RTEMS 6.1-rc5
flashPgm.h
1#ifndef BSP_FLASH_PGM_API_H
2#define BSP_FLASH_PGM_API_H
3
4/* Trivial Flash Programmer */
5
6/* Author: Till Straumann <strauman@slac.stanford.edu>, 2006
7 * NOTE: copyright info at the bottom of this file
8 */
9
10/* IMPORTANT NOTE
11 *
12 * The flash API is NOT THREAD SAFE. During the execution of any of the
13 * BSP_flashXXX() routines, flash (residing in the same device)
14 * MUST NOT be accessed by other threads in ANY way (NOT EVEN READ!).
15 * Read operations may return internal device register contents
16 * instead of memory array data when issued while a flash device
17 * is erased, written or queried by the library.
18 *
19 * The routines are intended for occasional maintenance use only
20 * (i.e., not for implementing a file system or similar).
21 *
22 * While polling for the completion of block erase operations the
23 * CPU is yielded to other threads. Busy waiting (interrupts and
24 * thread dispatching remain enabled) on write operations is employed.
25 */
26
27#include <stdio.h>
28
29#ifdef __cplusplus
30 extern "C" {
31#endif
32
33/* Disengage flash write protection. Write protection is implemented
34 * at the board or chipset level by disabling all write operations/bus cycles
35 * to the flash device(s).
36 * With write protection enabled, nothing but 'ordinary' (array) read operations
37 * are possible.
38 * Write protection must be disabled not only to erase and write contents
39 * but also in order to read ID, size, status etc.
40 * None of the operations (except for BSP_flashWriteEnable()) are possible
41 * on a write-protected device.
42 *
43 * 'bank': flash bank # (usually 0)
44 * RETURNS: 0 on success, nonzero on error (printing message to stderr).
45 *
46 * NOTES: - some boards (MVME5500) don't support 'bank' granularity but
47 * enable/disable write protection for all devices at once.
48 * - a jumper-based protection mechanism might be in place
49 * in addition to the software-based one. Consult the user's
50 * manual of your board for more information.
51 */
52int
53BSP_flashWriteEnable(int bank);
54
55/* Engage flash write protection (see above)
56 */
57int
58BSP_flashWriteDisable(int bank);
59
60/* Erase a region of flash memory.
61 * 'bank': flash bank # (usually 0).
62 * 'offset': destination address offset (from start of bank).
63 * 'size': number of bytes to erase.
64 * 'quiet': if non-zero, suppress confirmation message / prompt
65 * if > 1 also suppress the progress indicator.
66 *
67 * RETURNS: 0 on success, nonzero on error (printing messages to stderr).
68 *
69 * NOTES: - 'offset' and 'size' must be block-aligned. Common 16-bit devices
70 * have a block size of 0x20000 bytes. If two such devices are
71 * operated in parallel to form a 32-bit word then the 'effective'
72 * block size is 0x40000 bytes. The block size can be queried by
73 * BSP_flashBlockSize(int bank);
74 *
75 * - erase operation is verified.
76 */
77int
78BSP_flashErase(int bank, uint32_t offset, uint32_t size, int quiet);
79
80/* Write data from a buffer to flash. The target area is erased if necessary.
81 *
82 * 'bank': flash bank # (usually 0).
83 * 'offset': destination address offset (from start of bank).
84 * 'src': data source block address (in memory).
85 *'n_bytes': number of bytes to copy.
86 * 'quiet': if non-zero, suppress confirmation message / prompt
87 * if > 1 also suppress the progress indicator.
88 *
89 * NOTES: - Erase operations are only performed where necessary. I.e.,
90 * if one or both of the boundaries of the destination region is/are
91 * not block-aligned then adjacent data are preserved provided that
92 * the relevant chunks of the destination are blank (erased).
93 *
94 * | <neighbour> fffffff |
95 * ^--- destination ----- ^
96 * | : block boundary
97 * f : blank/erased pieces
98 *
99 * (If the start of the destination region up to the next block boundary
100 * is blank then '<neighbour>'-data is preserved. The end of the
101 * destination is treated the same way.)
102 *
103 * - user confirmation is requested before changes are made
104 *
105 * - 'src' must not point into the destination bank (no copy
106 * within a flash bank).
107 *
108 * - erase and write operations are verified.
109 *
110 * RETURNS: 0 on success, nonzero on error (message printed to stderr).
111 */
112int
113BSP_flashWrite(int bank, uint32_t offset, const char *src, uint32_t n_bytes, int quiet);
114
115/* Copy contents of a file to flash.
116 *
117 * 'fname': Path of a file.
118 * 'quiet': if non-zero, suppress confirmation message / prompt
119 * if > 1 also suppress the progress indicator.
120 *
121 * NOTES: Convenience wrapper around BSP_flashWrite(); see above for
122 * args and return value.
123 */
124int
125BSP_flashWriteFile(int bank, uint32_t offset, const char *path, int quiet);
126
127/* Dump info about available flash to file
128 * (stdout is used if f==NULL).
129 *
130 * RETURNS: 0
131 * NOTES: Write protection must be disengaged (see above);
132 */
133int
134BSP_flashDumpInfo(FILE *f);
135
136/*
137 * Obtain starting-address of flash bank (as seen from CPU)
138 * (returns ((uint32_t) -1) if the bank argument is invalid).
139 */
140
141uint32_t
142BSP_flashStart(int bank);
143
144/*
145 * Obtain size of flash bank (returns ((uint32_t) -1) if the
146 * bank argument is invalid).
147 */
148uint32_t
149BSP_flashSize(int bank);
150
151/*
152 * Obtain block size of flash bank (sector size times
153 * number of devices in parallel; the block size determines
154 * alignment and granularity accepted by BSP_flashErase()
155 * (returns ((uint32_t) -1) if the bank argument is invalid).
156 */
157uint32_t
158BSP_flashBlockSize(int bank);
159
160#ifdef __cplusplus
161 }
162#endif
163
164/*
165 * Authorship
166 * ----------
167 * This software was created by
168 * Till Straumann <strauman@slac.stanford.edu>, 2005-2007,
169 * Stanford Linear Accelerator Center, Stanford University.
170 *
171 * Acknowledgement of sponsorship
172 * ------------------------------
173 * The software was produced by
174 * the Stanford Linear Accelerator Center, Stanford University,
175 * under Contract DE-AC03-76SFO0515 with the Department of Energy.
176 *
177 * Government disclaimer of liability
178 * ----------------------------------
179 * Neither the United States nor the United States Department of Energy,
180 * nor any of their employees, makes any warranty, express or implied, or
181 * assumes any legal liability or responsibility for the accuracy,
182 * completeness, or usefulness of any data, apparatus, product, or process
183 * disclosed, or represents that its use would not infringe privately owned
184 * rights.
185 *
186 * Stanford disclaimer of liability
187 * --------------------------------
188 * Stanford University makes no representations or warranties, express or
189 * implied, nor assumes any liability for the use of this software.
190 *
191 * Stanford disclaimer of copyright
192 * --------------------------------
193 * Stanford University, owner of the copyright, hereby disclaims its
194 * copyright and all other rights in this software. Hence, anyone may
195 * freely use it for any purpose without restriction.
196 *
197 * Maintenance of notices
198 * ----------------------
199 * In the interest of clarity regarding the origin and status of this
200 * SLAC software, this and all the preceding Stanford University notices
201 * are to remain affixed to any copy or derivative of this software made
202 * or distributed by the recipient and are to be affixed to any copy of
203 * software made or distributed by the recipient that contains a copy or
204 * derivative of this software.
205 *
206 * ------------------ SLAC Software Notices, Set 4 OTT.002a, 2004 FEB 03
207 */
208
209#endif
