RTEMS 6.1-rc5
rtems-rfs-data.h
2
18/*
19 * COPYRIGHT (c) 2010 Chris Johns <chrisj@rtems.org>
20 *
21 * Redistribution and use in source and binary forms, with or without
22 * modification, are permitted provided that the following conditions
23 * are met:
24 * 1. Redistributions of source code must retain the above copyright
25 * notice, this list of conditions and the following disclaimer.
26 * 2. Redistributions in binary form must reproduce the above copyright
27 * notice, this list of conditions and the following disclaimer in the
28 * documentation and/or other materials provided with the distribution.
29 *
30 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40 * POSSIBILITY OF SUCH DAMAGE.
41 */
42
43
44#if !defined (_RTEMS_RFS_DATA_H_)
45#define _RTEMS_RFS_DATA_H_
46
47#include <stdint.h>
48
52#define rtems_rfs_data_ptr(_d) ((uint8_t*)(_d))
53
57#define rtems_rfs_data_get(_d, _t, _o, _s) \
58 (((_t)(rtems_rfs_data_ptr (_d)[_o])) << (_s))
59
63#define rtems_rfs_read_u8(_d) \
64 (*rtems_rfs_data_ptr (_d))
65
69#define rtems_rfs_read_u16(_d) \
70 (rtems_rfs_data_get (_d, uint16_t, 0, 8) | \
71 rtems_rfs_data_get (_d, uint16_t, 1, 0))
72
76#define rtems_rfs_read_u32(_d) \
77 (rtems_rfs_data_get (_d, uint32_t, 0, 24) | \
78 rtems_rfs_data_get (_d, uint32_t, 1, 16) | \
79 rtems_rfs_data_get (_d, uint32_t, 2, 8) | \
80 rtems_rfs_data_get (_d, uint32_t, 3, 0))
81
85#define rtems_rfs_write_u8(_d, _v) \
86 (*rtems_rfs_data_ptr (_d) = (uint8_t)(_v))
87
91#define rtems_rfs_write_u16(_d, _v) \
92 do { \
93 rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint16_t)(_v)) >> 8); \
94 rtems_rfs_data_ptr (_d)[1] = (uint8_t)((_v)); \
95 } while (0)
96
100#define rtems_rfs_write_u32(_d, _v) \
101 do { \
102 rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint32_t)(_v)) >> 24); \
103 rtems_rfs_data_ptr (_d)[1] = (uint8_t)(((uint32_t)(_v)) >> 16); \
104 rtems_rfs_data_ptr (_d)[2] = (uint8_t)(((uint32_t)(_v)) >> 8); \
105 rtems_rfs_data_ptr (_d)[3] = (uint8_t)((uint32_t)(_v)); \
106 } while (0)
107
108#endif
