RTEMS 6.1-rc5
stm32h7xx_hal_usart.c File Reference
USART HAL module driver. This file provides firmware functions to manage the following functionalities of the Universal Synchronous/Asynchronous Receiver Transmitter Peripheral (USART). More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Initialization and de-initialization functions
  • IO operation functions
  • Peripheral Control functions
  • Peripheral State and Error functions
Attention
                       ##### How to use this driver #####
     The USART HAL driver can be used as follows:
     (#) Declare a USART_HandleTypeDef handle structure (eg. USART_HandleTypeDef husart).
     (#) Initialize the USART low level resources by implementing the HAL_USART_MspInit() API:
         (++) Enable the USARTx interface clock.
         (++) USART pins configuration:
           (+++) Enable the clock for the USART GPIOs.
           (+++) Configure these USART pins as alternate function pull-up.
         (++) NVIC configuration if you need to use interrupt process (HAL_USART_Transmit_IT(),
               HAL_USART_Receive_IT() and HAL_USART_TransmitReceive_IT() APIs):
           (+++) Configure the USARTx interrupt priority.
           (+++) Enable the NVIC USART IRQ handle.
           (++) USART interrupts handling:
             -@@-   The specific USART interrupts (Transmission complete interrupt,
                 RXNE interrupt and Error Interrupts) will be managed using the macros
                 __HAL_USART_ENABLE_IT() and __HAL_USART_DISABLE_IT() inside the transmit and receive process.
         (++) DMA Configuration if you need to use DMA process (HAL_USART_Transmit_DMA()
              HAL_USART_Receive_DMA() and HAL_USART_TransmitReceive_DMA() APIs):
           (+++) Declare a DMA handle structure for the Tx/Rx channel.
           (+++) Enable the DMAx interface clock.
           (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters.
           (+++) Configure the DMA Tx/Rx channel.
           (+++) Associate the initialized DMA handle to the USART DMA Tx/Rx handle.
           (+++) Configure the priority and enable the NVIC for the transfer
                 complete interrupt on the DMA Tx/Rx channel.
     (#) Program the Baud Rate, Word Length, Stop Bit, Parity, and Mode
         (Receiver/Transmitter) in the husart handle Init structure.
     (#) Initialize the USART registers by calling the HAL_USART_Init() API:
         (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc)
              by calling the customized HAL_USART_MspInit(&husart) API.
    (@) To configure and enable/disable the USART to wake up the MCU from stop mode, resort to UART API's
       HAL_UARTEx_StopModeWakeUpSourceConfig(), HAL_UARTEx_EnableStopMode() and
       HAL_UARTEx_DisableStopMode() in casting the USART handle to UART type UART_HandleTypeDef.
   ##### Callback registration #####
   The compilation define USE_HAL_USART_REGISTER_CALLBACKS when set to 1
   allows the user to configure dynamically the driver callbacks.
   Use Function HAL_USART_RegisterCallback() to register a user callback.
   Function HAL_USART_RegisterCallback() allows to register following callbacks:
   (+) TxHalfCpltCallback        : Tx Half Complete Callback.
   (+) TxCpltCallback            : Tx Complete Callback.
   (+) RxHalfCpltCallback        : Rx Half Complete Callback.
   (+) RxCpltCallback            : Rx Complete Callback.
   (+) TxRxCpltCallback          : Tx Rx Complete Callback.
   (+) ErrorCallback             : Error Callback.
   (+) AbortCpltCallback         : Abort Complete Callback.
   (+) RxFifoFullCallback        : Rx Fifo Full Callback.
   (+) TxFifoEmptyCallback       : Tx Fifo Empty Callback.
   (+) MspInitCallback           : USART MspInit.
   (+) MspDeInitCallback         : USART MspDeInit.
   This function takes as parameters the HAL peripheral handle, the Callback ID
   and a pointer to the user callback function.
   Use function HAL_USART_UnRegisterCallback() to reset a callback to the default
   weak function.
   HAL_USART_UnRegisterCallback() takes as parameters the HAL peripheral handle,
   and the Callback ID.
   This function allows to reset following callbacks:
   By default, after the HAL_USART_Init() and when the state is HAL_USART_STATE_RESET
   all callbacks are set to the corresponding weak functions:
   examples HAL_USART_TxCpltCallback(), HAL_USART_RxHalfCpltCallback().
   Exception done for MspInit and MspDeInit functions that are respectively
   reset to the legacy weak functions in the HAL_USART_Init()
   and HAL_USART_DeInit() only when these callbacks are null (not registered beforehand).
   If not, MspInit or MspDeInit are not null, the HAL_USART_Init() and HAL_USART_DeInit()
   keep and use the user MspInit/MspDeInit callbacks (registered beforehand).
   Callbacks can be registered/unregistered in HAL_USART_STATE_READY state only.
   Exception done MspInit/MspDeInit that can be registered/unregistered
   in HAL_USART_STATE_READY or HAL_USART_STATE_RESET state, thus registered (user)
   MspInit/DeInit callbacks can be used during the Init/DeInit.
   In that case first register the MspInit/MspDeInit user callbacks
   using HAL_USART_RegisterCallback() before calling HAL_USART_DeInit()
   or HAL_USART_Init() function.
   When The compilation define USE_HAL_USART_REGISTER_CALLBACKS is set to 0 or
   not defined, the callback registration feature is not available
   and weak callbacks are used.
