Tests the BSP-specific fatal extension shutdown procedure.
More...
| RTEMS_SYSINIT_ITEM (InitBspValFatalSmpShutdown, RTEMS_SYSINIT_DEVICE_DRIVERS, RTEMS_SYSINIT_ORDER_MIDDLE) |
void * | __real__CPU_Thread_Idle_body (void *arg) |
void * | __wrap__CPU_Thread_Idle_body (void *arg) |
| T_TEST_CASE (BspValFatalSmpShutdown) |
This test case performs the following actions:
- Check the effects of the BSP-specific fatal extension.
- Wait until the second processor is idle.
- Check that the RTEMS_FATAL_SOURCE_SMP with SMP_FATAL_SHUTDOWN_RESPONSE fatal error occurred exactly once.
- Check that the RTEMS_FATAL_SOURCE_SMP with SMP_FATAL_SHUTDOWN_RESPONSE fatal error occurred on the second processor.
