RTEMS 6.1-rc6
MCF5206eLITE
Copyright (C) 2000,2001 OKTET Ltd., St.-Petersburg, Russia Author: Victor V. Vengerov vvv@o.nosp@m.ktet.nosp@m..ru
The license and distribution terms for this file may be found in the file LICENSE in this distribution or at http://www.rtems.org/license/LICENSE.
This board support package works with MCF5206eLITE evaluation board with Motorola Coldfire MCF5206e CPU.
Many thanks to Balanced Audio Technology (http://www.balanced.com), company which donates MCF5206eLITE evaluation board, P&E Coldfire BDM interface and provides support for development of this BSP and generic MCF5206 CPU code.
Decisions made at compile time include:
Decisions to be made a link-edit time are:
  • The size of memory allocator heap. By default, all available memory allocated for the heap. To specify amount of memory available for heap: LDFLAGS += -Wl,–defsym -Wl,HeapSize=xxx
  • The frequency of system clock oscillator. By default, this frequency is 54MHz. To select other clock frequency for your application, put line like this in application Makefile: LDFLAGS += -qclock=40000000
  • Select between RAM or ROM images. By default, RAM image generated which may be loaded starting from address 0x30000000 to the RAM. To prepare image intended to be stored in ROM, put the following line to the application Makefile: LDFLAGS += -qflash
    You may select other memory configuration providing your own linker script.
BSP NAME: mcf5206elite
BOARD: MCF5206eLITE Evaluation Board
BUS: none
CPU FAMILY: Motorola ColdFire
COPROCESSORS: none
MODE: not applicable
DEBUG MONITOR: none (Hardware provides BDM)
PERIPHERALS
TIMERS: PIT, Watchdog(disabled)
RESOLUTION: one microsecond
SERIAL PORTS: 2 UART
REAL-TIME CLOCK: DS1307
NVRAM: DS1307
DMA: 2 general purpose
VIDEO: none
SCSI: none
NETWORKING: none
I2C BUS: MCF5206e MBUS module
DRIVER INFORMATION
CLOCK DRIVER: Programmable Interval Timer
IOSUPP DRIVER: UART 1
SHMSUPP: none
TIMER DRIVER: yes
I2C DRIVER: yes
STDIO
PORT: UART 1
ELECTRICAL: EIA-232
BAUD: 19200
BITS PER CHARACTER: 8
PARITY: None
STOP BITS: 1
Board description
clock rate: 54 MHz default (other oscillator can be installed) bus width: 16-bit PROM, 32-bit external SRAM ROM: Flash memory device AM29LV800BB, 1 MByte, 3 wait states, chip select 0 RAM: Static RAM 2xMCM69F737TQ, 1 MByte, 1 wait state, chip select 2
Host System
RedHat 6.2 (Linux 2.2.14), RedHat 7.0 (Linux 2.2.17)
Verification
Single processor tests: passed Multi-processort tests: not applicable Timing tests: passed
