56#ifndef _RTEMS_RTEMS_DPMEM_H
57#define _RTEMS_RTEMS_DPMEM_H
150 void *internal_start,
151 void *external_start,
This header file provides types used by the Classic API.
rtems_status_code rtems_port_internal_to_external(rtems_id id, void *internal, void **external)
Converts the internal address to the external address.
Definition: dpmeminternal2external.c:45
rtems_status_code rtems_port_ident(rtems_name name, rtems_id *id)
Identifies a port by the object name.
Definition: dpmemident.c:45
rtems_status_code rtems_port_delete(rtems_id id)
Deletes the port.
Definition: dpmemdelete.c:44
rtems_status_code rtems_port_create(rtems_name name, void *internal_start, void *external_start, uint32_t length, rtems_id *id)
Creates a port.
Definition: dpmemcreate.c:50
rtems_status_code rtems_port_external_to_internal(rtems_id id, void *external, void **internal)
Converts the external address to the internal address.
Definition: dpmemexternal2internal.c:45
rtems_status_code
Definition: status.h:85
uint32_t rtems_name
This type represents Classic API object names.
Definition: types.h:226
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
This header file provides the status codes of Classic API directives and support functions.
