This header file provides the interfaces of the Processor Mask.
More...
#include <rtems/score/cpu.h>
#include <sys/_bitset.h>
#define | __BIT_AND2 BIT_AND2 |
#define | __BIT_CLR BIT_CLR |
#define | __BIT_CMP BIT_CMP |
#define | __BIT_COPY BIT_COPY |
#define | __BIT_COUNT BIT_COUNT |
#define | __BITSET_DEFINE BITSET_DEFINE |
#define | __BIT_EMPTY BIT_EMPTY |
#define | __BIT_FILL BIT_FILL |
#define | __BIT_FLS BIT_FLS |
#define | __BIT_ISSET BIT_ISSET |
#define | __BIT_OR2 BIT_OR2 |
#define | __BIT_OVERLAP BIT_OVERLAP |
#define | __BIT_SET BIT_SET |
#define | __BIT_SETOF BIT_SETOF |
#define | __BIT_SUBSET BIT_SUBSET |
#define | __BIT_XOR2 BIT_XOR2 |
#define | __BIT_ZERO BIT_ZERO |
typedef | __BITSET_DEFINE (Processor_mask, CPU_MAXIMUM_PROCESSORS) Processor_mask |
| A bit map which is large enough to provide one bit for each processor in the system.
