RTEMS 6.1-rc5
jffs2_flashdev.h
2
3/*
4 * Copyright (C) 2024 On-Line Applications Research Corporation (OAR)
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef JFFS2_FLASHDEV_H
29#define JFFS2_FLASHDEV_H
30
31#include <dev/flash/flashdev.h>
32#include <rtems/jffs2.h>
33#include <rtems/rtems/status.h>
34
48rtems_status_code jffs2_flashdev_mount(
49 const char *flashdev_path,
50 const char *mount_dir,
52 rtems_jffs2_compressor_control *compressor_control,
53 bool read_only
54);
55
56#endif /* JFFS2_FLASHDEV_H */
Generic Flash API.
rtems_status_code
Definition: status.h:85
This header file provides the status codes of Classic API directives and support functions.
General definition for on flash device.
Definition: flashdev.h:188
JFFS2 compressor control.
Definition: jffs2.h:506
