RTEMS 6.1-rc5
Extended DAC HAL module driver. This file provides firmware functions to manage the extended functionalities of the DAC peripheral. More...
#include "stm32h7xx_hal.h"
============================================================================== ##### How to use this driver ##### ============================================================================== [..] *** Dual mode IO operation *** ============================== [..] (+) Use HAL_DACEx_DualStart() to enable both channel and start conversion for dual mode operation. If software trigger is selected, using HAL_DACEx_DualStart() will start the conversion of the value previously set by HAL_DACEx_DualSetValue(). (+) Use HAL_DACEx_DualStop() to disable both channel and stop conversion for dual mode operation. (+) Use HAL_DACEx_DualStart_DMA() to enable both channel and start conversion for dual mode operation using DMA to feed DAC converters. First issued trigger will start the conversion of the value previously set by HAL_DACEx_DualSetValue(). The same callbacks that are used in single mode are called in dual mode to notify transfer completion (half complete or complete), errors or underrun. (+) Use HAL_DACEx_DualStop_DMA() to disable both channel and stop conversion for dual mode operation using DMA to feed DAC converters. (+) When Dual mode is enabled (i.e. DAC Channel1 and Channel2 are used simultaneously) : Use HAL_DACEx_DualGetValue() to get digital data to be converted and use HAL_DACEx_DualSetValue() to set digital value to converted simultaneously in Channel 1 and Channel 2. *** Signal generation operation *** =================================== [..] (+) Use HAL_DACEx_TriangleWaveGenerate() to generate Triangle signal. (+) Use HAL_DACEx_NoiseWaveGenerate() to generate Noise signal. (+) HAL_DACEx_SelfCalibrate to calibrate one DAC channel. (+) HAL_DACEx_SetUserTrimming to set user trimming value. (+) HAL_DACEx_GetTrimOffset to retrieve trimming value (factory setting after reset, user setting if HAL_DACEx_SetUserTrimming have been used at least one time after reset).
