RTEMS 6.1-rc5
MVME162
EISCAT Scientific Association. M.Savitski
This material is a part of the MVME162 Board Support Package for the RTEMS executive. Its licensing policies are those of the RTEMS distribution.
Updated by Joel Sherrill (jsher.nosp@m.ril@.nosp@m.redst.nosp@m.one..nosp@m.army..nosp@m.mil) after inclusion in the standard release.
Models
There are three different models of the MVME162 board. There are many variations within each model.
Model Variants
MVME162 MVME162-0xx
MVME162FX MVME162-4xx, MVME162-5xx
MVME162LX MVME162-2xx, MVME162-3xx, MVME162-7xx, MVME162-8xx
All models use either an MC68040 or MC68LC040 (no FPU) processors. The processor used varies by variant as does the speed, the amount and type of memory and the I/O devices (serial, ethernet, SCSI and VME). See the README.models file for details.
Configuring the BSP
The BSP needs to be configured for your specific board. The following files need to be modified.
include/bsp.h Change the MOT_162BUG_VEC_ADDRESS define to start of memory for your board
make/custom/mvme162.cfg If your board has an MC68040 processor
  • change the value of RTEMS_CPU_MODEL
  • remove the -msoft-float flag from CPU_CFLAGS
MVME162FX and DMA on the IP bus
From Eric Vaitl eric@.nosp@m.vias.nosp@m.at.co.nosp@m.m:
If you have any customers that will be using the 162FX, tell them to be careful. The main difference between the 162 and the 162FX is DMA on the IP bus. I spent over a month trying to write a DMA HDLC driver for GreenSprings IP-MP and couldn't get it to work. I talked to some people at GreenSprings, and they agreed that there really is no way to get DMA to work unless you know the size of the packets in advance. Once the IP2 chip DMA controller is given the character count and enabled, it doesn't accept further commands until all of the characters have arrived. The only way to terminate a DMA transfer prematurely is by raising DMAEND* during the last read. None of the IP modules that I know of are currently able to do that. GreenSprings is working on the problem, but nothing is going to available for a few months.
Installation
Nothing unique to the MVME162. It has been incorporated into the standard release.
Port Description
This section describes the initial port effort. There have been additions and modifications to the bsp since this was done. Interestingly, this was the first bsp submitted to the RTEMS project and the submission offer came out of the blue with no prior communication with the author. :)
The port was done using already existing ports to the M68020 boards, DMV152 and MVME136.
The initial host development system was SUN/Solaris 2.3, and the cross-development environment consisted of Free Software Foundation (FSF)'s GNU C compiler (version 2.6), GNU Assembler (version 2.3) and GNU binary utilities binutils version 2.5.2, built with m68k as a target. The recent/latest versions of other GNU programs (flex, make, etc) were also used at the build stage.
In all subdirectories of the RTEMS distribution tree, the directories mvme136 were duplicated as mvme162.
Essential modifications are detailed below:
  • the MVME162-specific hardware registers were described in bsp.h
  • timer and clock routines were made to use the MVME162's Tick Timers 1 and 2, respectively
  • shared memory support was replaced by stubs for the time being
  • console IO was lifted entirely from the DMV152 support code, thanks to the fact that Z8530 SCC used in DMV152 is upwards compatible with the Z85230 SCC of the MVME162. (Only the memory mapping of the SCC registers had to be changed.)
  • symbols in several *.s files were prepended with underscores to comply with the xgcc configuration used (it prepends underscores to all symbols defined in c code)
  • linkcmds file was modified to place the linked code into the memory configured for the board in use
  • bspstart.c was modified as follows:
       monitors_vector_table = (rtems_isr *)0xFFE00000;
    was made to point to the power-up location of MVME162 interrupt vector table.
  • The shutdown is a temporary solution. To exit cleanly, it has to disable all enabled interrupts and restore the board to its power-up status. Presently this is not done satisfactorily, as a result, the board needs a hardware reset from the external VMEbus master or from the front panel to ensure correct operation for subsequent downloads.
Host System
The VMEbus master used to externally control and download the MVME162 is a FORCE CPU-2CE board running Solaris 2.3. A simple program to load s-records and start/reset the MVME162 was written. The code is in the file tools/sload.c
This code depends on the external VMEbus master's vme driver and is provided as an example, without the Makefile. The bulk of the program which parses the s-records is courtesy of Kym Newbery, (89189.nosp@m.27y@.nosp@m.lux.l.nosp@m.evel.nosp@m.s.uni.nosp@m.sa.e.nosp@m.du.au).
In general, apart from x-gcc, the tools most often used while building RTEMS for MVME162 were: find, grep, diff, and, of course
MVME162 Embedded Controller Programmer's Reference Guide, Motorola, MVME162PG/D1.
Thanks
What's new
  • 28.07.95 BSP adjusted to rtems-3.2.0.
  • Now console driver uses interrupts on receive (ring buffer code lifted with thanks from the IDP BSP next door (../idp))
  • both front-panel serial interfaces are supported
  • serious bug in timer interrupts fixed
  • interrupt test tm27 now supported
| Dr. Mikhail (Misha) Savitski | Voice : +46-980-79162 |
| Software Systems Engineer | Fax : +46-980-79161 |
| EISCAT Svalbard Radar Project | E-mail: mms@eiscathq.irf.se |
| EISCAT Scientific Association |----------- /\_/\ -----------|
| Box 812 S-98128 Kiruna, Sweden | EIS { o o } CAT |
+----------------------------------+-------oQQQ--(>I<)--QQQo-------+
MVME162 Models
There are three different models of the MVME162 board with many variations within each model.
Model Variants
MVME162 MVME162-0xx
All models use either an MC68040 or MC68LC040 (no FPU) processors. The processor used varies by variant as does the speed, the amount and type of memory and the I/O devices (serial, ethernet, SCSI and VME). See the following tables for details.
MVME162 Variants
Source
o MVME162 Embedded Controller User's Manual (MVME162/D2)
Common Configuration
o One EPROM socket o 8Kx8 NVRAM/TOD clock o Two serial ports o 1MB Flash memory o Four MVIP Industry Pack interfaces o One or two DRAM/SRAM mezzanine memory boards
Model Processor Speed DRAM SRAM Other
001 MC68LC040 25MHz 1MB 512KB
002 MC68040 25MHz 1MB 512KB
003 MC68LC040 25MHz 1MB 512KB No VMEbus
010 MC68LC040 25MHz 4MB 512KB
011 MC68LC040 25MHz 4MB 512KB SCSI
012 MC68LC040 25MHz 4MB 512KB Ethernet
013 MC68LC040 25MHz 4MB 512KB Ethernet, SCSI
014 MC68LC040 25MHz 4MB - Ethernet, No VMEbus
020 MC68040 25MHz 4MB 512KB
021 MC68040 25MHz 4MB 512KB SCSI
022 MC68040 25MHz 4MB 512KB Ethernet
023 MC68040 25MHz 4MB 512KB Ethernet, SCSI
026 MC68040 25MHz 4MB - Ethernet, No VMEbus
030 MC68LC040 25MHz 8MB 512KB
031 MC68LC040 25MHz 8MB 512KB SCSI
032 MC68LC040 25MHz 8MB 512KB Ethernet
033 MC68LC040 25MHz 8MB 512KB Ethernet, SCSI
040 MC68040 25MHz 8MB 512KB
041 MC68040 25MHz 8MB 512KB SCSI
042 MC68040 25MHz 8MB 512KB Ethernet
043 MC68040 25MHz 8MB 512KB Ethernet, SCSI
Serial Interface Modules
SIM05 01-W3846B EIA-232-D DTE
SIM06 01-W3865B EIA-232-D DCE
SIM07 01-W3868B EIA-530 DTE
SIM08 01-W3867B EIA-530 DCE
DRAM/SRAM Expansion Memory Boards
MVME162FX Variants
Source
o MVME162FX Data Sheet o MVME162FX Embedded Controller Installation and Use (V162FXA/IH3) o MVME162FX Embedded Controller Programmer's Reference Guide (V162FXA/PG1) o MVME162FX 400/500-Series VME Embedded Controller Installation and Use (V162FXA/IH4) Edition of March 2000\Uffffffff o V162FXA/LT2, November 1995
o One EPROM socket o 8Kx8 NVRAM/TOD clock o Two serial ports o 1MB Flash memory with 162Bug installed o 512KB SRAM with battery backup o Four IndustryPack interfaces o One or two DRAM/SRAM mezzanine memory boards
Uses MC2 Chip, IP2 Chip, 4MB or 12MB mezzanine DRAM board
Model Processor Speed DRAM Other
403
410 MC68LC040 25Mhz 4MB
411 MC68LC040 25Mhz 4MB SCSI
412 MC68LC040 25Mhz 4MB Ethernet
413 MC68LC040 25Mhz 4MB Ethernet, SCSI
420 ?
421 ?
422 ?
423 ?
430 MC68LC040 25Mhz 8MB
431 MC68LC040 25Mhz 8MB SCSI
432 MC68LC040 25Mhz 8MB Ethernet
433 MC68LC040 25Mhz 8MB Ethernet, SCSI
440 ?
441 ?
442 ?
443 ?
450 ?
451 ?
452 ?
453 MC68LC040 25Mhz 16MB Ethernet, SCSI
460 ?
461 ?
462 ?
463 ?
510 MC68040 32MHz 4MB
511 MC68040 32MHz 4MB SCSI
512 MC68040 32MHz 4MB Ethernet
513 MC68040 32MHz 4MB Ethernet, SCSI
520 MC68040 32MHz 8MB
521 MC68040 32MHz 8MB SCSI
522 MC68040 32MHz 8MB Ethernet
523 MC68040 32MHz 8MB Ethernet, SCSI
530 MC68040 32MHz 16MB
531 MC68040 32MHz 16MB SCSI
532 MC68040 32MHz 16MB Ethernet
533 MC68040 32MHz 16MB Ethernet, SCSI
SIM09 01-W3002F EIA-485/422 DTE/DCE
MVME162-502 4MB DRAM
MVME162-503 12MB DRAM
? 2MB SRAM
MVME162LX Variants
Source
o Supplement to MVME162LX Embedded Controller Installation Guide (MVME162LXIG/D1A1) February 1995 o MVME162LX Embedded Controller Data Sheet o MVME162LX 200/300 Series Embedded Controller Programmer's Reference Guide (V162LX2-3A/PG2) o MVME162LX 200/300 Series Embedded Controller Installation and Use (V162LX2-3A/IH3) o MVME162LX 700/800 Series Embedded Controller Installation and Use (V162-7A/IH1) o MVME162LX 700/800 Series Embedded Controller Installation and Use (V162-7A/IH2)
o One EPROM socket o 8Kx8 NVRAM/TOD clock o 4 serial ports EIA-232-D DTE (unless otherwise noted) o 1MB Flash o 2 IP sites (unless otherwise noted)
200 MC68LC040 25MHz 1MB No serial(?)
201 MC68LC040 25MHz 1MB
202 MC68LC040 25MHz 1MB
210 MC68LC040 25MHz 4MB
211 MC68LC040 25MHz 4MB SCSI
212 MC68LC040 25MHz 4MB Ethernet
213 MC68LC040 25MHz 4MB Ethernet, SCSI
216 MC68LC040 25MHz 4MB Ethernet, No VMEbus, No serial(?)
220 MC68040 25MHz 4MB
222 MC68040 25MHz 4MB Ethernet
223 MC68040 25MHz 4MB Ethernet, SCSI
233 MC68LC040 25MHz 4MB ECC
233 MC68LC040 25MHz 4MB ECC Ethernet, SCSI
243 MC68040 25MHz 4MB ECC Ethernet, SCSI
253 MC68LC040 25MHz 16MB ECC Ethernet, SCSI
262 MC68040 25MHz 16MB ECC Ethernet
263 MC68040 25MHz 16MB ECC Ethernet, SCSI
322 MC68LC040 25MHz 8MB ECC Ethernet
323 MC68LC040 25MHz 8MB ECC Ethernet, SCSI
333 MC68040 25MHz 8MB ECC Ethernet, SCSI, No IP sites(?)
353 MC68040 25MHz 32MB ECC Ethernet, SCSI, 4 IP sites
723 MC68040 32MHz 4MB Ethernet, SCSI
743 MC68040 32MHz 4MB ECC Ethernet, SCSI
763 MC68040 32MHz 16MB ECC Ethernet, SCSI
813 MC68040 32MHz 8MB Ethernet, SCSI
833 MC68040 32MHz 8MB ECC Ethernet, SCSI
853 MC68040 32MHz 32MB ECC Ethernet, SCSI
863 MC68040 32MHz 16MB ECC Ethernet, SCSI
DRAM Expansion Memory Boards
MVME162-202 4MB (non-stacking) MVME162-203 16MB ECC (non-stacking) MVME162-204 16MB ECC (stacking) MVME162-207 4MB ECC (non-stakcing) MVME162-208 4MB ECC (stacking) MVME162-209 8MB ECC (non-stacking) MVME162-210 8MB ECC (stacking) MVME162-211 32MB ECC (non-stacking) MVME162-212 32MB ECC (stacking)
