RTEMS 6.1-rc5
This header file provides the Partition Manager API. More...
#include <stddef.h>
#include <stdint.h>
#include <rtems/rtems/attr.h>
#include <rtems/score/cpu.h>
#define | RTEMS_PARTITION_ALIGNMENT CPU_SIZEOF_POINTER |
This constant defines the minimum alignment of a partition buffer in bytes. | |
rtems_status_code | rtems_partition_create (rtems_name name, void *starting_address, uintptr_t length, size_t buffer_size, rtems_attribute attribute_set, rtems_id *id) |
Creates a partition. | |
rtems_status_code | rtems_partition_ident (rtems_name name, uint32_t node, rtems_id *id) |
Identifies a partition by the object name. | |
rtems_status_code | rtems_partition_delete (rtems_id id) |
Deletes the partition. | |
rtems_status_code | rtems_partition_get_buffer (rtems_id id, void **buffer) |
Tries to get a buffer from the partition. | |
rtems_status_code | rtems_partition_return_buffer (rtems_id id, void *buffer) |
Returns the buffer to the partition. | |
