RTEMS 6.1-rc5
#include "fsl_common.h"
struct | _tempmon_config |
TEMPMON temperature structure. More... | |
Driver version | |
#define | FSL_TEMPMON_DRIVER_VERSION (MAKE_VERSION(2, 1, 1)) |
TEMPMON driver version. | |
enum | _tempmon_alarm_mode { kTEMPMON_HighAlarmMode = 0U , kTEMPMON_PanicAlarmMode = 1U , kTEMPMON_LowAlarmMode = 2U } |
TEMPMON alarm mode. More... | |
typedef struct _tempmon_config | tempmon_config_t |
TEMPMON temperature structure. | |
typedef enum _tempmon_alarm_mode | tempmon_alarm_mode |
TEMPMON alarm mode. | |
void | TEMPMON_Init (TEMPMON_Type *base, const tempmon_config_t *config) |
Initializes the TEMPMON module. | |
void | TEMPMON_Deinit (TEMPMON_Type *base) |
Deinitializes the TEMPMON module. | |
void | TEMPMON_GetDefaultConfig (tempmon_config_t *config) |
Gets the default configuration structure. | |
float | TEMPMON_GetCurrentTemperature (TEMPMON_Type *base) |
Get current temperature with the fused temperature calibration data. | |
void | TEMPMON_SetTempAlarm (TEMPMON_Type *base, int8_t tempVal, tempmon_alarm_mode alarmMode) |
Set the temperature count (raw sensor output) that will generate an alarm interrupt. | |
