RTEMS 6.1-rc6
This group contains the AHBTRACE interfaces. More...
Modules | |
Trace buffer break address registers (TBBA) | |
This group contains register bit definitions. | |
Trace buffer break mask registers (TBBM) | |
Trace buffer control register (CTRL) | |
Trace buffer index register (INDEX) | |
Trace buffer master/slave filter register (MSFILT) | |
Trace buffer time tag register (TIMETAG) | |
Files | |
file | ahbtrace-regs.h |
This header file defines the AHBTRACE register block interface. | |
struct | ahbtrace |
This structure defines the AHBTRACE register block memory map. More... | |
Typedefs | |
typedef struct ahbtrace | ahbtrace |
This structure defines the AHBTRACE register block memory map. | |
