RTEMS 6.1-rc5
Data Structures | Macros | Typedefs
grclkgate-regs.h File Reference
This header file defines the GRCLKGATE register block interface. More...
#include <stdint.h>
struct  grclkgate
 This structure defines the GRCLKGATE register block memory map. More...
#define GRCLKGATE_UNLOCK_UNLOCK_SHIFT   0
#define GRCLKGATE_UNLOCK_UNLOCK_MASK   0xffffffffU
#define GRCLKGATE_UNLOCK_UNLOCK_GET(_reg)
#define GRCLKGATE_UNLOCK_UNLOCK_SET(_reg, _val)
#define GRCLKGATE_UNLOCK_UNLOCK(_val)
#define GRCLKGATE_CLKEN_ENABLE_SHIFT   0
#define GRCLKGATE_CLKEN_ENABLE_MASK   0xffffffffU
#define GRCLKGATE_CLKEN_ENABLE_GET(_reg)
#define GRCLKGATE_CLKEN_ENABLE_SET(_reg, _val)
#define GRCLKGATE_CLKEN_ENABLE(_val)
#define GRCLKGATE_RESET_RESET_SHIFT   0
#define GRCLKGATE_RESET_RESET_MASK   0xffffffffU
#define GRCLKGATE_RESET_RESET_GET(_reg)
#define GRCLKGATE_RESET_RESET_SET(_reg, _val)
#define GRCLKGATE_RESET_RESET(_val)
#define GRCLKGATE_OVERRIDE_FOVERRIDE_SHIFT   16
#define GRCLKGATE_OVERRIDE_FOVERRIDE_MASK   0xf0000U
#define GRCLKGATE_OVERRIDE_FOVERRIDE_GET(_reg)
#define GRCLKGATE_OVERRIDE_FOVERRIDE_SET(_reg, _val)
#define GRCLKGATE_OVERRIDE_FOVERRIDE(_val)
#define GRCLKGATE_OVERRIDE_OVERRIDE_SHIFT   0
#define GRCLKGATE_OVERRIDE_OVERRIDE_MASK   0xfU
#define GRCLKGATE_OVERRIDE_OVERRIDE_GET(_reg)
#define GRCLKGATE_OVERRIDE_OVERRIDE_SET(_reg, _val)
#define GRCLKGATE_OVERRIDE_OVERRIDE(_val)
typedef struct grclkgate grclkgate
