RTEMS 6.1-rc5
stm32h7xx_hal_adc_ex.h File Reference
Header file of ADC HAL extended module. More...
#include "stm32h7xx_hal_def.h"
struct  ADC_InjOversamplingTypeDef
 ADC Injected Conversion Oversampling structure definition. More...
struct  ADC_InjectionConfTypeDef
 Structure definition of ADC group injected and ADC channel affected to ADC group injected. More...
struct  ADC_MultiModeTypeDef
 Structure definition of ADC multimode. More...
#define ADC_INJECTED_SOFTWARE_START   (LL_ADC_INJ_TRIG_SOFTWARE)
#define ADC_EXTERNALTRIGINJEC_T1_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO)
#define ADC_EXTERNALTRIGINJEC_T1_CC4   (LL_ADC_INJ_TRIG_EXT_TIM1_CH4)
#define ADC_EXTERNALTRIGINJEC_T2_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM2_TRGO)
#define ADC_EXTERNALTRIGINJEC_T2_CC1   (LL_ADC_INJ_TRIG_EXT_TIM2_CH1)
#define ADC_EXTERNALTRIGINJEC_T3_CC4   (LL_ADC_INJ_TRIG_EXT_TIM3_CH4)
#define ADC_EXTERNALTRIGINJEC_T4_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM4_TRGO)
#define ADC_EXTERNALTRIGINJEC_EXT_IT15   (LL_ADC_INJ_TRIG_EXT_EXTI_LINE15)
#define ADC_EXTERNALTRIGINJEC_T8_CC4   (LL_ADC_INJ_TRIG_EXT_TIM8_CH4)
#define ADC_EXTERNALTRIGINJEC_T1_TRGO2   (LL_ADC_INJ_TRIG_EXT_TIM1_TRGO2)
#define ADC_EXTERNALTRIGINJEC_T8_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO)
#define ADC_EXTERNALTRIGINJEC_T8_TRGO2   (LL_ADC_INJ_TRIG_EXT_TIM8_TRGO2)
#define ADC_EXTERNALTRIGINJEC_T3_CC3   (LL_ADC_INJ_TRIG_EXT_TIM3_CH3)
#define ADC_EXTERNALTRIGINJEC_T3_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM3_TRGO)
#define ADC_EXTERNALTRIGINJEC_T3_CC1   (LL_ADC_INJ_TRIG_EXT_TIM3_CH1)
#define ADC_EXTERNALTRIGINJEC_T6_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM6_TRGO)
#define ADC_EXTERNALTRIGINJEC_T15_TRGO   (LL_ADC_INJ_TRIG_EXT_TIM15_TRGO)
#define ADC_EXTERNALTRIGINJEC_LPTIM1_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM1_OUT)
#define ADC_EXTERNALTRIGINJEC_LPTIM2_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM2_OUT)
#define ADC_EXTERNALTRIGINJEC_LPTIM3_OUT   (LL_ADC_INJ_TRIG_EXT_LPTIM3_OUT)
#define ADC_EXTERNALTRIGINJECCONV_EDGE_NONE   (0x00000000UL)
#define ADC_EXTERNALTRIGINJECCONV_EDGE_RISING   (ADC_JSQR_JEXTEN_0)
#define ADC_EXTERNALTRIGINJECCONV_EDGE_FALLING   (ADC_JSQR_JEXTEN_1)
#define ADC_EXTERNALTRIGINJECCONV_EDGE_RISINGFALLING   (ADC_JSQR_JEXTEN)
#define ADC_SINGLE_ENDED   (LL_ADC_SINGLE_ENDED)
#define ADC_DIFFERENTIAL_ENDED   (LL_ADC_DIFFERENTIAL_ENDED)
#define ADC_OFFSET_NONE   (ADC_OFFSET_4 + 1U)
#define ADC_OFFSET_1   (LL_ADC_OFFSET_1)
#define ADC_OFFSET_2   (LL_ADC_OFFSET_2)
#define ADC_OFFSET_3   (LL_ADC_OFFSET_3)
#define ADC_OFFSET_4   (LL_ADC_OFFSET_4)
#define ADC_INJECTED_RANK_1   (LL_ADC_INJ_RANK_1)
#define ADC_INJECTED_RANK_2   (LL_ADC_INJ_RANK_2)
#define ADC_INJECTED_RANK_3   (LL_ADC_INJ_RANK_3)
#define ADC_INJECTED_RANK_4   (LL_ADC_INJ_RANK_4)
#define ADC_MODE_INDEPENDENT   (LL_ADC_MULTI_INDEPENDENT)
#define ADC_DUALMODE_REGSIMULT   (LL_ADC_MULTI_DUAL_REG_SIMULT)
#define ADC_DUALMODE_INTERL   (LL_ADC_MULTI_DUAL_REG_INTERL)
#define ADC_DUALMODE_INJECSIMULT   (LL_ADC_MULTI_DUAL_INJ_SIMULT)
#define ADC_DUALMODE_ALTERTRIG   (LL_ADC_MULTI_DUAL_INJ_ALTERN)
#define ADC_DUALMODE_REGSIMULT_INJECSIMULT   (LL_ADC_MULTI_DUAL_REG_SIM_INJ_SIM)
#define ADC_DUALMODE_REGSIMULT_ALTERTRIG   (LL_ADC_MULTI_DUAL_REG_SIM_INJ_ALT)
#define ADC_DUALMODE_REGINTERL_INJECSIMULT   (LL_ADC_MULTI_DUAL_REG_INT_INJ_SIM)
#define ADC_DUALMODEDATAFORMAT_DISABLED   (0x00000000UL)
#define ADC_DUALMODEDATAFORMAT_32_10_BITS   (ADC_CCR_DAMDF_1)
#define ADC_DUALMODEDATAFORMAT_8_BITS   ((ADC_CCR_DAMDF_0 |ADC_CCR_DAMDF_1))
#define ADC_TWOSAMPLINGDELAY_1CYCLE   (LL_ADC_MULTI_TWOSMP_DELAY_1CYCLE_5)
#define ADC_TWOSAMPLINGDELAY_2CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_2CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_3CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_3CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_4CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_4CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_5CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_5CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_6CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_6CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_7CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_7CYCLES_5)
#define ADC_TWOSAMPLINGDELAY_8CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_8CYCLES)
#define ADC_TWOSAMPLINGDELAY_9CYCLES   (LL_ADC_MULTI_TWOSMP_DELAY_9CYCLES)
#define ADC_REGULAR_GROUP   (LL_ADC_GROUP_REGULAR)
#define ADC_INJECTED_GROUP   (LL_ADC_GROUP_INJECTED)
#define ADC_REGULAR_INJECTED_GROUP   (LL_ADC_GROUP_REGULAR_INJECTED)
#define ADC_CFGR_FIELDS
#define ADC_SMPR1_FIELDS
#define ADC_CFGR_FIELDS_2   ((uint32_t)(ADC_CFGR_DMNGT | ADC_CFGR_AUTDLY))
#define ADC_FORCE_MODE_INDEPENDENT(__HANDLE__)    LL_ADC_SetMultimode(__LL_ADC_COMMON_INSTANCE((__HANDLE__)->Instance), LL_ADC_MULTI_INDEPENDENT)
 Force ADC instance in multimode mode independent (multimode disable).
#define ADC_IS_SOFTWARE_START_INJECTED(__HANDLE__)    (((__HANDLE__)->Instance->JSQR & ADC_JSQR_JEXTEN) == 0UL)
 Test if conversion trigger of injected group is software start or external trigger.
#define ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED(__HANDLE__)
 Check if conversion is on going on regular or injected groups.
#define ADC_IS_CONVERSION_ONGOING_INJECTED(__HANDLE__)    (LL_ADC_INJ_IsConversionOngoing((__HANDLE__)->Instance))
 Check if conversion is on going on injected group.
#define ADC_JSQR_RK(__CHANNELNB__, __RANKNB__)   ((((__CHANNELNB__) & ADC_CHANNEL_ID_NUMBER_MASK) >> ADC_CHANNEL_ID_NUMBER_BITOFFSET_POS) << ((__RANKNB__) & ADC_INJ_RANK_ID_JSQR_MASK))
 Set the selected injected Channel rank.
#define ADC_CFGR_INJECT_CONTEXT_QUEUE(__INJECT_CONTEXT_QUEUE_MODE__)   ((__INJECT_CONTEXT_QUEUE_MODE__) << ADC_CFGR_JQM_Pos)
 Configure ADC injected context queue.
#define ADC_CFGR_INJECT_DISCCONTINUOUS(__INJECT_DISCONTINUOUS_MODE__)   ((__INJECT_DISCONTINUOUS_MODE__) << ADC_CFGR_JDISCEN_Pos)
 Configure ADC discontinuous conversion mode for injected group.
#define ADC_CFGR_REG_DISCONTINUOUS(__REG_DISCONTINUOUS_MODE__)   ((__REG_DISCONTINUOUS_MODE__) << ADC_CFGR_DISCEN_Pos)
 Configure ADC discontinuous conversion mode for regular group.
#define ADC_CFGR_DISCONTINUOUS_NUM(__NBR_DISCONTINUOUS_CONV__)   (((__NBR_DISCONTINUOUS_CONV__) - 1UL) << ADC_CFGR_DISCNUM_Pos)
 Configure the number of discontinuous conversions for regular group.
#define ADC_CFGR_AUTOWAIT(__AUTOWAIT__)   ((__AUTOWAIT__) << ADC_CFGR_AUTDLY_Pos)
 Configure the ADC auto delay mode.
#define ADC_CFGR_CONTINUOUS(__CONTINUOUS_MODE__)   ((__CONTINUOUS_MODE__) << ADC_CFGR_CONT_Pos)
 Configure ADC continuous conversion mode.
#define ADC_CFGR_DMACONTREQ(__DMACONTREQ_MODE__)   ((__DMACONTREQ_MODE__))
 Enable the ADC DMA continuous request.
#define ADC_OFR_CHANNEL(__CHANNEL__)   ((__CHANNEL__) << ADC_OFR1_OFFSET1_CH_Pos)
 Configure the channel number into offset OFRx register.
#define ADC_DIFSEL_CHANNEL(__CHANNEL__)   (1UL << (__CHANNEL__))
 Configure the channel number into differential mode selection register.
#define ADC_CALFACT_DIFF_SET(__CALIBRATION_FACTOR__)   (((__CALIBRATION_FACTOR__) & (ADC_CALFACT_CALFACT_D_Pos >> ADC_CALFACT_CALFACT_D_Pos) ) << ADC_CALFACT_CALFACT_D_Pos)
 Configure calibration factor in differential mode to be set into calibration register.
#define ADC_CALFACT_DIFF_GET(__CALIBRATION_FACTOR__)   ((__CALIBRATION_FACTOR__) >> ADC_CALFACT_CALFACT_D_Pos)
 Calibration factor in differential mode to be retrieved from calibration register.
#define ADC_TRX_HIGHTHRESHOLD(__THRESHOLD__)   ((__THRESHOLD__) << 16UL)
 Configure the analog watchdog high threshold into registers TR1, TR2 or TR3.
#define ADC_CCR_MULTI_DMACONTREQ(__DMACONTREQ_MODE__)   ((__DMACONTREQ_MODE__) << ADC_CCR_DMACFG_Pos)
 Configure the ADC DMA continuous request for ADC multimode.
#define ADC_OFFSET_SHIFT_RESOLUTION(__HANDLE__, __OFFSET__)
 Shift the offset in function of the selected ADC resolution.
#define ADC_AWD1THRESHOLD_SHIFT_RESOLUTION(__HANDLE__, __THRESHOLD__)
 Shift the AWD1 threshold in function of the selected ADC resolution.
#define ADC_AWD23THRESHOLD_SHIFT_RESOLUTION(__HANDLE__, __THRESHOLD__)
 Shift the AWD2 and AWD3 threshold in function of the selected ADC resolution.
#define ADC12_COMMON_REGISTER(__HANDLE__)   (ADC12_COMMON)
 Clear Common Control Register.
#define ADC_MASTER_REGISTER(__HANDLE__)   ( (ADC1))
 Report Master Instance.
#define ADC_IS_DUAL_REGULAR_CONVERSION_ENABLE(__HANDLE__)
 Check whether or not dual regular conversions are enabled.
#define ADC12_NONMULTIMODE_OR_MULTIMODEMASTER(__HANDLE__)
 Verification of condition for ADC start conversion: ADC must be in non-MultiMode or MultiMode with handle of ADC master.
#define ADC_INDEPENDENT_OR_NONMULTIMODEREGULAR_SLAVE(__HANDLE__)
 Ensure ADC Instance is Independent or Master, or is not Slave ADC with dual regular conversions enabled.
#define ADC_INDEPENDENT_OR_NONMULTIMODEINJECTED_SLAVE(__HANDLE__)
 Ensure ADC Instance is Independent or Master, or is not Slave ADC with dual injected conversions enabled.
#define ADC_CLEAR_COMMON_CONTROL_REGISTER(__HANDLE__)
#define ADC_MULTI_SLAVE(__HANDLE_MASTER__, __HANDLE_SLAVE__)    ( (((__HANDLE_MASTER__)->Instance == ADC1)) ? ((__HANDLE_SLAVE__)->Instance = ADC2) : ((__HANDLE_SLAVE__)->Instance = NULL) )
 Set handle instance of the ADC slave associated to the ADC master.
#define ADC_TEMPERATURE_SENSOR_INSTANCE(__HANDLE__)   (((__HANDLE__)->Instance) == ADC2)
 Verify the ADC instance connected to the temperature sensor.
#define ADC_BATTERY_VOLTAGE_INSTANCE(__HANDLE__)   (((__HANDLE__)->Instance) == ADC2)
 Verify the ADC instance connected to the battery voltage VBAT.
#define ADC_VREFINT_INSTANCE(__HANDLE__)   (((__HANDLE__)->Instance) == ADC2)
 Verify the ADC instance connected to the internal voltage reference VREFINT.
#define IS_ADC_INJECTED_NB_CONV(__LENGTH__)   (((__LENGTH__) >= (1U)) && ((__LENGTH__) <= (4U)))
 Verify the length of scheduled injected conversions group.
#define IS_ADC_CALFACT(__CALIBRATION_FACTOR__)   ((__CALIBRATION_FACTOR__) <= (0x7FFU))
 Calibration factor size verification (11 bits maximum).
#define IS_ADC_CHANNEL(__CHANNEL__)
 Verify the ADC channel setting.
#define IS_ADC1_DIFF_CHANNEL(__CHANNEL__)
 Verify the ADC channel setting in differential mode for ADC1.
#define IS_ADC2_DIFF_CHANNEL(__CHANNEL__)
 Verify the ADC channel setting in differential mode for ADC2.
#define IS_ADC3_DIFF_CHANNEL(__CHANNEL__)
 Verify the ADC channel setting in differential mode for ADC3.
#define IS_ADC_SINGLE_DIFFERENTIAL(__SING_DIFF__)
 Verify the ADC single-ended input or differential mode setting.
#define IS_ADC_OFFSET_NUMBER(__OFFSET_NUMBER__)
 Verify the ADC offset management setting.
#define IS_ADC_INJECTED_RANK(__CHANNEL__)
 Verify the ADC injected channel setting.
#define IS_ADC_EXTTRIGINJEC(__INJTRIG__)
 Verify the ADC injected conversions external trigger.
#define IS_ADC_EXTTRIGINJEC_EDGE(__EDGE__)
 Verify the ADC edge trigger setting for injected group.
#define IS_ADC_MULTIMODE(__MODE__)
 Verify the ADC multimode setting.
#define IS_ADC_DUAL_DATA_MODE(MODE)
 Verify the ADC dual data mode setting.
#define IS_ADC_SAMPLING_DELAY(__DELAY__)
 Verify the ADC multimode delay setting.
#define IS_ADC_ANALOG_WATCHDOG_NUMBER(__WATCHDOG__)
 Verify the ADC analog watchdog setting.
#define IS_ADC_ANALOG_WATCHDOG_MODE(__WATCHDOG_MODE__)
 Verify the ADC analog watchdog mode setting.
#define IS_ADC_CONVERSION_GROUP(__CONVERSION__)
 Verify the ADC conversion (regular or injected or both).
#define IS_ADC_EVENT_TYPE(__EVENT__)
 Verify the ADC event type.
#define IS_ADC_OVERSAMPLING_RATIO(RATIO)   (((RATIO) >= 1UL) && ((RATIO) <= 1024UL))
 Verify the ADC oversampling ratio.
#define IS_ADC_RIGHT_BIT_SHIFT(__SHIFT__)
 Verify the ADC oversampling shift.
#define IS_ADC_TRIGGERED_OVERSAMPLING_MODE(__MODE__)
 Verify the ADC oversampling triggered mode.
#define IS_ADC_REGOVERSAMPLING_MODE(__MODE__)
 Verify the ADC oversampling regular conversion resumed or continued mode.
#define IS_ADC_DFSDMCFG_MODE(__HANDLE__)   (SET)
 Verify the DFSDM mode configuration.
#define ADC_CFGR_DFSDM(__HANDLE__)   (0x0UL)
 Return the DFSDM configuration mode.
HAL_StatusTypeDef HAL_ADCEx_Calibration_Start (ADC_HandleTypeDef *hadc, uint32_t CalibrationMode, uint32_t SingleDiff)
uint32_t HAL_ADCEx_Calibration_GetValue (ADC_HandleTypeDef *hadc, uint32_t SingleDiff)
HAL_StatusTypeDef HAL_ADCEx_LinearCalibration_GetValue (ADC_HandleTypeDef *hadc, uint32_t *LinearCalib_Buffer)
HAL_StatusTypeDef HAL_ADCEx_Calibration_SetValue (ADC_HandleTypeDef *hadc, uint32_t SingleDiff, uint32_t CalibrationFactor)
HAL_StatusTypeDef HAL_ADCEx_LinearCalibration_SetValue (ADC_HandleTypeDef *hadc, uint32_t *LinearCalib_Buffer)
HAL_StatusTypeDef HAL_ADCEx_LinearCalibration_FactorLoad (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_InjectedStart (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_InjectedStop (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_InjectedPollForConversion (ADC_HandleTypeDef *hadc, uint32_t Timeout)
HAL_StatusTypeDef HAL_ADCEx_InjectedStart_IT (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_InjectedStop_IT (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_MultiModeStart_DMA (ADC_HandleTypeDef *hadc, uint32_t *pData, uint32_t Length)
HAL_StatusTypeDef HAL_ADCEx_MultiModeStop_DMA (ADC_HandleTypeDef *hadc)
uint32_t HAL_ADCEx_MultiModeGetValue (ADC_HandleTypeDef *hadc)
uint32_t HAL_ADCEx_InjectedGetValue (ADC_HandleTypeDef *hadc, uint32_t InjectedRank)
void HAL_ADCEx_InjectedConvCpltCallback (ADC_HandleTypeDef *hadc)
void HAL_ADCEx_InjectedQueueOverflowCallback (ADC_HandleTypeDef *hadc)
void HAL_ADCEx_LevelOutOfWindow2Callback (ADC_HandleTypeDef *hadc)
void HAL_ADCEx_LevelOutOfWindow3Callback (ADC_HandleTypeDef *hadc)
void HAL_ADCEx_EndOfSamplingCallback (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_RegularStop (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_RegularStop_IT (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_RegularStop_DMA (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_RegularMultiModeStop_DMA (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_InjectedConfigChannel (ADC_HandleTypeDef *hadc, ADC_InjectionConfTypeDef *sConfigInjected)
HAL_StatusTypeDef HAL_ADCEx_MultiModeConfigChannel (ADC_HandleTypeDef *hadc, ADC_MultiModeTypeDef *multimode)
HAL_StatusTypeDef HAL_ADCEx_EnableInjectedQueue (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_DisableInjectedQueue (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_DisableVoltageRegulator (ADC_HandleTypeDef *hadc)
HAL_StatusTypeDef HAL_ADCEx_EnterADCDeepPowerDownMode (ADC_HandleTypeDef *hadc)
Author
MCD Application Team
Attention
