152#ifndef __ACDISASM_H__
153#define __ACDISASM_H__
161#define BLOCK_COMMA_LIST 4
162#define ACPI_DEFAULT_RESNAME *(UINT32 *) "__RD"
168#define ACPI_RAW_TABLE_DATA_HEADER "Raw Table Data"
182#define DT_LENGTH 0x01
184#define DT_NON_ZERO 0x04
185#define DT_OPTIONAL 0x08
186#define DT_DESCRIBES_OPTIONAL 0x10
251 ACPI_DMT_DEVICE_PATH,
283 ACPI_DMT_IVRS_UNTERMINATED_STRING,
286 ACPI_DMT_MPAM_LOCATOR,
291 ACPI_DMT_PMTT_VENDOR,
301 ACPI_DMT_WPBT_UNICODE,
311void (*ACPI_DMTABLE_HANDLER) (
315ACPI_STATUS (*ACPI_CMTABLE_HANDLER) (
322 ACPI_DMTABLE_HANDLER TableHandler;
323 ACPI_CMTABLE_HANDLER CmTableHandler;
324 const unsigned char *Template;
347#ifndef ASL_WALK_CALLBACK_DEFINED
349ACPI_STATUS (*ASL_WALK_CALLBACK) (
353#define ASL_WALK_CALLBACK_DEFINED
357void (*ACPI_RESOURCE_HANDLER) (
372extern const char *AcpiGbl_WordDecode[];
373extern const char *AcpiGbl_IrqDecode[];
374extern const char *AcpiGbl_LockRule[];
375extern const char *AcpiGbl_AccessTypes[];
376extern const char *AcpiGbl_UpdateRules[];
377extern const char *AcpiGbl_MatchOps[];
726extern const AH_TABLE AcpiGbl_SupportedTables[];
729AcpiDmGenerateChecksum (
732 UINT8 OriginalChecksum);
747 UINT32 SubtableLength,
772 UINT32 AbsoluteOffset,
1004AcpiDmWalkParseTree (
1006 ASL_WALK_CALLBACK DescendingCallback,
1007 ASL_WALK_CALLBACK AscendingCallback,
1015AcpiDmDisassembleOneOp (
1029AcpiDmDisplayTargetPathname (
1033AcpiDmNotifyDescription (
1037AcpiDmPredefinedDescription (
1041AcpiDmFieldPredefinedDescription (
1069AcpiPsDisplayObjectPathname (
1082AcpiDmDisasmByteList (
1093AcpiDmCheckForHardwareId (
1097AcpiDmDecompressEisaId (
1105AcpiDmIsUnicodeBuffer (
1109AcpiDmIsStringBuffer (
1121AcpiDmParseDeferredOps (
1129AcpiDmAddToExternalFileList (
1133AcpiDmClearExternalFileList (
1137AcpiDmAddOpToExternalList (
1145AcpiDmCreateSubobjectForExternal (
1151AcpiDmAddNodeToExternalList (
1158AcpiDmAddExternalListToNamespace (
1162AcpiDmAddOneExternalToNamespace (
1168AcpiDmGetUnresolvedExternalMethodCount (
1172AcpiDmClearExternalList (
1176AcpiDmEmitExternals (
1185AcpiDmUnresolvedWarning (
1189AcpiDmGetExternalsFromFile (
1193AcpiDmMarkExternalConflict (
1206AcpiDmDumpInteger16 (
1211AcpiDmDumpInteger32 (
1216AcpiDmDumpInteger64 (
1221AcpiDmResourceTemplate (
1228AcpiDmIsResourceTemplate (
1237AcpiDmDescriptorName (
1245AcpiDmWordDescriptor (
1252AcpiDmDwordDescriptor (
1259AcpiDmExtendedDescriptor (
1266AcpiDmQwordDescriptor (
1273AcpiDmMemory24Descriptor (
1280AcpiDmMemory32Descriptor (
1287AcpiDmFixedMemory32Descriptor (
1294AcpiDmGenericRegisterDescriptor (
1301AcpiDmInterruptDescriptor (
1308AcpiDmVendorLargeDescriptor (
1315AcpiDmGpioDescriptor (
1322AcpiDmPinFunctionDescriptor (
1329AcpiDmPinConfigDescriptor (
1336AcpiDmPinGroupDescriptor (
1343AcpiDmPinGroupFunctionDescriptor (
1350AcpiDmPinGroupConfigDescriptor (
1357AcpiDmSerialBusDescriptor (
1371AcpiDmClockInputDescriptor (
1381AcpiDmIrqDescriptor (
1388AcpiDmDmaDescriptor (
1395AcpiDmFixedDmaDescriptor (
1409AcpiDmFixedIoDescriptor (
1416AcpiDmStartDependentDescriptor (
1423AcpiDmEndDependentDescriptor (
1430AcpiDmVendorSmallDescriptor (
1441AcpiDmDecodeAttribute (
1449AcpiDmCommaIfListMember (
1453AcpiDmCommaIfFieldMember (
1461AcpiDmFindResources (
1465AcpiDmCheckResourceReference (
1474AcpiDmCheckForSymbolicOpcode (
1479AcpiDmCloseOperator (
1487AcpiDmProcessSwitch (
1498AdDisassemblerHeader (
1502#define ACPI_IS_AML_TABLE 0
1503#define ACPI_IS_DATA_TABLE 1
1514 char **OutFilename);
1523 ACPI_OWNER_ID *OwnerId,
1533AdDisplayStatistics (
Test context for spec:/rtems/barrier/req/create test case.
Definition: tc-barrier-create.c:144
Definition: acdisasm.h:319
Definition: acdisasm.h:172
Definition: aclocal.h:294
Definition: acdisasm.h:330
Definition: acdisasm.h:364
Definition: acstruct.h:182
Definition: aclocal.h:1657
Definition: aclocal.h:1194
Definition: amlresrc.h:802
