RTEMS
6.1-rc5
bsps
arm
include
bsp
arm-pl050.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2013, 2014 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_ARM_SHARED_ARM_PL050_H
37
#define LIBBSP_ARM_SHARED_ARM_PL050_H
38
39
rtems/termiostypes.h
40
41
bsp/arm-pl050-regs.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
47
typedef
struct
48
rtems_termios_device_context
base;
49
volatile
pl050
*regs;
50
rtems_vector_number
irq;
51
uint32_t initial_baud;
52
arm_pl050_context
53
54
extern
const
rtems_termios_device_handler
arm_pl050_fns;
55
56
#ifdef __cplusplus
57
58
#endif
/* __cplusplus */
59
60
#endif
/* LIBBSP_ARM_SHARED_ARM_PL050_H */
arm-pl050-regs.h
ARM PL050 Register Definitions.
rtems_vector_number
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition:
intr.h:102
arm_pl050_context
Definition:
arm-pl050.h:47
pl050
Definition:
arm-pl050-regs.h:41
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
termiostypes.h
