RTEMS 6.1-rc6
gti2creg.h
1/* $NetBSD: gti2creg.h,v 1.2 2005/02/27 00:27:21 perry Exp $ */
2
3/*
4 * Copyright (c) 2005 Brocade Communcations, inc.
5 * All rights reserved.
6 *
7 * Written by Matt Thomas for Brocade Communcations, Inc.
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 * 3. The name of Brocade Communications, Inc. may not be used to endorse
18 * or promote products derived from this software without specific prior
19 * written permission.
20 *
21 * THIS SOFTWARE IS PROVIDED BY BROCADE COMMUNICATIONS, INC. ``AS IS'' AND
22 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL EITHER BROCADE COMMUNICATIONS, INC. BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
31 * OF THE POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _DEV_MARVELL_GTI2CREG_H_
35#define _DEV_MARVELL_GTI2CREG_H_
36
37#define I2C_REG_SlaveAddr 0xc000
38#define I2C_REG_ExtSlaveAddr 0xc010
39#define I2C_REG_Data 0xc004
40#define I2C_REG_Control 0xc008
41#define I2C_REG_Status 0xc00c
42#define I2C_REG_BaudRate 0xc00c
43#define I2C_REG_SoftReset 0xc01c
44
45#define I2C_SlaveAddr_GCE 0x0001 /* Act as Slave */
46#define I2C_SlaveAddr_SAddr 0x7E
47
48#define I2C_Control_ACK 0x04
49#define I2C_Control_IFlg 0x08
50#define I2C_Control_Stop 0x10
51#define I2C_Control_Start 0x20
52#define I2C_Control_TWSIEn 0x40
53#define I2C_Control_IntEn 0x80
54
55/*
56 * F(I2C) = F(Tclk) / ( 10 * (M + 1) * (2^(N+1)))
57 * For Tclk = 100MHz, M = 4, N = 4: F = 62.5KHz
58 * For Tclk = 100MHz, M = 13, N = 3: F = 96.2KHz
59 */
60#define I2C_BaudRate(M, N) (((M) << 3) | (N))
61#define I2C_BaudRate_62_5K I2C_BaudRate(4, 4)
62#define I2C_BaudRate_96_2K I2C_BaudRate(13, 3)
63
64#define I2C_Status_BusError 0x00 /* Bus error */
65#define I2C_Status_Started 0x08 /* Start condition xmitted */
66#define I2C_Status_ReStarted 0x10 /* Repeated start condition xmitted */
67#define I2C_Status_AddrWriteAck 0x18 /* Adr + wr bit xmtd, ack rcvd */
68#define I2C_Status_AddrWriteNoAck 0x20 /* Adr + wr bit xmtd, NO ack rcvd */
69#define I2C_Status_MasterWriteAck 0x28 /* Master xmtd data byte, ack rcvd */
70#define I2C_Status_MasterWriteNoAck 0x30 /* Master xmtd data byte, NO ack rcvd*/
71#define I2C_Status_MasterLostArb 0x38 /* Master lost arbitration during
72 address or data transfer */
73#define I2C_Status_AddrReadAck 0x40 /* Adr + rd bit xmtd, ack rcvd */
74#define I2C_Status_AddrReadNoAck 0x48 /* Adr + rd bit xmtd, NO ack rcvd */
75#define I2C_Status_MasterReadAck 0x50 /* Master rcvd data bye, ack rcvd */
76#define I2C_Status_MasterReadNoAck 0x58 /* Master rcvd data bye, NO ack rcvd */
77#define I2C_Status_2ndAddrWriteAck 0xd0 /* 2nd adr + wr bit xmid, ack rcvd */
78#define I2C_Status_2ndAddrWriteNoAck 0xd8 /* 2nd adr + wr bit xmid, NO ack rcvd */
79#define I2C_Status_2ndAddrReadAck 0xe0 /* 2nd adr + rd bit xmid, ack rcvd */
80#define I2C_Status_2ndAddrReadNoAck 0xe8 /* 2nd adr + rd bit xmtd, NO ack rcvd */
81#define I2C_Status_Idle 0xf8 /* Idle */
82
83#endif /* _DEV_MARVELL_GTI2CREG_H_ */
