RTEMS
6.1-rc5
include
pci
cfg_static.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* COPYRIGHT (c) 2010 Cobham Gaisler AB.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef __PCI_CFG_STATIC_H__
35
#define __PCI_CFG_STATIC_H__
36
37
/* This function initializes all buses and device accorind to a user defined
38
* "static" configuration. The configuration can manually created with C
39
* data structures. Or it can be automatically created on a running target
40
* using the pci_cfg_print() routine after the AUTO or READ Configuration
41
* Library has setup the PCI bus
42
43
extern
int
pci_config_static(
void
44
45
#endif
