RTEMS 6.1-rc5
frame_buffer.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _FRAME_BUFFER_
38#define _FRAME_BUFFER_
39
40/*----------------------------------------------------------------------------
41 * Exported functions
42 *----------------------------------------------------------------------------*/
43
44extern void FB_SetFrameBuffer(
45 LcdColor_t *pBuffer,
46 uint8_t ucWidth,
47 uint8_t ucHeight);
48
49extern void FB_SetColor(uint32_t color);
50
51extern uint32_t FB_DrawLine (
52 uint32_t dwX1,
53 uint32_t dwY1,
54 uint32_t dwX2,
55 uint32_t dwY2);
56
57extern uint32_t FB_DrawPixel(uint32_t x, uint32_t y);
58extern uint32_t FB_DrawCircle(uint32_t x, uint32_t y, uint32_t r);
59extern uint32_t FB_DrawFilledCircle(
60 uint32_t dwX,
61 uint32_t dwY,
62 uint32_t dwRadius);
63
64extern uint32_t FB_DrawRectangle(
65 uint32_t dwX1,
66 uint32_t dwY1,
67 uint32_t dwX2,
68 uint32_t dwY2);
69
70extern uint32_t FB_DrawFilledRectangle(
71 uint32_t dwX1,
72 uint32_t dwY1,
73 uint32_t dwX2,
74 uint32_t dwY2);
75
76extern uint32_t FB_DrawPicture(
77 uint32_t dwX1,
78 uint32_t dwY1,
79 uint32_t dwX2,
80 uint32_t dwY2,
81 const void *pBuffer);
82
83#endif /* #ifndef _FRAME_BUFFER_ */
