RTEMS 6.1-rc5
37#ifndef _RTEMS_CONFDEFS_OBSOLETE_H
38#define _RTEMS_CONFDEFS_OBSOLETE_H
40#ifndef __CONFIGURATION_TEMPLATE_h
41#error "Do not include this file directly, use <rtems/confdefs.h> instead"
61#ifdef CONFIGURE_BDBUF_BUFFER_SIZE
62 #error "The CONFIGURE_BDBUF_BUFFER_SIZE configuration option is obsolete since RTEMS 4.10.0"
65#ifdef CONFIGURE_BDBUF_BUFFER_COUNT
66 #error "The CONFIGURE_BDBUF_BUFFER_COUNT configuration option is obsolete since RTEMS 4.10.0"
69#ifdef CONFIGURE_MAXIMUM_DEVICES
70 #warning "The CONFIGURE_MAXIMUM_DEVICES configuration option is obsolete since RTEMS 5.1"
73#ifdef CONFIGURE_ENABLE_GO
74 #warning "The CONFIGURE_ENABLE_GO configuration option is obsolete since RTEMS 5.1"
77#ifdef CONFIGURE_GNAT_RTEMS
78 #warning "The CONFIGURE_GNAT_RTEMS configuration option is obsolete since RTEMS 5.1"
81#ifdef CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
82 #error "The CONFIGURE_HAS_OWN_CONFIGURATION_TABLE configuration option is obsolete since RTEMS 5.1"
85#ifdef CONFIGURE_HAS_OWN_BDBUF_TABLE
86 #error "The CONFIGURE_HAS_BDBUF_TABLE configuration option is obsolete since RTEMS 4.10.0"
89#ifdef CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE
90 #error "The CONFIGURE_HAS_OWN_DEVICE_DRIVER_TABLE configuration option is obsolete since RTEMS 5.1"
93#ifdef CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
94 #error "The CONFIGURE_HAS_OWN_FILESYSTEM_TABLE configuration option is obsolete since RTEMS 5.1"
97#ifdef CONFIGURE_HAS_OWN_INIT_TABLE
98 #error "The CONFIGURE_HAS_OWN_INIT_TABLE configuration option is obsolete since RTEMS 5.1"
101#ifdef CONFIGURE_HAS_OWN_MOUNT_TABLE
102 #error "The CONFIGURE_HAS_OWN_MOUNT_TABLE configuration option is obsolete since RTEMS 5.1"
105#ifdef CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE
106 #error "The CONFIGURE_HAS_OWN_MULTIPROCESSING_TABLE configuration option is obsolete since RTEMS 5.1"
109#ifdef CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
110 #warning "CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS has been renamed to CONFIGURE_MAXIMUM_FILE_DESCRIPTORS since RTEMS 5.1"
111 #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS
114#ifdef CONFIGURE_MAXIMUM_ADA_TASKS
115 #warning "The CONFIGURE_MAXIMUM_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
118#ifdef CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
119 #warning "The CONFIGURE_MAXIMUM_FAKE_ADA_TASKS configuration option is obsolete since RTEMS 5.1"
122#ifdef CONFIGURE_MAXIMUM_FIFOS
123 #warning "CONFIGURE_MAXIMUM_FIFOS is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
124 #if CONFIGURE_MAXIMUM_FIFOS > 0
125 #define CONFIGURE_IMFS_ENABLE_MKFIFO
129#ifdef CONFIGURE_MAXIMUM_GOROUTINES
130 #warning "The CONFIGURE_MAXIMUM_GOROUTINES configuration option is obsolete since RTEMS 5.1"
133#ifdef CONFIGURE_MAXIMUM_GO_CHANNELS
134 #warning "The CONFIGURE_MAXIMUM_GO_CHANNELS configuration option is obsolete since RTEMS 5.1"
137#ifdef CONFIGURE_MAXIMUM_MRSP_SEMAPHORES
138 #warning "The CONFIGURE_MAXIMUM_MRSP_SEMAPHORES configuration option is obsolete since RTEMS 5.1"
141#ifdef CONFIGURE_MAXIMUM_PIPES
142 #warning "CONFIGURE_MAXIMUM_PIPES is obsolete since RTEMS 5.1; use CONFIGURE_IMFS_ENABLE_MKFIFO instead"
143 #if CONFIGURE_MAXIMUM_PIPES > 0
144 #define CONFIGURE_IMFS_ENABLE_MKFIFO
148#ifdef CONFIGURE_MAXIMUM_POSIX_BARRIERS
149 #warning "The CONFIGURE_MAXIMUM_POSIX_BARRIERS configuration option is obsolete since RTEMS 5.1"
152#ifdef CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES
153 #warning "The CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES configuration option is obsolete since RTEMS 5.1"
156#ifdef CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS
157 #warning "The CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUE_DESCRIPTORS configuration option is obsolete since RTEMS 5.1"
160#ifdef CONFIGURE_MAXIMUM_POSIX_MUTEXES
161 #warning "The CONFIGURE_MAXIMUM_POSIX_MUTEXES configuration option is obsolete since RTEMS 5.1"
164#ifdef CONFIGURE_MAXIMUM_POSIX_RWLOCKS
165 #warning "The CONFIGURE_MAXIMUM_POSIX_RWLOCKS configuration option is obsolete since RTEMS 5.1"
168#ifdef CONFIGURE_MAXIMUM_POSIX_SPINLOCKS
169 #warning "The CONFIGURE_MAXIMUM_POSIX_SPINLOCKS configuration option is obsolete since RTEMS 5.1"
172#ifdef CONFIGURE_MAXIMUM_PTYS
173 #warning "The CONFIGURE_MAXIMUM_PTYS configuration option is obsolete since RTEMS 5.1"
176#ifdef CONFIGURE_NUMBER_OF_TERMIOS_PORTS
177 #warning "The CONFIGURE_NUMBER_OF_TERMIOS_PORTS configuration option is obsolete since RTEMS 5.1"
180#ifdef CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
181 #error "The CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE configuration option is obsolete since RTEMS 5.1"
184#ifdef CONFIGURE_SCHEDULER_CONTEXT
185 #warning "CONFIGURE_SCHEDULER_CONTEXT has been renamed to CONFIGURE_SCHEDULER since RTEMS 5.1"
186 #define CONFIGURE_SCHEDULER CONFIGURE_SCHEDULER_CONTEXT
189#ifdef CONFIGURE_SCHEDULER_CONTROLS
190 #warning "CONFIGURE_SCHEDULER_CONTROLS has been renamed to CONFIGURE_SCHEDULER_TABLE_ENTRIES since RTEMS 5.1"
191 #define CONFIGURE_SCHEDULER_TABLE_ENTRIES CONFIGURE_SCHEDULER_CONTROLS
194#ifdef CONFIGURE_SMP_APPLICATION
195 #warning "CONFIGURE_SMP_APPLICATION is obsolete since RTEMS 5.1"
198#ifdef CONFIGURE_SMP_MAXIMUM_PROCESSORS
199 #warning "CONFIGURE_SMP_MAXIMUM_PROCESSORS has been renamed to CONFIGURE_MAXIMUM_PROCESSORS since RTEMS 5.1"
200 #define CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_SMP_MAXIMUM_PROCESSORS
203#ifdef CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
204 #warning "CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS has been renamed to CONFIGURE_SCHEDULER_ASSIGNMENTS since RTEMS 5.1"
205 #define CONFIGURE_SCHEDULER_ASSIGNMENTS CONFIGURE_SMP_SCHEDULER_ASSIGNMENTS
208#ifdef CONFIGURE_TERMIOS_DISABLED
209 #warning "The CONFIGURE_TERMIOS_DISABLED configuration option is obsolete since RTEMS 5.1"
212#ifdef CONFIGURE_TEST_NEEDS_CLOCK_DRIVER
213 #error "The CONFIGURE_TEST_NEEDS_CLOCK_DRIVER configuration option is obsolete since at least RTEMS 4.5.0"
216#ifdef CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER
217 #error "The CONFIGURE_TEST_NEEDS_CONSOLE_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
220#ifdef CONFIGURE_TEST_NEEDS_RTC_DRIVER
221 #error "The CONFIGURE_TEST_NEEDS_RTC_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
224#ifdef CONFIGURE_TEST_NEEDS_STUB_DRIVER
225 #error "The CONFIGURE_TEST_NEEDS_STUB_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
228#ifdef CONFIGURE_TEST_NEEDS_TIMER_DRIVER
229 #error "The CONFIGURE_TEST_NEEDS_TIMER_DRIVER configuration option is obsolete at least RTEMS 4.5.0"
232#ifdef STACK_CHECKER_ON
233 #warning "STACK_CHECKER_ON has been renamed to CONFIGURE_STACK_CHECKER_ENABLED since RTEMS 4.10.0"
234 #define CONFIGURE_STACK_CHECKER_ENABLED
