*SCI Pin I/O Control Register 4*/
75 uint32_t PIO5; /*SCI Pin I/O Control Register 5*/
76 uint32_t PIO6; /*SCI Pin I/O Control Register 6*/
77 uint32_t PIO7; /*SCI Pin I/O Control Register 7*/
78 uint32_t PIO8; /*SCI Pin I/O Control Register 8*/
79 uint8_t reserved1 [48];
80 uint32_t IODFTCTRL; /*Input/Output Error Enable Register*/
82
83
84/*----------------------TMS570_SCI_GCR0----------------------*/
85/* field: Reserved - Read returns 0. Writes have no effect. */
86#define TMS570_SCI_GCR0_Reserved(val) BSP_FLD32(val,1, 31)
87#define TMS570_SCI_GCR0_Reserved_GET(reg) BSP_FLD32GET(reg,1, 31)
88#define TMS570_SCI_GCR0_Reserved_SET(reg,val) BSP_FLD32SET(reg, val,1, 31)
89
90/* field: RESET - This bit resets the SCI module. */
91#define TMS570_SCI_GCR0_RESET BSP_BIT32(0)
92
93
94/*----------------------TMS570_SCI_GCR1----------------------*/
95/* field: TXENA - Transmit enable. */
96#define TMS570_SCI_GCR1_TXENA BSP_BIT32(25)
97
98/* field: RXENA - Receive enable. RXENA allows or prevents the transfer of data from SCIRXSHF to SCIRD. */
99#define TMS570_SCI_GCR1_RXENA BSP_BIT32(24)
100
101/* field: CONT - Continue on suspend. */
102#define TMS570_SCI_GCR1_CONT BSP_BIT32(17)
103
104/* field: LOOP_BACK - Loopback bit. The self-checking option for the SCI can be selected with this bit. */
105#define TMS570_SCI_GCR1_LOOP_BACK BSP_BIT32(16)
106
107/* field: POWERDOWN - If the POWERDOWN bit is set while the receiver is actively receiving data and the wake-up */
108#define TMS570_SCI_GCR1_POWERDOWN BSP_BIT32(9)
109
110/* field: SLEEP - SCI sleep. In a multiprocessor configuration, this bit controls the receive sleep function. */
111#define TMS570_SCI_GCR1_SLEEP BSP_BIT32(8)
112
113/* field: SWnRST - Software reset (active low). This bit is effective in LIN and SCI modes. */
114#define TMS570_SCI_GCR1_SWnRST BSP_BIT32(7)
115
116/* field: CLOCK - CLOCK */
117#define TMS570_SCI_GCR1_CLOCK BSP_BIT32(5)
118
119/* field: STOP - SCI number of stop bits per frame. */
120#define TMS570_SCI_GCR1_STOP BSP_BIT32(4)
121
122/* field: PARITY - SCI parity odd/even selection. If the PARITY ENA bit is set, PARITY designates odd or even parity. */
123#define TMS570_SCI_GCR1_PARITY BSP_BIT32(3)
124
125/* field: PARITY_ENA - Parity enable. This bit enables or disables the parity function. */
126#define TMS570_SCI_GCR1_PARITY_ENA BSP_BIT32(2)
127
128/* field: TIMING_MODE - SCI timing mode bit. */
129#define TMS570_SCI_GCR1_TIMING_MODE BSP_BIT32(1)
130
131/* field: COMM_MODE - SCI communication mode bit. */
132#define TMS570_SCI_GCR1_COMM_MODE BSP_BIT32(0)
133
134
135/*----------------------TMS570_SCI_GCR2----------------------*/
136/* field: CC - Compare checksum. LIN mode only. */
137#define TMS570_SCI_GCR2_CC BSP_BIT32(17)
138
139/* field: SC - Send checksum byte. This bit is effective in LIN mode only. */
140#define TMS570_SCI_GCR2_SC BSP_BIT32(16)
141
142/* field: GEN_WU - Generate wakeup signal. This bit is effective in LIN mode only. */
143#define TMS570_SCI_GCR2_GEN_WU BSP_BIT32(8)
144
145/* field: POWERDOWN - Power down. This bit is effective in LIN or SCI mode. */
146#define TMS570_SCI_GCR2_POWERDOWN BSP_BIT32(0)
147
148
149/*---------------------TMS570_SCI_SETINT---------------------*/
150/* field: SET_FE_INT - */
151#define TMS570_SCI_SETINT_SET_FE_INT BSP_BIT32(26)
152
153/* field: SET_OE_INT - SET OE INT */
154#define TMS570_SCI_SETINT_SET_OE_INT BSP_BIT32(25)
155
156/* field: SET_PE_INT - Set parity interrupt. */
157#define TMS570_SCI_SETINT_SET_PE_INT BSP_BIT32(24)
158
159/* field: SET_RX_DMA_ALL - SET RX DMA ALL */
160#define TMS570_SCI_SETINT_SET_RX_DMA_ALL BSP_BIT32(18)
161
162/* field: SET_RX_DMA - SET RX DMA */
163#define TMS570_SCI_SETINT_SET_RX_DMA BSP_BIT32(17)
164
165/* field: SET_TX_DMA - Set transmit DMA. To enable DMA requests for the transmitter, this bit must be set. */
166#define TMS570_SCI_SETINT_SET_TX_DMA BSP_BIT32(16)
167
168/* field: SET_RX_INT - SET RX INT */
169#define TMS570_SCI_SETINT_SET_RX_INT BSP_BIT32(9)
170
171/* field: SET_TX_INT - Set transmitter interrupt. */
172#define TMS570_SCI_SETINT_SET_TX_INT BSP_BIT32(8)
173
174/* field: SET_WAKEUP_INT - Set wakeup interrupt. */
175#define TMS570_SCI_SETINT_SET_WAKEUP_INT BSP_BIT32(1)
176
177/* field: SET_BRKDT_INT - Set breakdetect interrupt. */
178#define TMS570_SCI_SETINT_SET_BRKDT_INT BSP_BIT32(0)
179
180
181/*--------------------TMS570_SCI_CLEARINT--------------------*/
182/* field: CLR_FE_INT - Clear framing-error interrupt. This bit disables the framing-error interrupt when set. */
183#define TMS570_SCI_CLEARINT_CLR_FE_INT BSP_BIT32(26)
184
185/* field: CLR_CE_INT - Clear overrun-error interrupt. This bit disables the SCI overrun error interrupt when set. */
186#define TMS570_SCI_CLEARINT_CLR_CE_INT BSP_BIT32(25)
187
188/* field: CLR_PE_INT - Clear parity interrupt. This bit disables the parity error interrupt when set. */
189#define TMS570_SCI_CLEARINT_CLR_PE_INT BSP_BIT32(24)
190
191/* field: CLR_RX_DMA_ALL - Clear receive DMA all. This bit clears the receive DMA request for address frames when set. */
192#define TMS570_SCI_CLEARINT_CLR_RX_DMA_ALL BSP_BIT32(18)
193
194/* field: CLR_RX_DMA - Clear receive DMA request. This bit disables the receive DMA request when set. */
195#define TMS570_SCI_CLEARINT_CLR_RX_DMA BSP_BIT32(17)
196
197/* field: CLR_TX_DMA - CLR TX DMA */
198#define TMS570_SCI_CLEARINT_CLR_TX_DMA BSP_BIT32(16)
199
200/* field: CLR_RX_INT - Clear receiver interrupt. This bit disables the receiver interrupt when set. */
201#define TMS570_SCI_CLEARINT_CLR_RX_INT BSP_BIT32(9)
202
203/* field: CLR_TX_INT - Clear transmitter interrupt. This bit disables the transmitter interrupt when set. */
204#define TMS570_SCI_CLEARINT_CLR_TX_INT BSP_BIT32(8)
205
206/* field: CLR_WAKEUP_INT - Clear wakeup interrupt. This bit disables the wakeup interrupt when set. */
207#define TMS570_SCI_CLEARINT_CLR_WAKEUP_INT BSP_BIT32(1)
208
209/* field: CLR_BRKDT_INT - Clear breakdetect interrupt. This bit disables the break-detect interrupt when set. */
210#define TMS570_SCI_CLEARINT_CLR_BRKDT_INT BSP_BIT32(0)
211
212
213/*--------------------TMS570_SCI_SETINTLVL--------------------*/
214/* field: SET_FE_INT_LVL - Set framing-error interrupt level. */
215#define TMS570_SCI_SETINTLVL_SET_FE_INT_LVL BSP_BIT32(26)
216
217/* field: SET_CE_INT_LVL - Set overrun-error interrupt level. */
218#define TMS570_SCI_SETINTLVL_SET_CE_INT_LVL BSP_BIT32(25)
219
220/* field: SET_PE_INT_LVL - Set parity error interrupt level. */
221#define TMS570_SCI_SETINTLVL_SET_PE_INT_LVL BSP_BIT32(24)
222
223/* field: SET_RX_DMA_ALL_LVL - Set receive DMA all interrupt levels. */
224#define TMS570_SCI_SETINTLVL_SET_RX_DMA_ALL_LVL BSP_BIT32(18)
225
226/* field: SET_RX_INT_LVL - Set receiver interrupt level. */
227#define TMS570_SCI_SETINTLVL_SET_RX_INT_LVL BSP_BIT32(9)
228
229/* field: SET_TX_INT_LVL - Set transmitter interrupt level. */
230#define TMS570_SCI_SETINTLVL_SET_TX_INT_LVL BSP_BIT32(8)
231
232/* field: SET_WAKEUP_INT_LVL - Set wakeup interrupt level. */
233#define TMS570_SCI_SETINTLVL_SET_WAKEUP_INT_LVL BSP_BIT32(1)
234
235/* field: SET_BRKDT_INT_LVL - SET BRKDT INT LVL */
236#define TMS570_SCI_SETINTLVL_SET_BRKDT_INT_LVL BSP_BIT32(0)
237
238
239/*-------------------TMS570_SCI_CLEARINTLVL-------------------*/
240/* field: CLR_FE_INT_LVL - Clear framing-error interrupt. */
241#define TMS570_SCI_CLEARINTLVL_CLR_FE_INT_LVL BSP_BIT32(26)
242
243/* field: CLR_CE_INT_LVL - CLR CE INT LVL */
244#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
245
246/* field: CLR_CE_INT_LVL - CLR CE INT LVL */
247#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL BSP_BIT32(25)
248
249/* field: CLR_PE_INT_LVL - */
250#define TMS570_SCI_CLEARINTLVL_CLR_PE_INT_LVL BSP_BIT32(24)
251
252/* field: CLR_RX_DMA_ALL_LVL - Clear receive DMA interrupt level. */
253#define TMS570_SCI_CLEARINTLVL_CLR_RX_DMA_ALL_LVL BSP_BIT32(18)
254
255/* field: CLR_RX_INT_LVL - Clear receiver interrupt. */
256#define TMS570_SCI_CLEARINTLVL_CLR_RX_INT_LVL BSP_BIT32(9)
257
258/* field: 8 - CLR TX INT LVL Clear transmitter interrupt. */
259#define TMS570_SCI_CLEARINTLVL_8 BSP_BIT32(8)
260
261/* field: CLR_WAKEUP_INT_LVL - Clear wakeup interrupt. */
262#define TMS570_SCI_CLEARINTLVL_CLR_WAKEUP_INT_LVL BSP_BIT32(1)
263
264/* field: CLR_BRKDT_INT_LVL - Clear breakdetect interrupt. */
265#define TMS570_SCI_CLEARINTLVL_CLR_BRKDT_INT_LVL BSP_BIT32(0)
266
267
268/*-----------------------TMS570_SCI_FLR-----------------------*/
269/* field: FE - Framing error flag. This bit is effective in LIN or SCI-compatible mode. */
270#define TMS570_SCI_FLR_FE BSP_BIT32(26)
271
272/* field: OE - Overrun error flag. */
273#define TMS570_SCI_FLR_OE BSP_BIT32(25)
274
275/* field: PE - Parity error flag. This bit is set when a parity error is detected in the received data. */
276#define TMS570_SCI_FLR_PE BSP_BIT32(24)
277
278/* field: RXWAKE - Receiver wakeup detect flag. */
279#define TMS570_SCI_FLR_RXWAKE BSP_BIT32(12)
280
281/* field: TX_EMPTY - Transmitter empty flag. */
282#define TMS570_SCI_FLR_TX_EMPTY BSP_BIT32(11)
283
284/* field: TXWAKE - Transmitter wakeup method select. */
285#define TMS570_SCI_FLR_TXWAKE BSP_BIT32(10)
286
287/* field: RXRDY - Receiver ready flag. */
288#define TMS570_SCI_FLR_RXRDY BSP_BIT32(9)
289
290/* field: TXRDY - Transmitter buffer register ready flag. */
291#define TMS570_SCI_FLR_TXRDY BSP_BIT32(8)
292
293/* field: BUSY - Bus busy flag. TThis bit indicates whether the receiver is in the process of receiving a frame. */
294#define TMS570_SCI_FLR_BUSY BSP_BIT32(3)
295
296/* field: IDLE - SCI receiver in idle state. */
297#define TMS570_SCI_FLR_IDLE BSP_BIT32(2)
298
299/* field: WAKEUP - Wakeup flag. */
300#define TMS570_SCI_FLR_WAKEUP BSP_BIT32(1)
301
302/* field: BRKDT - SCI break-detect flag. This bit is set when the SCI detects a break condition on the LINRX pin. */
303#define TMS570_SCI_FLR_BRKDT BSP_BIT32(0)
304
305
306/*--------------------TMS570_SCI_INTVECT0--------------------*/
307/* field: INVECT0 - Interrupt vector offset for INT0. This register indicates the offset for interrupt line INT0. */
308#define TMS570_SCI_INTVECT0_INVECT0(val) BSP_FLD32(val,0, 3)
309#define TMS570_SCI_INTVECT0_INVECT0_GET(reg) BSP_FLD32GET(reg,0, 3)
310#define TMS570_SCI_INTVECT0_INVECT0_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
311
312
313/*--------------------TMS570_SCI_INTVECT1--------------------*/
314/* field: INVECT1 - Interrupt vector offset for INT1. This register indicates the offset for interrupt line INT1. */
315#define TMS570_SCI_INTVECT1_INVECT1(val) BSP_FLD32(val,0, 3)
316#define TMS570_SCI_INTVECT1_INVECT1_GET(reg) BSP_FLD32GET(reg,0, 3)
317#define TMS570_SCI_INTVECT1_INVECT1_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
318
319
320/*---------------------TMS570_SCI_FORMAT---------------------*/
321/* field: CHAR - Character length control bits. These bits set the SCI character length from 1 to 8 bits. */
322#define TMS570_SCI_FORMAT_CHAR(val) BSP_FLD32(val,0, 2)
323#define TMS570_SCI_FORMAT_CHAR_GET(reg) BSP_FLD32GET(reg,0, 2)
324#define TMS570_SCI_FORMAT_CHAR_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
325
326
327/*-----------------------TMS570_SCI_BRS-----------------------*/
328/* field: BAUD - SCI 24-bit baud selection. */
329#define TMS570_SCI_BRS_BAUD(val) BSP_FLD32(val,0, 23)
330#define TMS570_SCI_BRS_BAUD_GET(reg) BSP_FLD32GET(reg,0, 23)
331#define TMS570_SCI_BRS_BAUD_SET(reg,val) BSP_FLD32SET(reg, val,0, 23)
332
333
334/*-----------------------TMS570_SCI_ED-----------------------*/
335/* field: ED - Emulator data. Reading SCIED[7:0] does not clear the RXRDY flag, unlike reading SCIRD. */
336#define TMS570_SCI_ED_ED(val) BSP_FLD32(val,0, 7)
337#define TMS570_SCI_ED_ED_GET(reg) BSP_FLD32GET(reg,0, 7)
338#define TMS570_SCI_ED_ED_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
339
340
341/*-----------------------TMS570_SCI_RD-----------------------*/
342/* field: RD - Receiver data. */
343#define TMS570_SCI_RD_RD(val) BSP_FLD32(val,0, 7)
344#define TMS570_SCI_RD_RD_GET(reg) BSP_FLD32GET(reg,0, 7)
345#define TMS570_SCI_RD_RD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
346
347
348/*-----------------------TMS570_SCI_TD-----------------------*/
349/* field: TD - Transmit data. Data to be transmitted is written to the SCITD register. */
350#define TMS570_SCI_TD_TD(val) BSP_FLD32(val,0, 7)
351#define TMS570_SCI_TD_TD_GET(reg) BSP_FLD32GET(reg,0, 7)
352#define TMS570_SCI_TD_TD_SET(reg,val) BSP_FLD32SET(reg, val,0, 7)
353
354
355/*----------------------TMS570_SCI_PIO0----------------------*/
356/* field: TX_FUNC - Transfer function. This bit defines the function of pin SCITX. */
357#define TMS570_SCI_PIO0_TX_FUNC BSP_BIT32(2)
358
359/* field: RX_FUNC - Receive function.This bit defines the function of pin SCIRX. */
360#define TMS570_SCI_PIO0_RX_FUNC BSP_BIT32(1)
361
362
363/*----------------------TMS570_SCI_PIO1----------------------*/
364/* field: TX_DIR - Transmit pin direction. */
365#define TMS570_SCI_PIO1_TX_DIR BSP_BIT32(2)
366
367/* field: RX_DIR - Receive pin direction. */
368#define TMS570_SCI_PIO1_RX_DIR BSP_BIT32(1)
369
370
371/*----------------------TMS570_SCI_PIO2----------------------*/
372/* field: TX_IN - Transmit pin in. This bit contains the current value on the SCITX pin. */
373#define TMS570_SCI_PIO2_TX_IN BSP_BIT32(2)
374
375/* field: RX_IN - Receive pin in. This bit contains the current value on the SCIRX pin. */
376#define TMS570_SCI_PIO2_RX_IN BSP_BIT32(1)
377
378
379/*----------------------TMS570_SCI_PIO3----------------------*/
380/* field: TX_OUT - Transmit pin out. */
381#define TMS570_SCI_PIO3_TX_OUT BSP_BIT32(2)
382
383/* field: RX_OUT - Receive pin out. */
384#define TMS570_SCI_PIO3_RX_OUT BSP_BIT32(1)
385
386
387/*----------------------TMS570_SCI_PIO4----------------------*/
388/* field: TX_SET - Transmit pin set. */
389#define TMS570_SCI_PIO4_TX_SET BSP_BIT32(2)
390
391/* field: RX_SET - Receive pin set. */
392#define TMS570_SCI_PIO4_RX_SET BSP_BIT32(1)
393
394
395/*----------------------TMS570_SCI_PIO5----------------------*/
396/* field: TX_CLR - Transmit pin clear. */
397#define TMS570_SCI_PIO5_TX_CLR BSP_BIT32(2)
398
399/* field: RX_CLR - Receive pin clear. */
400#define TMS570_SCI_PIO5_RX_CLR BSP_BIT32(1)
401
402
403/*----------------------TMS570_SCI_PIO6----------------------*/
404/* field: TX_PDR - Transmit pin open drain enable. */
405#define TMS570_SCI_PIO6_TX_PDR BSP_BIT32(2)
406
407/* field: RX_PDR - Receive pin open drain enable. */
408#define TMS570_SCI_PIO6_RX_PDR BSP_BIT32(1)
409
410
411/*----------------------TMS570_SCI_PIO7----------------------*/
412/* field: TX_PD - Transmit pin pull control disable. This bit disables pull control capability on the input pin SCITX. */
413#define TMS570_SCI_PIO7_TX_PD BSP_BIT32(2)
414
415/* field: RX_PD - Receive pin pull control disable. This bit disables pull control capability on the input pin SCIRX. */
416#define TMS570_SCI_PIO7_RX_PD BSP_BIT32(1)
417
418
419/*----------------------TMS570_SCI_PIO8----------------------*/
420/* field: TX_PSL - TX pin pull select. This bit selects pull type in the input pin SCITX. */
421#define TMS570_SCI_PIO8_TX_PSL BSP_BIT32(2)
422
423/* field: RX_PSL - RX pin pull select. This bit selects pull type in the input pin SCIRX. */
424#define TMS570_SCI_PIO8_RX_PSL BSP_BIT32(1)
425
426
427/*--------------------TMS570_SCI_IODFTCTRL--------------------*/
428/* field: FEN - Frame error enable. This bit is used to create a frame error. */
429#define TMS570_SCI_IODFTCTRL_FEN BSP_BIT32(26)
430
431/* field: PEN - Parity error enable. This bit is used to create a parity error. */
432#define TMS570_SCI_IODFTCTRL_PEN BSP_BIT32(25)
433
434/* field: BRKD_TENA - Break detect error enable. This bit is used to create a BRKDT error. */
435#define TMS570_SCI_IODFTCTRL_BRKD_TENA BSP_BIT32(24)
436
437/* field: PIN_SAMPLE_MASK - Pin sample mask. */
438#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK(val) BSP_FLD32(val,19, 20)
439#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg) BSP_FLD32GET(reg,19, 20)
440#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg,val) BSP_FLD32SET(reg, val,19, 20)
441
442/* field: TX_SHIFT - Transmit shift. */
443#define TMS570_SCI_IODFTCTRL_TX_SHIFT(val) BSP_FLD32(val,16, 18)
444#define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET(reg) BSP_FLD32GET(reg,16, 18)
445#define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
446
447/* field: IODFTENA - IODFT enable key. Write access permitted in Privilege mode only. */
448#define TMS570_SCI_IODFTCTRL_IODFTENA(val) BSP_FLD32(val,8, 11)
449#define TMS570_SCI_IODFTCTRL_IODFTENA_GET(reg) BSP_FLD32GET(reg,8, 11)
450#define TMS570_SCI_IODFTCTRL_IODFTENA_SET(reg,val) BSP_FLD32SET(reg, val,8, 11)
451
452/* field: LPBENA - Module loopback enable. Write access permitted in Privilege mode only. */
453#define TMS570_SCI_IODFTCTRL_LPBENA BSP_BIT32(1)
454
455/* field: RXPENA - Module analog loopback through receive pin enable. */
456#define TMS570_SCI_IODFTCTRL_RXPENA BSP_BIT32(0)
457
458
459
460#endif /* LIBBSP_ARM_TMS570_SCI */
This header file provides utility macros for BSPs.
Definition: reg_sci.h:54
