RTEMS 6.1-rc5
19#ifndef _I386_KEYBOARD_H
20#define _I386_KEYBOARD_H
25#define DISABLE_KBD_DURING_INTERRUPTS 0
27extern int pckbd_setkeycode(
unsigned int scancode,
unsigned int keycode);
28extern int pckbd_getkeycode(
unsigned int scancode);
29extern int pckbd_translate(
unsigned char scancode,
unsigned char *keycode,
31extern char pckbd_unexpected_up(
unsigned char keycode);
32extern void pckbd_leds(
unsigned char leds);
33extern void pckbd_init_hw(
void);
34extern unsigned char pckbd_sysrq_xlate[128];
36#define kbd_setkeycode pckbd_setkeycode
37#define kbd_getkeycode pckbd_getkeycode
38#define kbd_translate pckbd_translate
39#define kbd_unexpected_up pckbd_unexpected_up
40#define kbd_leds pckbd_leds
41#define kbd_init_hw pckbd_init_hw
42#define kbd_sysrq_xlate pckbd_sysrq_xlate
47#define kbd_request_region()
48#define kbd_request_irq(handler)
51#define kbd_read_input() inb(KBD_DATA_REG)
52#define kbd_read_status() inb(KBD_STATUS_REG)
53#define kbd_write_output(val) outb(val, KBD_DATA_REG)
54#define kbd_write_command(val) outb(val, KBD_CNTL_REG)
57#define kbd_pause() do { } while(0)
65#define aux_request_irq(hand, dev_id)
67#define aux_free_irq(dev_id)
82#define KBD_REPORT_UNKN
83#define KBD_REPORT_TIMEOUTS
84#undef KBD_IS_FOCUS_9000
85#undef INITIALIZE_MOUSE
87#define KBD_INIT_TIMEOUT 1000
88#define KBC_TIMEOUT 250
89#define KBD_TIMEOUT 1000
95extern unsigned char pckbd_read_mask;
96extern unsigned char aux_device_present;
102#define KBD_STATUS_REG 0x64
103#define KBD_CNTL_REG 0x64
104#define KBD_DATA_REG 0x60
110#define KBD_CCMD_READ_MODE 0x20
111#define KBD_CCMD_WRITE_MODE 0x60
112#define KBD_CCMD_GET_VERSION 0xA1
113#define KBD_CCMD_MOUSE_DISABLE 0xA7
114#define KBD_CCMD_MOUSE_ENABLE 0xA8
115#define KBD_CCMD_TEST_MOUSE 0xA9
116#define KBD_CCMD_SELF_TEST 0xAA
117#define KBD_CCMD_KBD_TEST 0xAB
118#define KBD_CCMD_KBD_DISABLE 0xAD
119#define KBD_CCMD_KBD_ENABLE 0xAE
120#define KBD_CCMD_WRITE_AUX_OBUF 0xD3
122#define KBD_CCMD_WRITE_MOUSE 0xD4
128#define KBD_CMD_SET_LEDS 0xED
129#define KBD_CMD_SET_RATE 0xF3
130#define KBD_CMD_ENABLE 0xF4
131#define KBD_CMD_DISABLE 0xF5
132#define KBD_CMD_RESET 0xFF
138#define KBD_REPLY_POR 0xAA
139#define KBD_REPLY_ACK 0xFA
140#define KBD_REPLY_RESEND 0xFE
146#define KBD_STAT_OBF 0x01
147#define KBD_STAT_IBF 0x02
148#define KBD_STAT_SELFTEST 0x04
149#define KBD_STAT_CMD 0x08
150#define KBD_STAT_UNLOCKED 0x10
151#define KBD_STAT_MOUSE_OBF 0x20
152#define KBD_STAT_GTO 0x40
153#define KBD_STAT_PERR 0x80
155#define AUX_STAT_OBF (KBD_STAT_OBF | KBD_STAT_MOUSE_OBF)
161#define KBD_MODE_KBD_INT 0x01
162#define KBD_MODE_MOUSE_INT 0x02
163#define KBD_MODE_SYS 0x04
164#define KBD_MODE_NO_KEYLOCK 0x08
165#define KBD_MODE_DISABLE_KBD 0x10
166#define KBD_MODE_DISABLE_MOUSE 0x20
167#define KBD_MODE_KCC 0x40
168#define KBD_MODE_RFU 0x80
174#define AUX_SET_RES 0xE8
175#define AUX_SET_SCALE11 0xE6
176#define AUX_SET_SCALE21 0xE7
177#define AUX_GET_SCALE 0xE9
178#define AUX_SET_STREAM 0xEA
179#define AUX_SET_SAMPLE 0xF3
180#define AUX_ENABLE_DEV 0xF4
181#define AUX_DISABLE_DEV 0xF5
182#define AUX_RESET 0xFF
185#define AUX_BUF_SIZE 2048
