RTEMS 6.1-rc5
Standard MIPS register names. More...
#define | PHYS_TO_K1(a) ((unsigned)(a) | K1BASE) |
Standard MIPS register names: | |
#define | zero $0 |
#define | z0 $0 |
#define | v0 $2 |
#define | v1 $3 |
#define | a0 $4 |
#define | a1 $5 |
#define | a2 $6 |
#define | a3 $7 |
#define | t0 $8 |
#define | t1 $9 |
#define | t2 $10 |
#define | t3 $11 |
#define | t4 $12 |
#define | t5 $13 |
#define | t6 $14 |
#define | t7 $15 |
#define | s0 $16 |
#define | s1 $17 |
#define | s2 $18 |
#define | s3 $19 |
#define | s4 $20 |
#define | s5 $21 |
#define | s6 $22 |
#define | s7 $23 |
#define | t8 $24 |
#define | t9 $25 |
#define | k0 $26 |
kernel private register 0 */ | |
#define | k1 $27 |
kernel private register 1 */ | |
#define | gp $28 |
global data pointer */ | |
#define | sp $29 |
stack-pointer */ | |
#define | fp $30 |
frame-pointer */ | |
#define | ra $31 |
return address */ | |
#define | pc $pc |
pc, used on mips16 */ | |
#define | fp0 $f0 |
#define | fp1 $f1 |
Useful memory constants: | |
#define | K0BASE 0x80000000 |
#define | K1BASE 0xA0000000 |
Standard Co-Processor 0 register numbers: | |
#define | C0_COUNT $9 |
Count Register */. | |
#define | C0_SR $12 |
Status Register */. | |
#define | C0_CAUSE $13 |
last exception description */ | |
#define | C0_EPC $14 |
Exception error address */. | |
#define | C0_CONFIG $16 |
CPU configuration */. | |
Standard Status Register bitmasks: | |
#define | SR_CU1 0x20000000 |
Mark CP1 as usable */. | |
#define | SR_FR 0x04000000 |
Enable MIPS III FP registers */. | |
#define | SR_BEV 0x00400000 |
Controls location of exception vectors */. | |
#define | SR_PE 0x00100000 |
Mark soft reset (clear parity error) */. | |
#define | SR_KX 0x00000080 |
Kernel extended addressing enabled */. | |
#define | SR_SX 0x00000040 |
Supervisor extended addressing enabled */. | |
#define | SR_UX 0x00000020 |
User extended addressing enabled */. | |
Standard (R4000) cache operations. | |
Taken from "MIPS R4000 Microprocessor User's Manual" 2nd edition: | |
#define | CACHE_I (0) |
primary instruction */ | |
#define | CACHE_D (1) |
primary data */ | |
#define | CACHE_SI (2) |
secondary instruction */ | |
#define | CACHE_SD (3) |
secondary data (or combined instruction/data) */ | |
#define | INDEX_INVALIDATE (0) |
also encodes WRITEBACK if CACHE_D or CACHE_SD */ | |
#define | INDEX_LOAD_TAG (1) |
#define | INDEX_STORE_TAG (2) |
#define | CREATE_DIRTY_EXCLUSIVE (3) |
CACHE_D and CACHE_SD only */. | |
#define | HIT_INVALIDATE (4) |
#define | CACHE_FILL (5) |
CACHE_I only */. | |
#define | HIT_WRITEBACK_INVALIDATE (5) |
#define | HIT_WRITEBACK (6) |
CACHE_I, CACHE_D and CACHE_SD only */. | |
#define | HIT_SET_VIRTUAL (7) |
CACHE_SI and CACHE_SD only */. | |
#define | BUILD_CACHE_OP(o, c) (((o) << 2) | (c)) |
Individual cache operations: | |
#define | INDEX_INVALIDATE_I BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_I) |
#define | INDEX_WRITEBACK_INVALIDATE_D BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_D) |
#define | INDEX_INVALIDATE_SI BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SI) |
#define | INDEX_WRITEBACK_INVALIDATE_SD BUILD_CACHE_OP(INDEX_INVALIDATE,CACHE_SD) |
#define | INDEX_LOAD_TAG_I BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_I) |
#define | INDEX_LOAD_TAG_D BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_D) |
#define | INDEX_LOAD_TAG_SI BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SI) |
#define | INDEX_LOAD_TAG_SD BUILD_CACHE_OP(INDEX_LOAD_TAG,CACHE_SD) |
#define | INDEX_STORE_TAG_I BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_I) |
#define | INDEX_STORE_TAG_D BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_D) |
#define | INDEX_STORE_TAG_SI BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SI) |
#define | INDEX_STORE_TAG_SD BUILD_CACHE_OP(INDEX_STORE_TAG,CACHE_SD) |
#define | CREATE_DIRTY_EXCLUSIVE_D BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_D) |
#define | CREATE_DIRTY_EXCLUSIVE_SD BUILD_CACHE_OP(CREATE_DIRTY_EXCLUSIVE,CACHE_SD) |
#define | HIT_INVALIDATE_I BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_I) |
#define | HIT_INVALIDATE_D BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_D) |
#define | HIT_INVALIDATE_SI BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SI) |
#define | HIT_INVALIDATE_SD BUILD_CACHE_OP(HIT_INVALIDATE,CACHE_SD) |
#define | CACHE_FILL_I BUILD_CACHE_OP(CACHE_FILL,CACHE_I) |
#define | HIT_WRITEBACK_INVALIDATE_D BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_D) |
#define | HIT_WRITEBACK_INVALIDATE_SD BUILD_CACHE_OP(HIT_WRITEBACK_INVALIDATE,CACHE_SD) |
#define | HIT_WRITEBACK_I BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_I) |
#define | HIT_WRITEBACK_D BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_D) |
#define | HIT_WRITEBACK_SD BUILD_CACHE_OP(HIT_WRITEBACK,CACHE_SD) |
#define | HIT_SET_VIRTUAL_SI BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SI) |
#define | HIT_SET_VIRTUAL_SD BUILD_CACHE_OP(HIT_SET_VIRTUAL,CACHE_SD) |
