63#define AFEC_MR_SETTLING_Pos 20
64#define AFEC_MR_SETTLING_Msk (0x3u << AFEC_MR_SETTLING_Pos)
66#define AFEC_MR_SETTLING_AST3 (0x0u << 20)
68#define AFEC_MR_SETTLING_AST5 (0x1u << 20)
70#define AFEC_MR_SETTLING_AST9 (0x2u << 20)
72#define AFEC_MR_SETTLING_AST17 (0x3u << 20)
76#define AFEC_EMR_STM_Pos 25
77#define AFEC_EMR_STM_Msk (0x1u << AFEC_EMR_STM_Pos)
79#define AFEC_EMR_STM_MULTI_TRIG (0x0u << 25)
82#define AFEC_EMR_STM_SINGLE_TRIG (0x1u << 25)
87#define AFEC_EMR_TAG_Pos 24
88#define AFEC_EMR_TAG_Msk (0x1u << AFEC_EMR_TAG_Pos)
90#define AFEC_EMR_TAG_CHNB_ZERO (0x0u << 24)
93#define AFEC_EMR_TAG_APPENDS (0x1u << 24)
98#define AFEC_EMR_CMPALL_Pos 9
99#define AFEC_EMR_CMPALL_Msk (0x1u << AFEC_EMR_TAG_Pos)
101#define AFEC_EMR_CMPALL_ONE_CHANNEL_COMP (0x0u << 9)
104#define AFEC_EMR_CMPALL_ALL_CHANNELS_COMP (0x1u << 9)
107#define AFEC_ACR_PGA0_ON (0x1u << 2)
108#define AFEC_ACR_PGA1_ON (0x1u << 3)
118#define AFEC_GetModeReg(pAFEC) ((pAFEC)->AFEC_MR)
119#define AFEC_SetModeReg(pAFEC, mode) ((pAFEC)->AFEC_MR = mode)
121#define AFEC_GetExtModeReg(pAFEC) ((pAFEC)->AFEC_EMR)
122#define AFEC_SetExtModeReg(pAFEC, mode) ((pAFEC)->AFEC_EMR = mode)
124#define AFEC_StartConversion(pAFEC) ((pAFEC)->AFEC_CR = AFEC_CR_START)
126#define AFEC_EnableChannel(pAFEC, dwChannel) {\
127 (pAFEC)->AFEC_CHER = (1 << (dwChannel));\
130#define AFEC_DisableChannel(pAFEC, dwChannel) {\
131 (pAFEC)->AFEC_CHDR = (1 << (dwChannel));\
134#define AFEC_EnableIt(pAFEC, dwMode) {\
135 (pAFEC)->AFEC_IER = (dwMode);\
138#define AFEC_DisableIt(pAFEC, dwMode) {\
139 (pAFEC)->AFEC_IDR = (dwMode);\
142#define AFEC_SetChannelGain(pAFEC,dwMode) {\
143 (pAFEC)->AFEC_CGR = dwMode;\
146#define AFEC_EnableDataReadyIt(pAFEC) ((pAFEC)->AFEC_IER = AFEC_IER_DRDY)
148#define AFEC_GetStatus(pAFEC) ((pAFEC)->AFEC_ISR)
150#define AFEC_GetCompareMode(pAFEC) (((pAFEC)->AFEC_EMR)& (AFEC_EMR_CMPMODE_Msk))
152#define AFEC_GetChannelStatus(pAFEC) ((pAFEC)->AFEC_CHSR)
154#define AFEC_GetInterruptMaskStatus(pAFEC) ((pAFEC)->AFEC_IMR)
156#define AFEC_GetLastConvertedData(pAFEC) ((pAFEC)->AFEC_LCDR)
165 uint32_t dwSettling);
178extern uint8_t AFEC_CheckConfiguration(
Afec *pAFEC, uint32_t dwMcK);
void AFEC_SetFastWakeup(Afec *pAFEC, uint8_t bEnDis)
Enable/Disable fast wake up.
Definition: afec.c:197
void AFEC_SetAnalogControl(Afec *pAFE, uint32_t control)
Set analog offset to be used for channel CSEL.
Definition: afec.c:453
uint32_t AFEC_SetClock(Afec *pAFEC, uint32_t dwPres, uint32_t dwMck)
Set AFE clock.
Definition: afec.c:116
void AFEC_SetTagEnable(Afec *pAFEC, uint8_t bEnDis)
Set "TAG" mode, show channel number in last data or not.
Definition: afec.c:290
void AFEC_SetSequence(Afec *pAFEC, uint32_t dwSEQ1, uint32_t dwSEQ2)
Set channel sequence.
Definition: afec.c:231
void AFEC_SetComparisonWindow(Afec *pAFEC, uint32_t dwHi_Lo)
Set comparison window.
Definition: afec.c:334
void AFEC_SetTiming(Afec *pAFEC, uint32_t dwStartup, uint32_t dwTracking, uint32_t dwSettling)
Set AFE timing.
Definition: afec.c:141
void AFEC_SetCompareChannel(Afec *pAFEC, uint32_t dwChannel)
Set compare channel.
Definition: afec.c:304
void AFEC_SetTrackingTime(Afec *pAFEC, uint32_t dwNs)
Definition: afec.c:408
uint32_t AFEC_GetConvertedData(Afec *pAFEC, uint32_t dwChannel)
Return the Channel Converted Data.
Definition: afec.c:345
void AFEC_SetSleepMode(Afec *pAFEC, uint8_t bEnDis)
Enable/Disable sleep mode.
Definition: afec.c:183
void AFEC_Initialize(Afec *pAFEC, uint32_t dwId)
Initialize the AFE controller.
Definition: afec.c:94
void AFEC_SetAnalogOffset(Afec *pAFE, uint32_t dwChannel, uint32_t aoffset)
Definition: afec.c:440
void AFEC_SetSequenceByList(Afec *pAFEC, uint8_t ucChList[], uint8_t ucNumCh)
Set channel sequence by given channel list.
Definition: afec.c:244
void AFEC_SetCompareMode(Afec *pAFEC, uint32_t dwMode)
Set compare mode.
Definition: afec.c:322
void AFEC_SetSequenceMode(Afec *pAFEC, uint8_t bEnDis)
Enable/Disable sequence mode.
Definition: afec.c:211
void AFEC_SetAnalogChange(Afec *pAFE, uint8_t bEnDis)
Set analog change. IF enabled, it allows different analog settings for each channel,...
Definition: afec.c:276
void AFEC_SetStartupTime(Afec *pAFEC, uint32_t dwUs)
Definition: afec.c:361
void AFEC_SetTrigger(Afec *pAFEC, uint32_t dwTrgSel)
Set AFE trigger.
Definition: afec.c:166
This header file provides the interfaces of the Assert Handler.
Afec hardware registers.
Definition: component_afec.h:41
Definition: intercom.c:87
