RTEMS
6.1-rc5
bsps
arm
tms570
include
bsp
ti_herc
reg_dma.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
/* The header file is generated by make_header.py from DMA.json */
12
/* Current script's version can be found at: */
13
/* https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python */
14
15
16
* Copyright (c) 2014-2015, Premysl Houdek <kom541000@gmail.com>
17
18
* Czech Technical University in Prague
19
* Zikova 1903/4
20
* 166 36 Praha 6
21
* Czech Republic
22
23
* All rights reserved.
24
25
26
* modification, are permitted provided that the following conditions are met:
27
28
* 1. Redistributions of source code must retain the above copyright notice, this
29
* list of conditions and the following disclaimer.
30
* 2. Redistributions in binary form must reproduce the above copyright notice,
31
* this list of conditions and the following disclaimer in the documentation
32
* and/or other materials provided with the distribution.
33
34
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
35
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
36
* WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
37
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR
38
* ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
39
* (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
40
* LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
41
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
42
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
43
* SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
44
45
* The views and conclusions contained in the software and documentation are those
46
* of the authors and should not be interpreted as representing official policies,
47
* either expressed or implied, of the FreeBSD Project.
48
49
#ifndef LIBBSP_ARM_TMS570_DMA
50
#define LIBBSP_ARM_TMS570_DMA
51
52
bsp/utility.h
53
54
typedef
struct
55
uint32_t STARTADD;
/*DMA Memory Protection Region start Address Register*/
56
uint32_t ENDADD;
/*DMA Memory Protection Region End Address Register*/
57
tms570_memory_prot_t
58
59
typedef
struct
60
uint32_t GCTRL;
/*Global Control Register*/
61
uint32_t PEND;
/*Channel Pending Register*/
62
uint8_t reserved1 [4];
63
uint32_t DMASTAT;
/*DMA Status Register*/
64
uint8_t reserved2 [4];
65
uint32_t HWCHENAS;
/*HW Channel Enable Set and Status Register*/
66
uint8_t reserved3 [4];
67
uint32_t HWCHENAR;
/*HW Channel Enable Reset and Status Register*/
68
uint8_t reserved4 [4];
69
uint32_t SWCHENAS;
/*SW Channel Enable Set and Status Register*/
70
uint8_t reserved5 [4];
71
uint32_t SWCHENAR;
/*SW Channel Enable Reset and Status Register*/
72
uint8_t reserved6 [4];
73
uint32_t CHPRIOS;
/*Channel Priority Set Register*/
74
uint8_t reserved7 [4];
75
uint32_t CHPRIOR;
/*Channel Priority Reset Register*/
76
uint8_t reserved8 [4];
77
uint32_t GCHIENAS;
/*Global Channel Interrupt Enable Set Register*/
78
uint8_t reserved9 [4];
79
uint32_t GCHIENAR;
/*Global Channel Interrupt Enable Reset Register*/
80
uint8_t reserved10 [4];
81
uint32_t DREQASI[4];
/*DMA Request Assignment Register 0*/
82
uint8_t reserved11 [48];
83
uint32_t PAR0;
/*Port Assignment Register 0*/
84
uint32_t PAR1;
/*Port Assignment Register 1*/
85
uint8_t reserved12 [24];
86
uint32_t FTCMAP;
/*FTC Interrupt Mapping Register*/
87
uint8_t reserved13 [4];
88
uint32_t LFSMAP;
/*LFS Interrupt Mapping Register*/
89
uint8_t reserved14 [4];
90
uint32_t HBCMAP;
/*HBC Interrupt Mapping Register*/
91
uint8_t reserved15 [4];
92
uint32_t BTCMAP;
/*BTC Interrupt Mapping Register*/
93
uint8_t reserved16 [4];
94
uint32_t BERMAP;
/*BER Interrupt Mapping Register*/
95
uint8_t reserved17 [4];
96
uint32_t FTCINTENAS;
/*FTC Interrupt Enable Set*/
97
uint8_t reserved18 [4];
98
uint32_t FTCINTENAR;
/*FTC Interrupt Enable Reset*/
99
uint8_t reserved19 [4];
100
uint32_t LFSINTENAS;
/*LFS Interrupt Enable Set*/
101
uint8_t reserved20 [4];
102
uint32_t LFSINTENAR;
/*LFS Interrupt Enable Reset*/
103
uint8_t reserved21 [4];
104
uint32_t HBCINTENAS;
/*HBC Interrupt Enable Set*/
105
uint8_t reserved22 [4];
106
uint32_t HBCINTENAR;
/*HBC Interrupt Enable Reset*/
107
uint8_t reserved23 [4];
108
uint32_t BTCINTENAS;
/*BTC Interrupt Enable Set*/
109
uint8_t reserved24 [4];
110
uint32_t BTCINTENAR;
/*BTC Interrupt Enable Reset*/
111
uint8_t reserved25 [4];
112
uint32_t GINTFLAG;
/*Global Interrupt Flag Register*/
113
uint8_t reserved26 [4];
114
uint32_t FTCFLAG;
/*FTC Interrupt Flag Register*/
115
uint8_t reserved27 [4];
116
uint32_t LFSFLAG;
/*LFS Interrupt Flag Register*/
117
uint8_t reserved28 [4];
118
uint32_t HBCFLAG;
/*HBC Interrupt Flag Register*/
119
uint8_t reserved29 [4];
120
uint32_t BTCFLAG;
/*BTC Interrupt Flag Register*/
121
uint8_t reserved30 [4];
122
uint32_t BERFLAG;
/*BER Interrupt Flag Register*/
123
uint8_t reserved31 [4];
124
uint32_t FTCAOFFSET;
/*FTCA Interrupt Channel Offset Register*/
125
uint32_t LFSAOFFSET;
/*LFSA Interrupt Channel Offset Register*/
126
uint32_t HBCAOFFSET;
/*HBCA Interrupt Channel Offset Register*/
127
uint32_t BTCAOFFSET;
/*BTCA Interrupt Channel Offset Register*/
128
uint32_t BERAOFFSET;
/*BERA Interrupt Channel Offset Register*/
129
uint32_t FTCBOFFSET;
/*FTCB Interrupt Channel Offset Register*/
130
uint32_t LFSBOFFSET;
/*LFSB Interrupt Channel Offset Register*/
131
uint32_t HBCBOFFSET;
/*HBCB Interrupt Channel Offset Register*/
132
uint32_t BTCBOFFSET;
/*BTCB Interrupt Channel Offset Register*/
133
uint32_t BERBOFFSET;
/*BERB Interrupt Channel Offset Register*/
134
uint8_t reserved32 [4];
135
uint32_t PTCRL;
/*Port Control Register*/
136
uint32_t RTCTRL;
/*RAM Test Control Register*/
137
uint32_t DCTRL;
/*Debug Control*/
138
uint32_t WPR;
/*Watch Point Register*/
139
uint32_t WMR;
/*Watch Mask Register*/
140
uint8_t reserved33 [12];
141
uint32_t PBACSADDR;
/*Port B Active Channel Source Address Register*/
142
uint32_t PBACDADDR;
/*Port B Active Channel Destination Address Register*/
143
uint32_t PBACTC;
/*Port B Active Channel Transfer Count Register*/
144
uint8_t reserved34 [4];
145
uint32_t DMAPCR;
/*Parity Control Register*/
146
uint32_t DMAPAR;
/*DMA Parity Error Address Register*/
147
uint32_t DMAMPCTRL;
/*DMA Memory Protection Control Register*/
148
uint32_t DMAMPST;
/*DMA Memory Protection Status Register*/
149
DMAMPROS[4];
/*DMA Memory Protection Regions*/
150
tms570_dma_t
151
152
153
/*--------------------TMS570_DMA_STARTADD--------------------*/
154
/* field: STARTADDRESS - Start Address defines the address at which the region begins. */
155
/* Whole 32 bits */
156
157
/*---------------------TMS570_DMA_ENDADD---------------------*/
158
/* field: ENDADDRESS - End Address defines the address at which the region ends. */
159
/* Whole 32 bits */
160
161
/*----------------------TMS570_DMA_GCTRL----------------------*/
162
/* field: DMA_EN - DMA enable bit. */
163
#define TMS570_DMA_GCTRL_DMA_EN BSP_BIT32(16)
164
165
/* field: BUS_BUSY - This bit indicates status of DMA external AHB bus status. */
166
#define TMS570_DMA_GCTRL_BUS_BUSY BSP_BIT32(14)
167
168
/* field: DEBUG_MODE - Debug Mode. */
169
#define TMS570_DMA_GCTRL_DEBUG_MODE(val) BSP_FLD32(val,8, 9)
170
#define TMS570_DMA_GCTRL_DEBUG_MODE_GET(reg) BSP_FLD32GET(reg,8, 9)
171
#define TMS570_DMA_GCTRL_DEBUG_MODE_SET(reg,val) BSP_FLD32SET(reg, val,8, 9)
172
173
/* field: DMA_RES - DMA software reset */
174
#define TMS570_DMA_GCTRL_DMA_RES BSP_BIT32(0)
175
176
177
/*----------------------TMS570_DMA_PEND----------------------*/
178
/* field: PEND - Channel pending register. */
179
#define TMS570_DMA_PEND_PEND(val) BSP_FLD32(val,0, 15)
180
#define TMS570_DMA_PEND_PEND_GET(reg) BSP_FLD32GET(reg,0, 15)
181
#define TMS570_DMA_PEND_PEND_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
182
183
184
/*---------------------TMS570_DMA_DMASTAT---------------------*/
185
/* field: STCH - Status of DMA channels. */
186
#define TMS570_DMA_DMASTAT_STCH(val) BSP_FLD32(val,0, 15)
187
#define TMS570_DMA_DMASTAT_STCH_GET(reg) BSP_FLD32GET(reg,0, 15)
188
#define TMS570_DMA_DMASTAT_STCH_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
189
190
191
/*--------------------TMS570_DMA_HWCHENAS--------------------*/
192
/* field: HWCHENA - Hardware channel enable bit. */
193
#define TMS570_DMA_HWCHENAS_HWCHENA(val) BSP_FLD32(val,0, 15)
194
#define TMS570_DMA_HWCHENAS_HWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
195
#define TMS570_DMA_HWCHENAS_HWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
196
197
198
/*--------------------TMS570_DMA_HWCHENAR--------------------*/
199
/* field: HWCHDIS - HW channel disable bit. */
200
#define TMS570_DMA_HWCHENAR_HWCHDIS(val) BSP_FLD32(val,0, 15)
201
#define TMS570_DMA_HWCHENAR_HWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
202
#define TMS570_DMA_HWCHENAR_HWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
203
204
205
/*--------------------TMS570_DMA_SWCHENAS--------------------*/
206
/* field: SWCHENA - SW channel enable bit. */
207
#define TMS570_DMA_SWCHENAS_SWCHENA(val) BSP_FLD32(val,0, 15)
208
#define TMS570_DMA_SWCHENAS_SWCHENA_GET(reg) BSP_FLD32GET(reg,0, 15)
209
#define TMS570_DMA_SWCHENAS_SWCHENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
210
211
212
/*--------------------TMS570_DMA_SWCHENAR--------------------*/
213
/* field: SWCHDIS - SW channel disable bit. */
214
#define TMS570_DMA_SWCHENAR_SWCHDIS(val) BSP_FLD32(val,0, 15)
215
#define TMS570_DMA_SWCHENAR_SWCHDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
216
#define TMS570_DMA_SWCHENAR_SWCHDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
217
218
219
/*---------------------TMS570_DMA_CHPRIOS---------------------*/
220
/* field: CPS - Channel priority set bit. */
221
#define TMS570_DMA_CHPRIOS_CPS(val) BSP_FLD32(val,0, 15)
222
#define TMS570_DMA_CHPRIOS_CPS_GET(reg) BSP_FLD32GET(reg,0, 15)
223
#define TMS570_DMA_CHPRIOS_CPS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
224
225
226
/*---------------------TMS570_DMA_CHPRIOR---------------------*/
227
/* field: CPR - Channel priority reset bit. */
228
#define TMS570_DMA_CHPRIOR_CPR(val) BSP_FLD32(val,0, 15)
229
#define TMS570_DMA_CHPRIOR_CPR_GET(reg) BSP_FLD32GET(reg,0, 15)
230
#define TMS570_DMA_CHPRIOR_CPR_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
231
232
233
/*--------------------TMS570_DMA_GCHIENAS--------------------*/
234
/* field: GCHIE - Global channel interrupt enable bit. */
235
#define TMS570_DMA_GCHIENAS_GCHIE(val) BSP_FLD32(val,0, 15)
236
#define TMS570_DMA_GCHIENAS_GCHIE_GET(reg) BSP_FLD32GET(reg,0, 15)
237
#define TMS570_DMA_GCHIENAS_GCHIE_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
238
239
240
/*--------------------TMS570_DMA_GCHIENAR--------------------*/
241
/* field: GCHID - Global channel interrupt disable bit. */
242
#define TMS570_DMA_GCHIENAR_GCHID(val) BSP_FLD32(val,0, 15)
243
#define TMS570_DMA_GCHIENAR_GCHID_GET(reg) BSP_FLD32GET(reg,0, 15)
244
#define TMS570_DMA_GCHIENAR_GCHID_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
245
246
247
/*---------------------TMS570_DMA_DREQASI---------------------*/
248
/* field: CH0ASI - Channel 0 assignment. This bit field chooses the DMA request assignment for channel 0. */
249
#define TMS570_DMA_DREQASI_CH0ASI(val) BSP_FLD32(val,24, 29)
250
#define TMS570_DMA_DREQASI_CH0ASI_GET(reg) BSP_FLD32GET(reg,24, 29)
251
#define TMS570_DMA_DREQASI_CH0ASI_SET(reg,val) BSP_FLD32SET(reg, val,24, 29)
252
253
/* field: CH1ASI - Channel 1 assignment. This bit field chooses the DMA request assignment for channel 1. */
254
#define TMS570_DMA_DREQASI_CH1ASI(val) BSP_FLD32(val,16, 21)
255
#define TMS570_DMA_DREQASI_CH1ASI_GET(reg) BSP_FLD32GET(reg,16, 21)
256
#define TMS570_DMA_DREQASI_CH1ASI_SET(reg,val) BSP_FLD32SET(reg, val,16, 21)
257
258
/* field: CH2ASI - Channel 2 assignment. This bit field chooses the DMA request assignment for channel 2. */
259
#define TMS570_DMA_DREQASI_CH2ASI(val) BSP_FLD32(val,8, 13)
260
#define TMS570_DMA_DREQASI_CH2ASI_GET(reg) BSP_FLD32GET(reg,8, 13)
261
#define TMS570_DMA_DREQASI_CH2ASI_SET(reg,val) BSP_FLD32SET(reg, val,8, 13)
262
263
/* field: CH3ASI - Channel 3 assignment. This bit field chooses the DMA request assignment for channel 3. */
264
#define TMS570_DMA_DREQASI_CH3ASI(val) BSP_FLD32(val,0, 5)
265
#define TMS570_DMA_DREQASI_CH3ASI_GET(reg) BSP_FLD32GET(reg,0, 5)
266
#define TMS570_DMA_DREQASI_CH3ASI_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
267
268
269
/*----------------------TMS570_DMA_PAR0----------------------*/
270
/* field: CH0PA - These bit fields determine to which port channel 0 is assigned. */
271
#define TMS570_DMA_PAR0_CH0PA(val) BSP_FLD32(val,28, 30)
272
#define TMS570_DMA_PAR0_CH0PA_GET(reg) BSP_FLD32GET(reg,28, 30)
273
#define TMS570_DMA_PAR0_CH0PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
274
275
/* field: CH1PA - These bit fields determine to which port channel 1 is assigned. */
276
#define TMS570_DMA_PAR0_CH1PA(val) BSP_FLD32(val,24, 26)
277
#define TMS570_DMA_PAR0_CH1PA_GET(reg) BSP_FLD32GET(reg,24, 26)
278
#define TMS570_DMA_PAR0_CH1PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
279
280
/* field: CH2PA - These bit fields determine to which port channel 2 is assigned. */
281
#define TMS570_DMA_PAR0_CH2PA(val) BSP_FLD32(val,20, 22)
282
#define TMS570_DMA_PAR0_CH2PA_GET(reg) BSP_FLD32GET(reg,20, 22)
283
#define TMS570_DMA_PAR0_CH2PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
284
285
/* field: CH3PA - These bit fields determine to which port channel 3 is assigned. */
286
#define TMS570_DMA_PAR0_CH3PA(val) BSP_FLD32(val,16, 18)
287
#define TMS570_DMA_PAR0_CH3PA_GET(reg) BSP_FLD32GET(reg,16, 18)
288
#define TMS570_DMA_PAR0_CH3PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
289
290
/* field: CH4PA - These bit fields determine to which port channel 4 is assigned. */
291
#define TMS570_DMA_PAR0_CH4PA(val) BSP_FLD32(val,12, 14)
292
#define TMS570_DMA_PAR0_CH4PA_GET(reg) BSP_FLD32GET(reg,12, 14)
293
#define TMS570_DMA_PAR0_CH4PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
294
295
/* field: CH5PA - These bit fields determine to which port channel 5 is assigned. */
296
#define TMS570_DMA_PAR0_CH5PA(val) BSP_FLD32(val,8, 10)
297
#define TMS570_DMA_PAR0_CH5PA_GET(reg) BSP_FLD32GET(reg,8, 10)
298
#define TMS570_DMA_PAR0_CH5PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
299
300
/* field: CH6PA - These bit fields determine to which port channel 6 is assigned. */
301
#define TMS570_DMA_PAR0_CH6PA(val) BSP_FLD32(val,4, 6)
302
#define TMS570_DMA_PAR0_CH6PA_GET(reg) BSP_FLD32GET(reg,4, 6)
303
#define TMS570_DMA_PAR0_CH6PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
304
305
/* field: CH7PA - These bit fields determine to which port channel 7 is assigned. */
306
#define TMS570_DMA_PAR0_CH7PA(val) BSP_FLD32(val,0, 2)
307
#define TMS570_DMA_PAR0_CH7PA_GET(reg) BSP_FLD32GET(reg,0, 2)
308
#define TMS570_DMA_PAR0_CH7PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
309
310
311
/*----------------------TMS570_DMA_PAR1----------------------*/
312
/* field: CH8PA - These bit fields determine to which port channel 8 is assigned. */
313
#define TMS570_DMA_PAR1_CH8PA(val) BSP_FLD32(val,28, 30)
314
#define TMS570_DMA_PAR1_CH8PA_GET(reg) BSP_FLD32GET(reg,28, 30)
315
#define TMS570_DMA_PAR1_CH8PA_SET(reg,val) BSP_FLD32SET(reg, val,28, 30)
316
317
/* field: CH9PA - These bit fields determine to which port channel 9 is assigned. */
318
#define TMS570_DMA_PAR1_CH9PA(val) BSP_FLD32(val,24, 26)
319
#define TMS570_DMA_PAR1_CH9PA_GET(reg) BSP_FLD32GET(reg,24, 26)
320
#define TMS570_DMA_PAR1_CH9PA_SET(reg,val) BSP_FLD32SET(reg, val,24, 26)
321
322
/* field: CH10PA - These bit fields determine to which port channel 10 is assigned. */
323
#define TMS570_DMA_PAR1_CH10PA(val) BSP_FLD32(val,20, 22)
324
#define TMS570_DMA_PAR1_CH10PA_GET(reg) BSP_FLD32GET(reg,20, 22)
325
#define TMS570_DMA_PAR1_CH10PA_SET(reg,val) BSP_FLD32SET(reg, val,20, 22)
326
327
/* field: CH11PA - These bit fields determine to which port channel 11 is assigned. */
328
#define TMS570_DMA_PAR1_CH11PA(val) BSP_FLD32(val,16, 18)
329
#define TMS570_DMA_PAR1_CH11PA_GET(reg) BSP_FLD32GET(reg,16, 18)
330
#define TMS570_DMA_PAR1_CH11PA_SET(reg,val) BSP_FLD32SET(reg, val,16, 18)
331
332
/* field: CH12PA - These bit fields determine to which port channel 12 is assigned. */
333
#define TMS570_DMA_PAR1_CH12PA(val) BSP_FLD32(val,12, 14)
334
#define TMS570_DMA_PAR1_CH12PA_GET(reg) BSP_FLD32GET(reg,12, 14)
335
#define TMS570_DMA_PAR1_CH12PA_SET(reg,val) BSP_FLD32SET(reg, val,12, 14)
336
337
/* field: CH13PA - These bit fields determine to which port channel 13 is assigned. */
338
#define TMS570_DMA_PAR1_CH13PA(val) BSP_FLD32(val,8, 10)
339
#define TMS570_DMA_PAR1_CH13PA_GET(reg) BSP_FLD32GET(reg,8, 10)
340
#define TMS570_DMA_PAR1_CH13PA_SET(reg,val) BSP_FLD32SET(reg, val,8, 10)
341
342
/* field: CH14PA - These bit fields determine to which port channel 14 is assigned. */
343
#define TMS570_DMA_PAR1_CH14PA(val) BSP_FLD32(val,4, 6)
344
#define TMS570_DMA_PAR1_CH14PA_GET(reg) BSP_FLD32GET(reg,4, 6)
345
#define TMS570_DMA_PAR1_CH14PA_SET(reg,val) BSP_FLD32SET(reg, val,4, 6)
346
347
/* field: CH15PA - These bit fields determine to which port channel 15 is assigned. */
348
#define TMS570_DMA_PAR1_CH15PA(val) BSP_FLD32(val,0, 2)
349
#define TMS570_DMA_PAR1_CH15PA_GET(reg) BSP_FLD32GET(reg,0, 2)
350
#define TMS570_DMA_PAR1_CH15PA_SET(reg,val) BSP_FLD32SET(reg, val,0, 2)
351
352
353
/*---------------------TMS570_DMA_FTCMAP---------------------*/
354
/* field: FTCAB - Frame transfer complete (FTC) interrupt to Group A or Group B. */
355
#define TMS570_DMA_FTCMAP_FTCAB(val) BSP_FLD32(val,0, 15)
356
#define TMS570_DMA_FTCMAP_FTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
357
#define TMS570_DMA_FTCMAP_FTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
358
359
360
/*---------------------TMS570_DMA_LFSMAP---------------------*/
361
/* field: LFSAB - Last frame started (LFS) interrupt to Group A or Group B. */
362
#define TMS570_DMA_LFSMAP_LFSAB(val) BSP_FLD32(val,0, 15)
363
#define TMS570_DMA_LFSMAP_LFSAB_GET(reg) BSP_FLD32GET(reg,0, 15)
364
#define TMS570_DMA_LFSMAP_LFSAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
365
366
367
/*---------------------TMS570_DMA_HBCMAP---------------------*/
368
/* field: HBCAB - Half block complete (HBC) interrupt to Group A or Group B. */
369
#define TMS570_DMA_HBCMAP_HBCAB(val) BSP_FLD32(val,0, 15)
370
#define TMS570_DMA_HBCMAP_HBCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
371
#define TMS570_DMA_HBCMAP_HBCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
372
373
374
/*---------------------TMS570_DMA_BTCMAP---------------------*/
375
/* field: BTCAB - Block transfer complete (BTC) interrupt to Group A or Group B */
376
#define TMS570_DMA_BTCMAP_BTCAB(val) BSP_FLD32(val,0, 15)
377
#define TMS570_DMA_BTCMAP_BTCAB_GET(reg) BSP_FLD32GET(reg,0, 15)
378
#define TMS570_DMA_BTCMAP_BTCAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
379
380
381
/*---------------------TMS570_DMA_BERMAP---------------------*/
382
/* field: BERAB - Bus error (BER) interrupt to Group A or Group B. */
383
#define TMS570_DMA_BERMAP_BERAB(val) BSP_FLD32(val,0, 15)
384
#define TMS570_DMA_BERMAP_BERAB_GET(reg) BSP_FLD32GET(reg,0, 15)
385
#define TMS570_DMA_BERMAP_BERAB_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
386
387
388
/*-------------------TMS570_DMA_FTCINTENAS-------------------*/
389
/* field: FTCINTENA - Frame transfer complete (FTC) interrupt enable. */
390
#define TMS570_DMA_FTCINTENAS_FTCINTENA(val) BSP_FLD32(val,0, 15)
391
#define TMS570_DMA_FTCINTENAS_FTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
392
#define TMS570_DMA_FTCINTENAS_FTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
393
394
395
/*-------------------TMS570_DMA_FTCINTENAR-------------------*/
396
/* field: FTCINTDIS - Frame transfer complete (FTC) interrupt disable. */
397
#define TMS570_DMA_FTCINTENAR_FTCINTDIS(val) BSP_FLD32(val,0, 15)
398
#define TMS570_DMA_FTCINTENAR_FTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
399
#define TMS570_DMA_FTCINTENAR_FTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
400
401
402
/*-------------------TMS570_DMA_LFSINTENAS-------------------*/
403
/* field: LFSINTENA - Last frame started (LFS) interrupt enable. */
404
#define TMS570_DMA_LFSINTENAS_LFSINTENA(val) BSP_FLD32(val,0, 15)
405
#define TMS570_DMA_LFSINTENAS_LFSINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
406
#define TMS570_DMA_LFSINTENAS_LFSINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
407
408
409
/*-------------------TMS570_DMA_LFSINTENAR-------------------*/
410
/* field: LFSINTDIS - Last frame started (LFS) interrupt disable. */
411
#define TMS570_DMA_LFSINTENAR_LFSINTDIS(val) BSP_FLD32(val,0, 15)
412
#define TMS570_DMA_LFSINTENAR_LFSINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
413
#define TMS570_DMA_LFSINTENAR_LFSINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
414
415
416
/*-------------------TMS570_DMA_HBCINTENAS-------------------*/
417
/* field: HBCINTENA - Half block complete (HBC) interrupt enable. */
418
#define TMS570_DMA_HBCINTENAS_HBCINTENA(val) BSP_FLD32(val,0, 15)
419
#define TMS570_DMA_HBCINTENAS_HBCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
420
#define TMS570_DMA_HBCINTENAS_HBCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
421
422
423
/*-------------------TMS570_DMA_HBCINTENAR-------------------*/
424
/* field: HBCINTDIS - Half block complete (HBC) interrupt disable. */
425
#define TMS570_DMA_HBCINTENAR_HBCINTDIS(val) BSP_FLD32(val,0, 15)
426
#define TMS570_DMA_HBCINTENAR_HBCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
427
#define TMS570_DMA_HBCINTENAR_HBCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
428
429
430
/*-------------------TMS570_DMA_BTCINTENAS-------------------*/
431
/* field: BTCINTENA - Block transfer complete (BTC) interrupt enable. */
432
#define TMS570_DMA_BTCINTENAS_BTCINTENA(val) BSP_FLD32(val,0, 15)
433
#define TMS570_DMA_BTCINTENAS_BTCINTENA_GET(reg) BSP_FLD32GET(reg,0, 15)
434
#define TMS570_DMA_BTCINTENAS_BTCINTENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
435
436
437
/*-------------------TMS570_DMA_BTCINTENAR-------------------*/
438
/* field: BTCINTDIS - Block transfer complete (BTC) interurpt disable. */
439
#define TMS570_DMA_BTCINTENAR_BTCINTDIS(val) BSP_FLD32(val,0, 15)
440
#define TMS570_DMA_BTCINTENAR_BTCINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15)
441
#define TMS570_DMA_BTCINTENAR_BTCINTDIS_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
442
443
444
/*--------------------TMS570_DMA_GINTFLAG--------------------*/
445
/* field: GINT - Global interrupt flags. */
446
#define TMS570_DMA_GINTFLAG_GINT(val) BSP_FLD32(val,0, 15)
447
#define TMS570_DMA_GINTFLAG_GINT_GET(reg) BSP_FLD32GET(reg,0, 15)
448
#define TMS570_DMA_GINTFLAG_GINT_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
449
450
451
/*---------------------TMS570_DMA_FTCFLAG---------------------*/
452
/* field: FTCI - Frame transfer complete (FTC) flags. */
453
#define TMS570_DMA_FTCFLAG_FTCI(val) BSP_FLD32(val,0, 15)
454
#define TMS570_DMA_FTCFLAG_FTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
455
#define TMS570_DMA_FTCFLAG_FTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
456
457
458
/*---------------------TMS570_DMA_LFSFLAG---------------------*/
459
/* field: LFSI - Last frame started (LFS) flags. */
460
#define TMS570_DMA_LFSFLAG_LFSI(val) BSP_FLD32(val,0, 15)
461
#define TMS570_DMA_LFSFLAG_LFSI_GET(reg) BSP_FLD32GET(reg,0, 15)
462
#define TMS570_DMA_LFSFLAG_LFSI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
463
464
465
/*---------------------TMS570_DMA_HBCFLAG---------------------*/
466
/* field: HBCI - Half block transfer (HBC) complete flags. */
467
#define TMS570_DMA_HBCFLAG_HBCI(val) BSP_FLD32(val,0, 15)
468
#define TMS570_DMA_HBCFLAG_HBCI_GET(reg) BSP_FLD32GET(reg,0, 15)
469
#define TMS570_DMA_HBCFLAG_HBCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
470
471
472
/*---------------------TMS570_DMA_BTCFLAG---------------------*/
473
/* field: BTCI - Block transfer complete (BTC) flags. */
474
#define TMS570_DMA_BTCFLAG_BTCI(val) BSP_FLD32(val,0, 15)
475
#define TMS570_DMA_BTCFLAG_BTCI_GET(reg) BSP_FLD32GET(reg,0, 15)
476
#define TMS570_DMA_BTCFLAG_BTCI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
477
478
479
/*---------------------TMS570_DMA_BERFLAG---------------------*/
480
/* field: BERI - Bus error (BER) flags. */
481
#define TMS570_DMA_BERFLAG_BERI(val) BSP_FLD32(val,0, 15)
482
#define TMS570_DMA_BERFLAG_BERI_GET(reg) BSP_FLD32GET(reg,0, 15)
483
#define TMS570_DMA_BERFLAG_BERI_SET(reg,val) BSP_FLD32SET(reg, val,0, 15)
484
485
486
/*-------------------TMS570_DMA_FTCAOFFSET-------------------*/
487
/* field: sbz - These bits should always be programmed as zero. */
488
#define TMS570_DMA_FTCAOFFSET_sbz(val) BSP_FLD32(val,6, 7)
489
#define TMS570_DMA_FTCAOFFSET_sbz_GET(reg) BSP_FLD32GET(reg,6, 7)
490
#define TMS570_DMA_FTCAOFFSET_sbz_SET(reg,val) BSP_FLD32SET(reg, val,6, 7)
491
492
/* field: FTCA - Channel causing FTC interrupt Group A. */
493
#define TMS570_DMA_FTCAOFFSET_FTCA(val) BSP_FLD32(val,0, 5)
494
#define TMS570_DMA_FTCAOFFSET_FTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
495
#define TMS570_DMA_FTCAOFFSET_FTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
496
497
498
/*-------------------TMS570_DMA_LFSAOFFSET-------------------*/
499
/* field: LFSA - Channel causing LFS interrupt Group A. */
500
#define TMS570_DMA_LFSAOFFSET_LFSA(val) BSP_FLD32(val,0, 5)
501
#define TMS570_DMA_LFSAOFFSET_LFSA_GET(reg) BSP_FLD32GET(reg,0, 5)
502
#define TMS570_DMA_LFSAOFFSET_LFSA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
503
504
505
/*-------------------TMS570_DMA_HBCAOFFSET-------------------*/
506
/* field: HBCA - Channel causing HBC interrupt Group A. */
507
#define TMS570_DMA_HBCAOFFSET_HBCA(val) BSP_FLD32(val,0, 5)
508
#define TMS570_DMA_HBCAOFFSET_HBCA_GET(reg) BSP_FLD32GET(reg,0, 5)
509
#define TMS570_DMA_HBCAOFFSET_HBCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
510
511
512
/*-------------------TMS570_DMA_BTCAOFFSET-------------------*/
513
/* field: BTCA - Channel causing BTC interrupt Group A. */
514
#define TMS570_DMA_BTCAOFFSET_BTCA(val) BSP_FLD32(val,0, 5)
515
#define TMS570_DMA_BTCAOFFSET_BTCA_GET(reg) BSP_FLD32GET(reg,0, 5)
516
#define TMS570_DMA_BTCAOFFSET_BTCA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
517
518
519
/*-------------------TMS570_DMA_BERAOFFSET-------------------*/
520
/* field: BERA - Channel causing BER interrupt Group A. */
521
#define TMS570_DMA_BERAOFFSET_BERA(val) BSP_FLD32(val,0, 5)
522
#define TMS570_DMA_BERAOFFSET_BERA_GET(reg) BSP_FLD32GET(reg,0, 5)
523
#define TMS570_DMA_BERAOFFSET_BERA_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
524
525
526
/*-------------------TMS570_DMA_FTCBOFFSET-------------------*/
527
/* field: FTCB - Channel causing FTC interrupt Group B. */
528
#define TMS570_DMA_FTCBOFFSET_FTCB(val) BSP_FLD32(val,0, 5)
529
#define TMS570_DMA_FTCBOFFSET_FTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
530
#define TMS570_DMA_FTCBOFFSET_FTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
531
532
533
/*-------------------TMS570_DMA_LFSBOFFSET-------------------*/
534
/* field: LFSB - Channel causing LFS interrupt Group B. */
535
#define TMS570_DMA_LFSBOFFSET_LFSB(val) BSP_FLD32(val,0, 5)
536
#define TMS570_DMA_LFSBOFFSET_LFSB_GET(reg) BSP_FLD32GET(reg,0, 5)
537
#define TMS570_DMA_LFSBOFFSET_LFSB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
538
539
540
/*-------------------TMS570_DMA_HBCBOFFSET-------------------*/
541
/* field: HBCB - Channel causing HBC interrupt Group B. */
542
#define TMS570_DMA_HBCBOFFSET_HBCB(val) BSP_FLD32(val,0, 5)
543
#define TMS570_DMA_HBCBOFFSET_HBCB_GET(reg) BSP_FLD32GET(reg,0, 5)
544
#define TMS570_DMA_HBCBOFFSET_HBCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
545
546
547
/*-------------------TMS570_DMA_BTCBOFFSET-------------------*/
548
/* field: BTCB - interrupt for Group B if the corresponding interrupt enable is set. */
549
#define TMS570_DMA_BTCBOFFSET_BTCB(val) BSP_FLD32(val,0, 5)
550
#define TMS570_DMA_BTCBOFFSET_BTCB_GET(reg) BSP_FLD32GET(reg,0, 5)
551
#define TMS570_DMA_BTCBOFFSET_BTCB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
552
553
554
/*-------------------TMS570_DMA_BERBOFFSET-------------------*/
555
/* field: BERB - Channel causing BER interrupt Group B. */
556
#define TMS570_DMA_BERBOFFSET_BERB(val) BSP_FLD32(val,0, 5)
557
#define TMS570_DMA_BERBOFFSET_BERB_GET(reg) BSP_FLD32GET(reg,0, 5)
558
#define TMS570_DMA_BERBOFFSET_BERB_SET(reg,val) BSP_FLD32SET(reg, val,0, 5)
559
560
561
/*----------------------TMS570_DMA_PTCRL----------------------*/
562
/* field: PENDB - Transfers pending for Port B. This flag determines if transfers are ongoing on port B. */
563
#define TMS570_DMA_PTCRL_PENDB BSP_BIT32(24)
564
565
/* field: BYB - Bypass FIFO B. */
566
#define TMS570_DMA_PTCRL_BYB BSP_BIT32(18)
567
568
/* field: PSFRHQPB - Priority scheme fix or rotate for high priority queue of Port B. */
569
#define TMS570_DMA_PTCRL_PSFRHQPB BSP_BIT32(17)
570
571
/* field: PSFRLQPB - Priority scheme fix or rotate for low priority queue of Port B. */
572
#define TMS570_DMA_PTCRL_PSFRLQPB BSP_BIT32(16)
573
574
575
/*---------------------TMS570_DMA_RTCTRL---------------------*/
576
/* field: RTC - RAM Test Control. */
577
#define TMS570_DMA_RTCTRL_RTC BSP_BIT32(0)
578
579
580
/*----------------------TMS570_DMA_DCTRL----------------------*/
581
/* field: CHNUM - Channel Number. */
582
#define TMS570_DMA_DCTRL_CHNUM(val) BSP_FLD32(val,24, 28)
583
#define TMS570_DMA_DCTRL_CHNUM_GET(reg) BSP_FLD32GET(reg,24, 28)
584
#define TMS570_DMA_DCTRL_CHNUM_SET(reg,val) BSP_FLD32SET(reg, val,24, 28)
585
586
/* field: DMADBGS - DMA debug status. */
587
#define TMS570_DMA_DCTRL_DMADBGS BSP_BIT32(16)
588
589
/* field: DBGEN - Debug Enable. */
590
#define TMS570_DMA_DCTRL_DBGEN BSP_BIT32(0)
591
592
593
/*-----------------------TMS570_DMA_WPR-----------------------*/
594
/* field: WP - Watch point. */
595
/* Whole 32 bits */
596
597
/*-----------------------TMS570_DMA_WMR-----------------------*/
598
/* field: WM - Watch mask. */
599
/* Whole 32 bits */
600
601
/*--------------------TMS570_DMA_PBACSADDR--------------------*/
602
/* field: PBACSA - Port B Active Channel Source Address. */
603
/* Whole 32 bits */
604
605
/*--------------------TMS570_DMA_PBACDADDR--------------------*/
606
/* field: PBACDA - address of the active channel as broadcasted in Section 16.3.1.3 for Port B. */
607
/* Whole 32 bits */
608
609
/*---------------------TMS570_DMA_PBACTC---------------------*/
610
/* field: PBFTCOUNT - Port B active channel frame count. */
611
#define TMS570_DMA_PBACTC_PBFTCOUNT(val) BSP_FLD32(val,16, 28)
612
#define TMS570_DMA_PBACTC_PBFTCOUNT_GET(reg) BSP_FLD32GET(reg,16, 28)
613
#define TMS570_DMA_PBACTC_PBFTCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,16, 28)
614
615
/* field: PBETCOUNT - Port B active channel element count. */
616
#define TMS570_DMA_PBACTC_PBETCOUNT(val) BSP_FLD32(val,0, 12)
617
#define TMS570_DMA_PBACTC_PBETCOUNT_GET(reg) BSP_FLD32GET(reg,0, 12)
618
#define TMS570_DMA_PBACTC_PBETCOUNT_SET(reg,val) BSP_FLD32SET(reg, val,0, 12)
619
620
621
/*---------------------TMS570_DMA_DMAPCR---------------------*/
622
/* field: ERRA - Error action. */
623
#define TMS570_DMA_DMAPCR_ERRA BSP_BIT32(16)
624
625
/* field: TEST - When this bit is set, the parity bits are memory mapped to make them accessible by the CPU. */
626
#define TMS570_DMA_DMAPCR_TEST BSP_BIT32(8)
627
628
/* field: PARITY_ENA - Parity error detection enable. */
629
#define TMS570_DMA_DMAPCR_PARITY_ENA(val) BSP_FLD32(val,0, 3)
630
#define TMS570_DMA_DMAPCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3)
631
#define TMS570_DMA_DMAPCR_PARITY_ENA_SET(reg,val) BSP_FLD32SET(reg, val,0, 3)
632
633
634
/*---------------------TMS570_DMA_DMAPAR---------------------*/
635
/* field: EDFLAG - Parity Error Detection Flag. */
636
#define TMS570_DMA_DMAPAR_EDFLAG BSP_BIT32(24)
637
638
/* field: ERRORADDRESS - Error address. These bits hold the address of the first parity error generated in the RAM. */
639
#define TMS570_DMA_DMAPAR_ERRORADDRESS(val) BSP_FLD32(val,0, 11)
640
#define TMS570_DMA_DMAPAR_ERRORADDRESS_GET(reg) BSP_FLD32GET(reg,0, 11)
641
#define TMS570_DMA_DMAPAR_ERRORADDRESS_SET(reg,val) BSP_FLD32SET(reg, val,0, 11)
642
643
644
/*--------------------TMS570_DMA_DMAMPCTRL--------------------*/
645
/* field: INT3AB - Interrupt assignment of region 3 to Group A or Group B. */
646
#define TMS570_DMA_DMAMPCTRL_INT3AB BSP_BIT32(28)
647
648
/* field: INT3ENA - Interrupt enable of region 3. */
649
#define TMS570_DMA_DMAMPCTRL_INT3ENA BSP_BIT32(27)
650
651
/* field: REG3AP - Region 3 access permission. */
652
#define TMS570_DMA_DMAMPCTRL_REG3AP(val) BSP_FLD32(val,25, 26)
653
#define TMS570_DMA_DMAMPCTRL_REG3AP_GET(reg) BSP_FLD32GET(reg,25, 26)
654
#define TMS570_DMA_DMAMPCTRL_REG3AP_SET(reg,val) BSP_FLD32SET(reg, val,25, 26)
655
656
/* field: REG3ENA - Region 3 enable. */
657
#define TMS570_DMA_DMAMPCTRL_REG3ENA BSP_BIT32(24)
658
659
/* field: INT2AB - Interrupt assignment of region 2 to Group A or Group B. */
660
#define TMS570_DMA_DMAMPCTRL_INT2AB BSP_BIT32(20)
661
662
/* field: INT2ENA - Interrupt enable of region 2. */
663
#define TMS570_DMA_DMAMPCTRL_INT2ENA BSP_BIT32(19)
664
665
/* field: REG2AP - Region 2 access permission. These bits determine the access permission for region 2. */
666
#define TMS570_DMA_DMAMPCTRL_REG2AP(val) BSP_FLD32(val,17, 18)
667
#define TMS570_DMA_DMAMPCTRL_REG2AP_GET(reg) BSP_FLD32GET(reg,17, 18)
668
#define TMS570_DMA_DMAMPCTRL_REG2AP_SET(reg,val) BSP_FLD32SET(reg, val,17, 18)
669
670
/* field: REG2ENA - Region 2 enable. */
671
#define TMS570_DMA_DMAMPCTRL_REG2ENA BSP_BIT32(16)
672
673
/* field: INT1AB - Interrupt assignment of region 1 to Group A or Group B. */
674
#define TMS570_DMA_DMAMPCTRL_INT1AB BSP_BIT32(12)
675
676
/* field: INT1ENA - Interrupt enable of region 1. */
677
#define TMS570_DMA_DMAMPCTRL_INT1ENA BSP_BIT32(11)
678
679
/* field: REG1AP - Region 1 access permission. */
680
#define TMS570_DMA_DMAMPCTRL_REG1AP(val) BSP_FLD32(val,9, 10)
681
#define TMS570_DMA_DMAMPCTRL_REG1AP_GET(reg) BSP_FLD32GET(reg,9, 10)
682
#define TMS570_DMA_DMAMPCTRL_REG1AP_SET(reg,val) BSP_FLD32SET(reg, val,9, 10)
683
684
/* field: REG1ENA - Region 1 enable. */
685
#define TMS570_DMA_DMAMPCTRL_REG1ENA BSP_BIT32(8)
686
687
/* field: INT0AB - Interrupt assignment of region 0 to Group A or Group B. */
688
#define TMS570_DMA_DMAMPCTRL_INT0AB BSP_BIT32(4)
689
690
/* field: INT0ENA - Interrupt enable of region 0. */
691
#define TMS570_DMA_DMAMPCTRL_INT0ENA BSP_BIT32(3)
692
693
/* field: REG0AP - Region 0 access permission. These bits determine the access permission for region 0. */
694
#define TMS570_DMA_DMAMPCTRL_REG0AP(val) BSP_FLD32(val,1, 2)
695
#define TMS570_DMA_DMAMPCTRL_REG0AP_GET(reg) BSP_FLD32GET(reg,1, 2)
696
#define TMS570_DMA_DMAMPCTRL_REG0AP_SET(reg,val) BSP_FLD32SET(reg, val,1, 2)
697
698
/* field: REG0ENA - Region 0 enable. */
699
#define TMS570_DMA_DMAMPCTRL_REG0ENA BSP_BIT32(0)
700
701
702
/*---------------------TMS570_DMA_DMAMPST---------------------*/
703
/* field: REG3FT - Region 3 fault. */
704
#define TMS570_DMA_DMAMPST_REG3FT BSP_BIT32(24)
705
706
/* field: REG2FT - Region 2 fault. */
707
#define TMS570_DMA_DMAMPST_REG2FT BSP_BIT32(16)
708
709
/* field: REG1FT - Region 1 fault. */
710
#define TMS570_DMA_DMAMPST_REG1FT BSP_BIT32(8)
711
712
/* field: REG0FT - Region 0 fault. */
713
#define TMS570_DMA_DMAMPST_REG0FT BSP_BIT32(0)
714
715
716
/*--------------------TMS570_DMA_DMAMPROS--------------------*/
717
718
/* Whole 32 bits */
719
720
721
#endif
/* LIBBSP_ARM_TMS570_DMA */
utility.h
This header file provides utility macros for BSPs.
tms570_dma_t
Definition:
reg_dma.h:59
Definition:
reg_dma.h:54
