RTEMS 6.1-rc5
DMA Extension HAL module driver This file provides firmware functions to manage the following functionalities of the DMA Extension peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The DMA Extension HAL driver can be used as follows: (+) Start a multi buffer transfer using the HAL_DMA_MultiBufferStart() function for polling mode or HAL_DMA_MultiBufferStart_IT() for interrupt mode. (+) Configure the DMA_MUX Synchronization Block using HAL_DMAEx_ConfigMuxSync function. (+) Configure the DMA_MUX Request Generator Block using HAL_DMAEx_ConfigMuxRequestGenerator function. Functions HAL_DMAEx_EnableMuxRequestGenerator and HAL_DMAEx_DisableMuxRequestGenerator can then be used to respectively enable/disable the request generator. (+) To handle the DMAMUX Interrupts, the function HAL_DMAEx_MUX_IRQHandler should be called from the DMAMUX IRQ handler i.e DMAMUX1_OVR_IRQHandler or DMAMUX2_OVR_IRQHandler . As only one interrupt line is available for all DMAMUX channels and request generators , HAL_DMA_MUX_IRQHandler should be called with, as parameter, the appropriate DMA handle as many as used DMAs in the user project (exception done if a given DMA is not using the DMAMUX SYNC block neither a request generator) -@- In Memory-to-Memory transfer mode, Multi (Double) Buffer mode is not allowed. -@- When Multi (Double) Buffer mode is enabled, the transfer is circular by default. -@- In Multi (Double) buffer mode, it is possible to update the base address for the AHB memory port on the fly (DMA_SxM0AR or DMA_SxM1AR) when the stream is enabled. -@- Multi (Double) buffer mode is possible with DMA and BDMA instances.
