RTEMS
6.1-rc6
include
ioimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* COPYRIGHT (c) 1989-2008.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_IOIMPL_H
39
#define _RTEMS_IOIMPL_H
40
41
rtems/io.h
42
rtems/score/isrlock.h
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
58
extern
const
size_t
_IO_Number_of_drivers;
59
60
extern
rtems_driver_address_table
_IO_Driver_address_table[];
61
62
extern
bool
_IO_All_drivers_initialized;
63
69
void
_IO_Initialize_all_drivers
void
70
71
#if ISR_LOCK_NEEDS_OBJECT
72
extern
ISR_lock_Control _IO_Driver_registration_lock;
73
#endif
74
75
static
inline
void
_IO_Driver_registration_acquire(
76
ISR_lock_Context
*lock_context
77
78
79
_ISR_lock_ISR_disable_and_acquire
80
&_IO_Driver_registration_lock,
81
lock_context
82
83
84
85
static
inline
void
_IO_Driver_registration_release(
86
ISR_lock_Context
*lock_context
87
88
89
_ISR_lock_Release_and_ISR_enable
90
91
lock_context
92
93
94
97
#ifdef __cplusplus
98
99
#endif
/* __cplusplus */
100
101
#endif
/* _RTEMS_IOIMPL_H */
io.h
This header file defines the IO Manager API.
void _IO_Initialize_all_drivers(void)
Initialization of all device drivers.
Definition:
io.c:47
#define _ISR_lock_Release_and_ISR_enable(_lock, _context)
Releases an ISR lock.
Definition:
isrlock.h:229
#define _ISR_lock_ISR_disable_and_acquire(_lock, _context)
Acquires an ISR lock.
Definition:
isrlock.h:204
isrlock.h
This header file provides the interfaces of the ISR Locks.
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:94
This structure contains the device driver entries.
Definition:
io.h:140
