RTEMS 6.1-rc6
Modules | Files | Data Structures | Typedefs
GR740 I/0 and PLL Configuration
This group contains the GR740 I/0 and PLL Configuration interfaces. More...
 Alternative function enable register (ALTFUNC)
 This group contains register bit definitions.
 Configuration lockdown register (LOCKDOWN)
 Drive strength configuration register 1 (DRVSTR1)
 Drive strength configuration register 2 (DRVSTR2)
 FTMCTRL function enable register (FTMFUNC)
 LVDS and memory clock pad enable register (LVDSMCLK)
 PLL current configuration register (PLLCURCFG)
 PLL new configuration register (PLLNEWCFG)
 PLL reconfigure command register (PLLRECFG)
file  gr740-iopll-regs.h
 This header file defines the GR740 I/O and PLL configuration register block interface.
struct  gr740_iopll
 This structure defines the GR740 I/0 and PLL Configuration register block memory map. More...
typedef struct gr740_iopll gr740_iopll
