RTEMS 6.1-rc5
rtems-rfs-format.h
2
13/*
14 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#if !defined (_RTEMS_RFS_FORMAT_H_)
39#define _RTEMS_RFS_FORMAT_H_
40
41#include <stddef.h>
42#include <stdbool.h>
43#include <stdint.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif
48
50
56{
60 size_t block_size;
61
66
71
76
81
86
90 bool verbose;
91
93
103int rtems_rfs_format (const char* name, const rtems_rfs_format_config* config);
104
105#ifdef __cplusplus
106}
107#endif
108
109#endif
int rtems_rfs_format(const char *name, const rtems_rfs_format_config *config)
Definition: rtems-rfs-format.c:559
struct _rtems_rfs_format_config rtems_rfs_format_config
Manages the Trace and Debugging Features of the RTEMS RFS File System.
Definition: rtems-rfs-format.h:56
bool verbose
Definition: rtems-rfs-format.h:90
size_t group_inodes
Definition: rtems-rfs-format.h:70
size_t block_size
Definition: rtems-rfs-format.h:60
bool initialise_inodes
Definition: rtems-rfs-format.h:85
size_t max_name_length
Definition: rtems-rfs-format.h:80
size_t group_blocks
Definition: rtems-rfs-format.h:65
int inode_overhead
Definition: rtems-rfs-format.h:75
Definition: deflate.c:114
