RTEMS 6.1-rc5
This file provides firmware functions to manage the following functionalities of the Analog to Digital Converter (ADC) peripheral: More...
#include "stm32h7xx_hal.h"
============================================================================== ##### ADC peripheral features ##### ============================================================================== [..] (+) 16-bit, 14-bit, 12-bit, 10-bit or 8-bit configurable resolution. Note: On devices STM32H72xx and STM32H73xx, these resolution are applicable to instances ADC1 and ADC2. ADC3 is featuring resolutions 12-bit, 10-bit, 8-bit, 6-bit. (+) Interrupt generation at the end of regular conversion and in case of analog watchdog or overrun events. (+) Single and continuous conversion modes. (+) Scan mode for conversion of several channels sequentially. (+) Data alignment with in-built data coherency. (+) Programmable sampling time (channel wise) (+) External trigger (timer or EXTI) with configurable polarity (+) DMA request generation for transfer of conversions data of regular group. (+) Configurable delay between conversions in Dual interleaved mode. (+) ADC channels selectable single/differential input. (+) ADC offset shared on 4 offset instances. (+) ADC calibration (+) ADC conversion of regular group. (+) ADC supply requirements: 1.62 V to 3.6 V. (+) ADC input range: from Vref- (connected to Vssa) to Vref+ (connected to Vdda or to an external voltage reference). ##### How to use this driver ##### ============================================================================== [..] *** Configuration of top level parameters related to ADC *** ============================================================ [..] (#) Enable the ADC interface (++) As prerequisite, ADC clock must be configured at RCC top level. (++) Two clock settings are mandatory: (+++) ADC clock (core clock, also possibly conversion clock). (+++) ADC clock (conversions clock). Two possible clock sources: synchronous clock derived from AHB clock or asynchronous clock derived from system clock, the PLL2 or the PLL3 running up to 400MHz. (+++) Example: Into HAL_ADC_MspInit() (recommended code location) or with other device clock parameters configuration: (+++) __HAL_RCC_ADC_CLK_ENABLE(); (mandatory) RCC_ADCCLKSOURCE_PLL2 enable: (optional: if asynchronous clock selected) (+++) RCC_PeriphClkInitTypeDef RCC_PeriphClkInit; (+++) PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC; (+++) PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_PLL2; (+++) HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit); (++) ADC clock source and clock prescaler are configured at ADC level with parameter "ClockPrescaler" using function HAL_ADC_Init(). (#) ADC pins configuration (++) Enable the clock for the ADC GPIOs using macro __HAL_RCC_GPIOx_CLK_ENABLE() (++) Configure these ADC pins in analog mode using function HAL_GPIO_Init() (#) Optionally, in case of usage of ADC with interruptions: (++) Configure the NVIC for ADC using function HAL_NVIC_EnableIRQ(ADCx_IRQn) (++) Insert the ADC interruption handler function HAL_ADC_IRQHandler() into the function of corresponding ADC interruption vector ADCx_IRQHandler(). (#) Optionally, in case of usage of DMA: (++) Configure the DMA (DMA channel, mode normal or circular, ...) using function HAL_DMA_Init(). (++) Configure the NVIC for DMA using function HAL_NVIC_EnableIRQ(DMAx_Channelx_IRQn) (++) Insert the ADC interruption handler function HAL_ADC_IRQHandler() into the function of corresponding DMA interruption vector DMAx_Channelx_IRQHandler(). *** Configuration of ADC, group regular, channels parameters *** ================================================================ [..] (#) Configure the ADC parameters (resolution, data alignment, ...) and regular group parameters (conversion trigger, sequencer, ...) using function HAL_ADC_Init(). (#) Configure the channels for regular group parameters (channel number, channel rank into sequencer, ..., into regular group) using function HAL_ADC_ConfigChannel(). (#) Optionally, configure the analog watchdog parameters (channels monitored, thresholds, ...) using function HAL_ADC_AnalogWDGConfig(). *** Execution of ADC conversions *** ==================================== [..] (#) Optionally, perform an automatic ADC calibration to improve the conversion accuracy using function HAL_ADCEx_Calibration_Start(). (#) ADC driver can be used among three modes: polling, interruption, transfer by DMA. (++) ADC conversion by polling: (+++) Activate the ADC peripheral and start conversions using function HAL_ADC_Start() (+++) Wait for ADC conversion completion using function HAL_ADC_PollForConversion() (+++) Retrieve conversion results using function HAL_ADC_GetValue() (+++) Stop conversion and disable the ADC peripheral using function HAL_ADC_Stop() (++) ADC conversion by interruption: (+++) Activate the ADC peripheral and start conversions using function HAL_ADC_Start_IT() (+++) Wait for ADC conversion completion by call of function HAL_ADC_ConvCpltCallback() (this function must be implemented in user program) (+++) Retrieve conversion results using function HAL_ADC_GetValue() (+++) Stop conversion and disable the ADC peripheral using function HAL_ADC_Stop_IT() (++) ADC conversion with transfer by DMA: (+++) Activate the ADC peripheral and start conversions using function HAL_ADC_Start_DMA() (+++) Wait for ADC conversion completion by call of function HAL_ADC_ConvCpltCallback() or HAL_ADC_ConvHalfCpltCallback() (these functions must be implemented in user program) (+++) Conversion results are automatically transferred by DMA into destination variable address. (+++) Stop conversion and disable the ADC peripheral using function HAL_ADC_Stop_DMA() [..] (@) Callback functions must be implemented in user program: (+@) HAL_ADC_ErrorCallback() (+@) HAL_ADC_LevelOutOfWindowCallback() (callback of analog watchdog) (+@) HAL_ADC_ConvCpltCallback() (+@) HAL_ADC_ConvHalfCpltCallback *** Deinitialization of ADC *** ============================================================ [..] (#) Disable the ADC interface (++) ADC clock can be hard reset and disabled at RCC top level. (++) Hard reset of ADC peripherals using macro __HAL_RCC_ADCx_FORCE_RESET(), __HAL_RCC_ADCx_RELEASE_RESET(). (++) ADC clock disable using the equivalent macro/functions as configuration step. (+++) Example: Into HAL_ADC_MspDeInit() (recommended code location) or with other device clock parameters configuration: (+++) __HAL_RCC_ADC_CLK_DISABLE(); (if not used anymore) RCC_ADCCLKSOURCE_CLKP restore: (optional) (+++) RCC_PeriphClkInitTypeDef RCC_PeriphClkInit; (+++) PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC; (+++) PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_CLKP; (+++) HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit); (#) ADC pins configuration (++) Disable the clock for the ADC GPIOs using macro __HAL_RCC_GPIOx_CLK_DISABLE() (#) Optionally, in case of usage of ADC with interruptions: (++) Disable the NVIC for ADC using function HAL_NVIC_EnableIRQ(ADCx_IRQn) (#) Optionally, in case of usage of DMA: (++) Deinitialize the DMA using function HAL_DMA_Init(). (++) Disable the NVIC for DMA using function HAL_NVIC_EnableIRQ(DMAx_Channelx_IRQn) [..] *** Callback registration *** ============================================= [..] The compilation flag USE_HAL_ADC_REGISTER_CALLBACKS, when set to 1, allows the user to configure dynamically the driver callbacks. Use Functions HAL_ADC_RegisterCallback() to register an interrupt callback. [..] Function HAL_ADC_RegisterCallback() allows to register following callbacks: (+) ConvCpltCallback : ADC conversion complete callback (+) ConvHalfCpltCallback : ADC conversion DMA half-transfer callback (+) LevelOutOfWindowCallback : ADC analog watchdog 1 callback (+) ErrorCallback : ADC error callback (+) InjectedConvCpltCallback : ADC group injected conversion complete callback (+) InjectedQueueOverflowCallback : ADC group injected context queue overflow callback (+) LevelOutOfWindow2Callback : ADC analog watchdog 2 callback (+) LevelOutOfWindow3Callback : ADC analog watchdog 3 callback (+) EndOfSamplingCallback : ADC end of sampling callback (+) MspInitCallback : ADC Msp Init callback (+) MspDeInitCallback : ADC Msp DeInit callback This function takes as parameters the HAL peripheral handle, the Callback ID and a pointer to the user callback function. [..] Use function HAL_ADC_UnRegisterCallback to reset a callback to the default weak function. [..] HAL_ADC_UnRegisterCallback takes as parameters the HAL peripheral handle, and the Callback ID. This function allows to reset following callbacks: (+) ConvCpltCallback : ADC conversion complete callback (+) ConvHalfCpltCallback : ADC conversion DMA half-transfer callback (+) LevelOutOfWindowCallback : ADC analog watchdog 1 callback (+) ErrorCallback : ADC error callback (+) InjectedConvCpltCallback : ADC group injected conversion complete callback (+) InjectedQueueOverflowCallback : ADC group injected context queue overflow callback (+) LevelOutOfWindow2Callback : ADC analog watchdog 2 callback (+) LevelOutOfWindow3Callback : ADC analog watchdog 3 callback (+) EndOfSamplingCallback : ADC end of sampling callback (+) MspInitCallback : ADC Msp Init callback (+) MspDeInitCallback : ADC Msp DeInit callback [..] By default, after the HAL_ADC_Init() and when the state is HAL_ADC_STATE_RESET all callbacks are set to the corresponding weak functions: examples HAL_ADC_ConvCpltCallback(), HAL_ADC_ErrorCallback(). Exception done for MspInit and MspDeInit functions that are reset to the legacy weak functions in the HAL_ADC_Init()/ HAL_ADC_DeInit() only when these callbacks are null (not registered beforehand). [..] If MspInit or MspDeInit are not null, the HAL_ADC_Init()/ HAL_ADC_DeInit() keep and use the user MspInit/MspDeInit callbacks (registered beforehand) whatever the state. [..] Callbacks can be registered/unregistered in HAL_ADC_STATE_READY state only. Exception done MspInit/MspDeInit functions that can be registered/unregistered in HAL_ADC_STATE_READY or HAL_ADC_STATE_RESET state, thus registered (user) MspInit/DeInit callbacks can be used during the Init/DeInit. [..] Then, the user first registers the MspInit/MspDeInit user callbacks using HAL_ADC_RegisterCallback() before calling HAL_ADC_DeInit() or HAL_ADC_Init() function. [..] When the compilation flag USE_HAL_ADC_REGISTER_CALLBACKS is set to 0 or not defined, the callback registration feature is not available and all callbacks are set to the corresponding weak functions.
