RTEMS
6.1-rc5
include
fdt.h
1
/* SPDX-License-Identifier: (GPL-2.0-or-later OR BSD-2-Clause) */
2
#ifndef FDT_H
3
#define FDT_H
4
5
* libfdt - Flat Device Tree manipulation
6
* Copyright (C) 2006 David Gibson, IBM Corporation.
7
* Copyright 2012 Kim Phillips, Freescale Semiconductor.
8
9
10
#ifndef __ASSEMBLY__
11
12
struct
fdt_header
13
fdt32_t magic;
/* magic word FDT_MAGIC */
14
fdt32_t totalsize;
/* total size of DT block */
15
fdt32_t off_dt_struct;
/* offset to structure */
16
fdt32_t off_dt_strings;
/* offset to strings */
17
fdt32_t off_mem_rsvmap;
/* offset to memory reserve map */
18
fdt32_t version;
/* format version */
19
fdt32_t last_comp_version;
/* last compatible version */
20
21
/* version 2 fields below */
22
fdt32_t boot_cpuid_phys;
/* Which physical CPU id we're
23
booting on */
24
/* version 3 fields below */
25
fdt32_t size_dt_strings;
/* size of the strings block */
26
27
/* version 17 fields below */
28
fdt32_t size_dt_struct;
/* size of the structure block */
29
30
31
struct
fdt_reserve_entry
32
fdt64_t address;
33
fdt64_t size;
34
35
36
struct
fdt_node_header
37
fdt32_t tag;
38
char
name[0];
39
40
41
struct
fdt_property
42
fdt32_t tag;
43
fdt32_t len;
44
fdt32_t nameoff;
45
char
data[0];
46
47
48
#endif
/* !__ASSEMBLY */
49
50
#define FDT_MAGIC 0xd00dfeed
/* 4: version, 4: total size */
51
#define FDT_TAGSIZE sizeof(fdt32_t)
52
53
#define FDT_BEGIN_NODE 0x1
/* Start node: full name */
54
#define FDT_END_NODE 0x2
/* End node */
55
#define FDT_PROP 0x3
/* Property: name off,
56
size, content */
57
#define FDT_NOP 0x4
/* nop */
58
#define FDT_END 0x9
59
60
#define FDT_V1_SIZE (7*sizeof(fdt32_t))
61
#define FDT_V2_SIZE (FDT_V1_SIZE + sizeof(fdt32_t))
62
#define FDT_V3_SIZE (FDT_V2_SIZE + sizeof(fdt32_t))
63
#define FDT_V16_SIZE FDT_V3_SIZE
64
#define FDT_V17_SIZE (FDT_V16_SIZE + sizeof(fdt32_t))
65
66
#endif
/* FDT_H */
fdt_header
Definition:
fdt.h:12
fdt_node_header
Definition:
fdt.h:36
fdt_property
Definition:
fdt.h:41
fdt_reserve_entry
Definition:
fdt.h:31
