RTEMS 6.1-rc5
MC68430 definitions. More...
#define | MBASE 0xEFFFF000 /* Module Base Address */ |
#define | MBAR (*(portb) 0x0003FF00) /* Module Base Addr Reg */ |
#define | MBAR1 (*(portb) 0x0003FF00) /* Module Base Addr Reg 1 (MSW) */ |
#define | MBAR2 (*(portb) 0x0003FF02) /* Module Base Addr Reg 2 (LSW) */ |
#define | SIMMCR (*(portw) (MBASE+0x0000)) /* SIM Module Config Reg */ |
#define | SIMSYNCR (*(portw) (MBASE+0x0004)) /* SIM Clock Synth Cont Reg */ |
#define | SIMAVR (*(portb) (MBASE+0x0006)) /* SIM Autovector Reg */ |
#define | SIMRSR (*(portb) (MBASE+0x0007)) /* SIM Reset Status Reg */ |
#define | SIMPORTA (*(portb) (MBASE+0x0011)) /* SIM Port A Data Reg */ |
#define | SIMDDRA (*(portb) (MBASE+0x0013)) /* SIM Port A Data Dir Reg */ |
#define | SIMPPRA1 (*(portb) (MBASE+0x0015)) /* SIM Port A Pin Asm 1 Reg */ |
#define | SIMPPRA2 (*(portb) (MBASE+0x0017)) /* SIM Port A Pin Asm 2 Reg */ |
#define | SIMPORTB (*(portb) (MBASE+0x0019)) /* SIM Port B Data Reg */ |
#define | SIMPORTB1 (*(portb) (MBASE+0x001B)) /* SIM Port B Data Reg */ |
#define | SIMDDRB (*(portb) (MBASE+0x001D)) /* SIM Port B Data Dir Reg */ |
#define | SIMPPARB (*(portb) (MBASE+0x001F)) /* SIM Port B Pin Asm Reg */ |
#define | SIMSWIV (*(portb) (MBASE+0x0020)) /* SIM SW Interrupt Vector */ |
#define | SIMSYPCR (*(portb) (MBASE+0x0021)) /* SIM System Prot Cont Reg */ |
#define | SIMPICR (*(portw) (MBASE+0x0022)) /* SIM Period Intr Cont Reg */ |
#define | SIMPITR (*(portw) (MBASE+0x0024)) /* SIM Period Intr Tmg Reg */ |
#define | SIMSWSR (*(portb) (MBASE+0x0027)) /* SIM Software Service Reg */ |
#define | SIMCS0AM (*(portl) (MBASE+0x0040)) /* SIM Chp Sel 0 Addr Msk */ |
#define | SIMCS0AM1 (*(portw) (MBASE+0x0040)) /* SIM Chp Sel 0 Addr Msk 1 */ |
#define | SIMCS0AM2 (*(portw) (MBASE+0x0042)) /* SIM Chp Sel 0 Addr Msk 2 */ |
#define | SIMCS0BA (*(portl) (MBASE+0x0044)) /* SIM Chp Sel 0 Base Addr */ |
#define | SIMCS0BA1 (*(portw) (MBASE+0x0044)) /* SIM Chp Sel 0 Bas Addr 1 */ |
#define | SIMCS0BA2 (*(portw) (MBASE+0x0046)) /* SIM Chp Sel 0 Bas Addr 2 */ |
#define | SIMCS1AM (*(portl) (MBASE+0x0048)) /* SIM Chp Sel 1 Adress Msk */ |
#define | SIMCS1AM1 (*(portw) (MBASE+0x0048)) /* SIM Chp Sel 1 Addr Msk 1 */ |
#define | SIMCS1AM2 (*(portw) (MBASE+0x004A)) /* SIM Chp Sel 1 Addr Msk 2 */ |
#define | SIMCS1BA (*(portl) (MBASE+0x004C)) /* SIM Chp Sel 1 Base Addr */ |
#define | SIMCS1BA1 (*(portw) (MBASE+0x004C)) /* SIM Chp Sel 1 Bas Addr 1 */ |
#define | SIMCS1BA2 (*(portw) (MBASE+0x004E)) /* SIM Chp Sel 1 Bas Addr 2 */ |
#define | SIMCS2AM (*(portl) (MBASE+0x0050)) /* SIM Chp Sel 2 Addr Msk */ |
#define | SIMCS2AM1 (*(portw) (MBASE+0x0050)) /* SIM Chp Sel 2 Addr Msk 1 */ |
#define | SIMCS2AM2 (*(portw) (MBASE+0x0052)) /* SIM Chp Sel 2 Addr Msk 2 */ |
#define | SIMCS2BA (*(portl) (MBASE+0x0054)) /* SIM Chp Sel 2 Base Addr */ |
#define | SIMCS2BA1 (*(portw) (MBASE+0x0054)) /* SIM Chp Sel 2 Bas Addr 1 */ |
#define | SIMCS2BA2 (*(portw) (MBASE+0x0056)) /* SIM Chp Sel 2 Bas Addr 2 */ |
#define | SIMCS3AM (*(portl) (MBASE+0x0058)) /* SIM Chp Sel 3 Addr Msk */ |
#define | SIMCS3AM1 (*(portw) (MBASE+0x0058)) /* SIM Chp Sel 3 Addr Msk 1 */ |
#define | SIMCS3AM2 (*(portw) (MBASE+0x005A)) /* SIM Chp Sel 3 Addr Msk 2 */ |
#define | SIMCS3BA (*(portl) (MBASE+0x005C)) /* SIM Chp Sel 3 Base Addr */ |
#define | SIMCS3BA1 (*(portw) (MBASE+0x005C)) /* SIM Chp Sel 3 Bas Addr 1 */ |
#define | SIMCS3BA2 (*(portw) (MBASE+0x005E)) /* SIM Chp Sel 3 Bas Addr 2 */ |
#define | DMAMCR1 (*(portw) (MBASE+0x0780)) /* DMA Module Config Reg 1 */ |
#define | DMAINTR1 (*(portw) (MBASE+0x0784)) /* DMA Interrupt Reg 1 */ |
#define | DMACCR1 (*(portw) (MBASE+0x0788)) /* DMA Channel Cont Reg 1 */ |
#define | DMACSR1 (*(portb) (MBASE+0x078A)) /* DMA Channel Status Reg 1 */ |
#define | DMAFCR1 (*(portb) (MBASE+0x078B)) /* DMA Function Code Reg 1 */ |
#define | DMASAR1 (*(portl) (MBASE+0x078C)) /* DMA DMA Src Addr Reg 1 */ |
#define | DMADAR1 (*(portl) (MBASE+0x0790)) /* DMA Dest Addr Reg 1 */ |
#define | DMABTC1 (*(portb) (MBASE+0x079l)) /* DMA Byte Trans Cnt Reg 1 */ |
#define | DMAMCR2 (*(portw) (MBASE+0x07A0)) /* DMA Module Config Reg 2 */ |
#define | DMAINTR2 (*(portw) (MBASE+0x07A4)) /* DMA Interrupt Reg 2 */ |
#define | DMACCR2 (*(portw) (MBASE+0x07A8)) /* DMA Channel Cont Reg 2 */ |
#define | DMACSR2 (*(portb) (MBASE+0x07AA)) /* DMA Channel Status Reg 2 */ |
#define | DMAFCR2 (*(portb) (MBASE+0x07AB)) /* DMA Function Code Reg 1 */ |
#define | DMASAR2 (*(portl) (MBASE+0x07AC)) /* DMA Source Addr Reg 2 */ |
#define | DMADAR2 (*(portl) (MBASE+0x07B0)) /* DMA Dest Addr Reg 2 */ |
#define | DMABTC2 (*(portb) (MBASE+0x07B4)) /* DMA Byte Trans Cnt Reg 2 */ |
#define | DUMCRH (*(portb) (MBASE+0x0700)) /* DUART Module Config Reg */ |
#define | DUMCRL (*(portb) (MBASE+0x0701)) /* DUART Module Config Reg */ |
#define | DUILR (*(portb) (MBASE+0x0704)) /* DUART Interrupt Level */ |
#define | DUIVR (*(portb) (MBASE+0x0705)) /* DUART Interrupt Vector */ |
#define | DUMR1A (*(portb) (MBASE+0x0710)) /* DUART Mode Reg 1A */ |
#define | DUSRA (*(portb) (MBASE+0x0711)) /* DUART Status Reg A */ |
#define | DUCSRA (*(portb) (MBASE+0x0711)) /* DUART Clock Sel Reg A */ |
#define | DUCRA (*(portb) (MBASE+0x0712)) /* DUART Command Reg A */ |
#define | DURBA (*(portb) (MBASE+0x0713)) /* DUART Receiver Buffer A */ |
#define | DUTBA (*(portb) (MBASE+0x0713)) /* DUART Transmitter Buff A */ |
#define | DUIPCR (*(portb) (MBASE+0x0714)) /* DUART Input Port Chg Reg */ |
#define | DUACR (*(portb) (MBASE+0x0714)) /* DUART Auxiliary Cont Reg */ |
#define | DUISR (*(portb) (MBASE+0x0715)) /* DUART Interrupt Stat Reg */ |
#define | DUIER (*(portb) (MBASE+0x0715)) /* DUART Interrupt Enb Reg */ |
#define | DUMR1B (*(portb) (MBASE+0x0718)) /* DUART Mode Reg 1B */ |
#define | DUSRB (*(portb) (MBASE+0x0719)) /* DUART Status Reg B */ |
#define | DUCSRB (*(portb) (MBASE+0x0719)) /* DUART Clock Sel Reg B */ |
#define | DUCRB (*(portb) (MBASE+0x071A)) /* DUART Command Reg B */ |
#define | DURBB (*(portb) (MBASE+0x071B)) /* DUART Receiver Buffer B */ |
#define | DUTBB (*(portb) (MBASE+0x071B)) /* DUART Transmitter Buff B */ |
#define | DUIP (*(portb) (MBASE+0x071D)) /* DUART Input Port Reg */ |
#define | DUOPCR (*(portb) (MBASE+0x071D)) /* DUART Outp Port Cnt Reg */ |
#define | DUOPBS (*(portb) (MBASE+0x071E)) /* DUART Outp Port Bit Set */ |
#define | DUOPBR (*(portb) (MBASE+0x071F)) /* DUART Outp Port Bit Rst */ |
#define | DUMR2A (*(portb) (MBASE+0x0720)) /* DUART Mode Reg 2A */ |
#define | DUMR2B (*(portb) (MBASE+0x0721)) /* DUART Mode Reg 2B */ |
#define | TMCR1 (*(portw) (MBASE+0x0600)) /* Timer Module Config Reg 1 */ |
#define | TIR1 (*(portw) (MBASE+0x0604)) /* Timer Interrupt Reg 1 */ |
#define | TCR1 (*(portw) (MBASE+0x0606)) /* Timer Control Reg 1 */ |
#define | TSR1 (*(portw) (MBASE+0x0608)) /* Timer Status Reg 1 */ |
#define | TCNTR1 (*(portw) (MBASE+0x060A)) /* Timer Counter Reg 1 */ |
#define | WPREL11 (*(portw) (MBASE+0x060C)) /* Timer Preload 1 Reg 1 */ |
#define | WPREL21 (*(portw) (MBASE+0x060E)) /* Timer Preload 2 Reg 1 */ |
#define | TCOM1 (*(portw) (MBASE+0x0610)) /* Timer Compare Reg 1 */ |
#define | TMCR2 (*(portw) (MBASE+0x0640)) /* Timer Module Config Reg 2 */ |
#define | TIR2 (*(portw) (MBASE+0x0644)) /* Timer Interrupt Reg 2 */ |
#define | TCR2 (*(portw) (MBASE+0x0646)) /* Timer Control Reg 2 */ |
#define | TSR2 (*(portw) (MBASE+0x0648)) /* Timer Status Reg 2 */ |
#define | TCNTR2 (*(portw) (MBASE+0x064A)) /* Timer Counter Reg 2 */ |
#define | WPREL12 (*(portw) (MBASE+0x064C)) /* Timer Preload 1 Reg 2 */ |
#define | WPREL22 (*(portw) (MBASE+0x064E)) /* Timer Preload 2 Reg 2 */ |
#define | TCOM2 (*(portw) (MBASE+0x0650)) /* Timer Compare Reg 2 */ |
Typedefs | |
typedef volatile unsigned char * | portb |
typedef volatile unsigned short * | portw |
typedef volatile unsigned int * | portl |
