RTEMS 6.1-rc5
milkymist
Full RTEMS port to the Milkymist One. Supports Milkymist SoC 1.0.x.
Includes drivers for:
  • Multi-standard video input (PAL/SECAM/NTSC)
  • Two DMX512 (RS485) ports
  • MIDI IN and MIDI OUT ports
  • VGA output
  • AC'97 audio
  • NOR flash
  • 10/100 Ethernet
  • Memory card (experimental and incomplete)
  • USB host connectors (input devices only, using the softusb-input firmware)
  • RC5 infrared receiver
  • RS232 debug port
For more information: http://www.milkymist.org/
UART
Initialization:
set the CSR_UART_DIVISOR to the correct VALUE,
depending on the internal frequency of the LatticeMico32 softcore.
for the ML401 board, this value is calculated using this formula : clk_frequency/230400/16
clk_frequency  = 100000000 Hz
=> we must set CSR_UART_DIVISOR to 27
How to send a byte to uart :
void writechar(char c)
CSR_UART_RXTX = c;
while(!(irq_pending() & IRQ_UARTTX));
irq_ack(IRQ_UARTTX);
How to receive a byte from uart :
char readchar()
char c;
while(!(irq_pending() & IRQ_UARTRX));
irq_ack(IRQ_UARTRX);
c = CSR_UART_RXTX;
return c;
