RTEMS 6.1-rc5
stm32h7xx_hal_sd_ex.c File Reference
SD card Extended HAL module driver. This file provides firmware functions to manage the following functionalities of the Secure Digital (SD) peripheral: More...
#include "stm32h7xx_hal.h"
Author
MCD Application Team
  • Extended features functions
Attention
                      ##### How to use this driver #####
 The SD Extension HAL driver can be used as follows:
 (+) Configure Buffer0 and Buffer1 start address and Buffer size using HAL_SDEx_ConfigDMAMultiBuffer() function.
 (+) Start Read and Write for multibuffer mode using HAL_SDEx_ReadBlocksDMAMultiBuffer()
     and HAL_SDEx_WriteBlocksDMAMultiBuffer() functions.
