RTEMS 6.1-rc6
acrtems.h
2
3/*
4 * Copyright (C) 2024 Matheus Pecoraro
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef __ACRTEMS_H__
29#define __ACRTEMS_H__
30
31#include <stdint.h>
32
33#define ACPI_MACHINE_WIDTH 64
34
35#define COMPILER_DEPENDENT_INT64 int64_t
36#define COMPILER_DEPENDENT_UINT64 uint64_t
37
38#define ACPI_UINTPTR_T uintptr_t
39
40#define ACPI_TO_INTEGER(p) ((uintptr_t)(p))
41#define ACPI_OFFSET(d, f) __offsetof(d, f)
42
43#define ACPI_USE_DO_WHILE_0
44#define ACPI_USE_LOCAL_CACHE
45#define ACPI_USE_NATIVE_DIVIDE
46#define ACPI_USE_NATIVE_MATH64
47#define ACPI_USE_SYSTEM_CLIBRARY
48#define ACPI_USE_STANDARD_HEADERS
49
50#endif /* __ACRTEMS_H__ */
