RTEMS 6.1-rc5
IRDA HAL module driver. This file provides firmware functions to manage the following functionalities of the IrDA (Infrared Data Association) Peripheral (IRDA) More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The IRDA HAL driver can be used as follows: (#) Declare a IRDA_HandleTypeDef handle structure (eg. IRDA_HandleTypeDef hirda). (#) Initialize the IRDA low level resources by implementing the HAL_IRDA_MspInit() API in setting the associated USART or UART in IRDA mode: (++) Enable the USARTx/UARTx interface clock. (++) USARTx/UARTx pins configuration: (+++) Enable the clock for the USARTx/UARTx GPIOs. (+++) Configure these USARTx/UARTx pins (TX as alternate function pull-up, RX as alternate function Input). (++) NVIC configuration if you need to use interrupt process (HAL_IRDA_Transmit_IT() and HAL_IRDA_Receive_IT() APIs): (+++) Configure the USARTx/UARTx interrupt priority. (+++) Enable the NVIC USARTx/UARTx IRQ handle. (+++) The specific IRDA interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_IRDA_ENABLE_IT() and __HAL_IRDA_DISABLE_IT() inside the transmit and receive process. (++) DMA Configuration if you need to use DMA process (HAL_IRDA_Transmit_DMA() and HAL_IRDA_Receive_DMA() APIs): (+++) Declare a DMA handle structure for the Tx/Rx channel. (+++) Enable the DMAx interface clock. (+++) Configure the declared DMA handle structure with the required Tx/Rx parameters. (+++) Configure the DMA Tx/Rx channel. (+++) Associate the initialized DMA handle to the IRDA DMA Tx/Rx handle. (+++) Configure the priority and enable the NVIC for the transfer complete interrupt on the DMA Tx/Rx channel. (#) Program the Baud Rate, Word Length and Parity and Mode(Receiver/Transmitter), the normal or low power mode and the clock prescaler in the hirda handle Init structure. (#) Initialize the IRDA registers by calling the HAL_IRDA_Init() API: (++) This API configures also the low level Hardware GPIO, CLOCK, CORTEX...etc) by calling the customized HAL_IRDA_MspInit() API. -@@- The specific IRDA interrupts (Transmission complete interrupt, RXNE interrupt and Error Interrupts) will be managed using the macros __HAL_IRDA_ENABLE_IT() and __HAL_IRDA_DISABLE_IT() inside the transmit and receive process. (#) Three operation modes are available within this driver : *** Polling mode IO operation *** ================================= [..] (+) Send an amount of data in blocking mode using HAL_IRDA_Transmit() (+) Receive an amount of data in blocking mode using HAL_IRDA_Receive() *** Interrupt mode IO operation *** =================================== [..] (+) Send an amount of data in non-blocking mode using HAL_IRDA_Transmit_IT() (+) At transmission end of transfer HAL_IRDA_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_TxCpltCallback() (+) Receive an amount of data in non-blocking mode using HAL_IRDA_Receive_IT() (+) At reception end of transfer HAL_IRDA_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_RxCpltCallback() (+) In case of transfer Error, HAL_IRDA_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_IRDA_ErrorCallback() *** DMA mode IO operation *** ============================== [..] (+) Send an amount of data in non-blocking mode (DMA) using HAL_IRDA_Transmit_DMA() (+) At transmission half of transfer HAL_IRDA_TxHalfCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_TxHalfCpltCallback() (+) At transmission end of transfer HAL_IRDA_TxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_TxCpltCallback() (+) Receive an amount of data in non-blocking mode (DMA) using HAL_IRDA_Receive_DMA() (+) At reception half of transfer HAL_IRDA_RxHalfCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_RxHalfCpltCallback() (+) At reception end of transfer HAL_IRDA_RxCpltCallback() is executed and user can add his own code by customization of function pointer HAL_IRDA_RxCpltCallback() (+) In case of transfer Error, HAL_IRDA_ErrorCallback() function is executed and user can add his own code by customization of function pointer HAL_IRDA_ErrorCallback() *** IRDA HAL driver macros list *** ==================================== [..] Below the list of most used macros in IRDA HAL driver. (+) __HAL_IRDA_ENABLE: Enable the IRDA peripheral (+) __HAL_IRDA_DISABLE: Disable the IRDA peripheral (+) __HAL_IRDA_GET_FLAG : Check whether the specified IRDA flag is set or not (+) __HAL_IRDA_CLEAR_FLAG : Clear the specified IRDA pending flag (+) __HAL_IRDA_ENABLE_IT: Enable the specified IRDA interrupt (+) __HAL_IRDA_DISABLE_IT: Disable the specified IRDA interrupt (+) __HAL_IRDA_GET_IT_SOURCE: Check whether or not the specified IRDA interrupt is enabled [..] (@) You can refer to the IRDA HAL driver header file for more useful macros ##### Callback registration ##### ================================== [..] The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS when set to 1 allows the user to configure dynamically the driver callbacks. [..] Use Function HAL_IRDA_RegisterCallback() to register a user callback. Function HAL_IRDA_RegisterCallback() allows to register following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) MspInitCallback : IRDA MspInit. (+) MspDeInitCallback : IRDA MspDeInit. This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_IRDA_UnRegisterCallback() to reset a callback to the default weak function. HAL_IRDA_UnRegisterCallback() takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) TxHalfCpltCallback : Tx Half Complete Callback. (+) TxCpltCallback : Tx Complete Callback. (+) RxHalfCpltCallback : Rx Half Complete Callback. (+) RxCpltCallback : Rx Complete Callback. (+) ErrorCallback : Error Callback. (+) AbortCpltCallback : Abort Complete Callback. (+) AbortTransmitCpltCallback : Abort Transmit Complete Callback. (+) AbortReceiveCpltCallback : Abort Receive Complete Callback. (+) MspInitCallback : IRDA MspInit. (+) MspDeInitCallback : IRDA MspDeInit. [..] By default, after the HAL_IRDA_Init() and when the state is HAL_IRDA_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_IRDA_TxCpltCallback(), HAL_IRDA_RxHalfCpltCallback(). Exception done for MspInit and MspDeInit functions that are respectively reset to the legacy weak functions in the HAL_IRDA_Init() and HAL_IRDA_DeInit() only when these callbacks are null (not registered beforehand). If not, MspInit or MspDeInit are not null, the HAL_IRDA_Init() and HAL_IRDA_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand). [..] Callbacks can be registered/unregistered in HAL_IRDA_STATE_READY state only. Exception done MspInit/MspDeInit that can be registered/unregistered in HAL_IRDA_STATE_READY or HAL_IRDA_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. In that case first register the MspInit/MspDeInit user callbacks using HAL_IRDA_RegisterCallback() before calling HAL_IRDA_DeInit() or HAL_IRDA_Init() function. [..] When The compilation define USE_HAL_IRDA_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and weak callbacks are used.
