RTEMS
6.1-rc5
bsps
arm
atsam
contrib
libraries
libchip
source
exceptions.c File Reference
#include "chip.h"
void
NMI_Handler
(void)
Default NMI interrupt handler.
__STATIC_INLINE uint32_t
StackUnwind
(void)
This function back trace the stack to give exact address where fault happened.
void
HardFault_Handler
(void)
Default HardFault interrupt handler.
void
MemManage_Handler
(void)
Default MemManage interrupt handler.
void
BusFault_Handler
(void)
Default BusFault interrupt handler.
void
UsageFault_Handler
(void)
Default UsageFault interrupt handler.
This file contains the default exception handlers.
Note
The exception handler has weak aliases. As they are weak aliases, any function with the same name will override this definition.
