RTEMS 6.1-rc5
Typedefs | Functions
This header should only be used inside a BSP chosing to use bspVmeDmaList for implementing VMEDMA.h. More...
#include <stdint.h>
#include <bsp/VMEDMA.h>
typedef struct VMEDmaListNodeRec_VMEDmaListNode
typedef struct VMEDmaListClassRec_VMEDmaListClass
VMEDmaListNode BSP_VMEDmaListDescriptorNewTool (VMEDmaListClass pc, uint32_t attr_mask, uint32_t xfer_mode, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes)
VMEDmaListNode BSP_VMEDmaListDescriptorSetupTool (VMEDmaListNode n, uint32_t attr_mask, uint32_t xfer_mode, uint32_t pci_addr, uint32_t vme_addr, uint32_t n_bytes)
int BSP_VMEDmaListDescriptorStartTool (volatile void *controller, int channel, VMEDmaListNode n)
