RTEMS
6.1-rc6
bsps
arm
atsam
include
bsp
iocopy.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2018 embedded brains GmbH & Co. KG
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef ATSAM_IOCOPY_H
29
#define ATSAM_IOCOPY_H
30
31
rtems.h
32
#include <stdint.h>
33
34
#ifdef __cplusplus
35
extern
"C"
36
#endif
/* __cplusplus */
37
38
39
* Note: This functions are for copying from or to memory that is marked as
40
* Peripheral memory. In this regions a misaligned access is not allowed.
41
* Therefore memcopy would not work in all cases.
42
43
void
atsam_copy_to_io(
void
*dst,
const
void
*src,
size_t
n);
44
void
atsam_copy_from_io(
void
*dst,
const
void
*src,
size_t
n);
45
46
#ifdef __cplusplus
47
48
#endif
/* __cplusplus */
49
50
#endif
/* ATSAM_IOCOPY_H */
rtems.h
