161#define AE_CODE_ENVIRONMENTAL 0x0000
162#define AE_CODE_PROGRAMMER 0x1000
163#define AE_CODE_ACPI_TABLES 0x2000
164#define AE_CODE_AML 0x3000
165#define AE_CODE_CONTROL 0x4000
167#define AE_CODE_MAX 0x4000
168#define AE_CODE_MASK 0xF000
173#define EXCEP_ENV(code) ((ACPI_STATUS) (code | AE_CODE_ENVIRONMENTAL))
174#define EXCEP_PGM(code) ((ACPI_STATUS) (code | AE_CODE_PROGRAMMER))
175#define EXCEP_TBL(code) ((ACPI_STATUS) (code | AE_CODE_ACPI_TABLES))
176#define EXCEP_AML(code) ((ACPI_STATUS) (code | AE_CODE_AML))
177#define EXCEP_CTL(code) ((ACPI_STATUS) (code | AE_CODE_CONTROL))
187#if defined (ACPI_HELP_APP) || defined (ACPI_ASL_COMPILER)
192#if defined (ACPI_HELP_APP) || defined (ACPI_ASL_COMPILER)
193#define EXCEP_TXT(Name,Description) {Name, Description}
195#define EXCEP_TXT(Name,Description) {Name}
202#define ACPI_SUCCESS(a) (!(a))
203#define ACPI_FAILURE(a) (a)
205#define AE_OK (ACPI_STATUS) 0x0000
207#define ACPI_ENV_EXCEPTION(Status) (((Status) & AE_CODE_MASK) == AE_CODE_ENVIRONMENTAL)
208#define ACPI_AML_EXCEPTION(Status) (((Status) & AE_CODE_MASK) == AE_CODE_AML)
209#define ACPI_PROG_EXCEPTION(Status) (((Status) & AE_CODE_MASK) == AE_CODE_PROGRAMMER)
210#define ACPI_TABLE_EXCEPTION(Status) (((Status) & AE_CODE_MASK) == AE_CODE_ACPI_TABLES)
211#define ACPI_CNTL_EXCEPTION(Status) (((Status) & AE_CODE_MASK) == AE_CODE_CONTROL)
217#define AE_ERROR EXCEP_ENV (0x0001)
218#define AE_NO_ACPI_TABLES EXCEP_ENV (0x0002)
219#define AE_NO_NAMESPACE EXCEP_ENV (0x0003)
220#define AE_NO_MEMORY EXCEP_ENV (0x0004)
221#define AE_NOT_FOUND EXCEP_ENV (0x0005)
222#define AE_NOT_EXIST EXCEP_ENV (0x0006)
223#define AE_ALREADY_EXISTS EXCEP_ENV (0x0007)
224#define AE_TYPE EXCEP_ENV (0x0008)
225#define AE_NULL_OBJECT EXCEP_ENV (0x0009)
226#define AE_NULL_ENTRY EXCEP_ENV (0x000A)
227#define AE_BUFFER_OVERFLOW EXCEP_ENV (0x000B)
228#define AE_STACK_OVERFLOW EXCEP_ENV (0x000C)
229#define AE_STACK_UNDERFLOW EXCEP_ENV (0x000D)
230#define AE_NOT_IMPLEMENTED EXCEP_ENV (0x000E)
231#define AE_SUPPORT EXCEP_ENV (0x000F)
232#define AE_LIMIT EXCEP_ENV (0x0010)
233#define AE_TIME EXCEP_ENV (0x0011)
234#define AE_ACQUIRE_DEADLOCK EXCEP_ENV (0x0012)
235#define AE_RELEASE_DEADLOCK EXCEP_ENV (0x0013)
236#define AE_NOT_ACQUIRED EXCEP_ENV (0x0014)
237#define AE_ALREADY_ACQUIRED EXCEP_ENV (0x0015)
238#define AE_NO_HARDWARE_RESPONSE EXCEP_ENV (0x0016)
239#define AE_NO_GLOBAL_LOCK EXCEP_ENV (0x0017)
240#define AE_ABORT_METHOD EXCEP_ENV (0x0018)
241#define AE_SAME_HANDLER EXCEP_ENV (0x0019)
242#define AE_NO_HANDLER EXCEP_ENV (0x001A)
243#define AE_OWNER_ID_LIMIT EXCEP_ENV (0x001B)
244#define AE_NOT_CONFIGURED EXCEP_ENV (0x001C)
245#define AE_ACCESS EXCEP_ENV (0x001D)
246#define AE_IO_ERROR EXCEP_ENV (0x001E)
247#define AE_NUMERIC_OVERFLOW EXCEP_ENV (0x001F)
248#define AE_HEX_OVERFLOW EXCEP_ENV (0x0020)
249#define AE_DECIMAL_OVERFLOW EXCEP_ENV (0x0021)
250#define AE_OCTAL_OVERFLOW EXCEP_ENV (0x0022)
251#define AE_END_OF_TABLE EXCEP_ENV (0x0023)
253#define AE_CODE_ENV_MAX 0x0023
259#define AE_BAD_PARAMETER EXCEP_PGM (0x0001)
260#define AE_BAD_CHARACTER EXCEP_PGM (0x0002)
261#define AE_BAD_PATHNAME EXCEP_PGM (0x0003)
262#define AE_BAD_DATA EXCEP_PGM (0x0004)
263#define AE_BAD_HEX_CONSTANT EXCEP_PGM (0x0005)
264#define AE_BAD_OCTAL_CONSTANT EXCEP_PGM (0x0006)
265#define AE_BAD_DECIMAL_CONSTANT EXCEP_PGM (0x0007)
266#define AE_MISSING_ARGUMENTS EXCEP_PGM (0x0008)
267#define AE_BAD_ADDRESS EXCEP_PGM (0x0009)
269#define AE_CODE_PGM_MAX 0x0009
275#define AE_BAD_SIGNATURE EXCEP_TBL (0x0001)
276#define AE_BAD_HEADER EXCEP_TBL (0x0002)
277#define AE_BAD_CHECKSUM EXCEP_TBL (0x0003)
278#define AE_BAD_VALUE EXCEP_TBL (0x0004)
279#define AE_INVALID_TABLE_LENGTH EXCEP_TBL (0x0005)
281#define AE_CODE_TBL_MAX 0x0005
288#define AE_AML_BAD_OPCODE EXCEP_AML (0x0001)
289#define AE_AML_NO_OPERAND EXCEP_AML (0x0002)
290#define AE_AML_OPERAND_TYPE EXCEP_AML (0x0003)
291#define AE_AML_OPERAND_VALUE EXCEP_AML (0x0004)
292#define AE_AML_UNINITIALIZED_LOCAL EXCEP_AML (0x0005)
293#define AE_AML_UNINITIALIZED_ARG EXCEP_AML (0x0006)
294#define AE_AML_UNINITIALIZED_ELEMENT EXCEP_AML (0x0007)
295#define AE_AML_NUMERIC_OVERFLOW EXCEP_AML (0x0008)
296#define AE_AML_REGION_LIMIT EXCEP_AML (0x0009)
297#define AE_AML_BUFFER_LIMIT EXCEP_AML (0x000A)
298#define AE_AML_PACKAGE_LIMIT EXCEP_AML (0x000B)
299#define AE_AML_DIVIDE_BY_ZERO EXCEP_AML (0x000C)
300#define AE_AML_BAD_NAME EXCEP_AML (0x000D)
301#define AE_AML_NAME_NOT_FOUND EXCEP_AML (0x000E)
302#define AE_AML_INTERNAL EXCEP_AML (0x000F)
303#define AE_AML_INVALID_SPACE_ID EXCEP_AML (0x0010)
304#define AE_AML_STRING_LIMIT EXCEP_AML (0x0011)
305#define AE_AML_NO_RETURN_VALUE EXCEP_AML (0x0012)
306#define AE_AML_METHOD_LIMIT EXCEP_AML (0x0013)
307#define AE_AML_NOT_OWNER EXCEP_AML (0x0014)
308#define AE_AML_MUTEX_ORDER EXCEP_AML (0x0015)
309#define AE_AML_MUTEX_NOT_ACQUIRED EXCEP_AML (0x0016)
310#define AE_AML_INVALID_RESOURCE_TYPE EXCEP_AML (0x0017)
311#define AE_AML_INVALID_INDEX EXCEP_AML (0x0018)
312#define AE_AML_REGISTER_LIMIT EXCEP_AML (0x0019)
313#define AE_AML_NO_WHILE EXCEP_AML (0x001A)
314#define AE_AML_ALIGNMENT EXCEP_AML (0x001B)
315#define AE_AML_NO_RESOURCE_END_TAG EXCEP_AML (0x001C)
316#define AE_AML_BAD_RESOURCE_VALUE EXCEP_AML (0x001D)
317#define AE_AML_CIRCULAR_REFERENCE EXCEP_AML (0x001E)
318#define AE_AML_BAD_RESOURCE_LENGTH EXCEP_AML (0x001F)
319#define AE_AML_ILLEGAL_ADDRESS EXCEP_AML (0x0020)
320#define AE_AML_LOOP_TIMEOUT EXCEP_AML (0x0021)
321#define AE_AML_UNINITIALIZED_NODE EXCEP_AML (0x0022)
322#define AE_AML_TARGET_TYPE EXCEP_AML (0x0023)
323#define AE_AML_PROTOCOL EXCEP_AML (0x0024)
324#define AE_AML_BUFFER_LENGTH EXCEP_AML (0x0025)
326#define AE_CODE_AML_MAX 0x0025
332#define AE_CTRL_RETURN_VALUE EXCEP_CTL (0x0001)
333#define AE_CTRL_PENDING EXCEP_CTL (0x0002)
334#define AE_CTRL_TERMINATE EXCEP_CTL (0x0003)
335#define AE_CTRL_TRUE EXCEP_CTL (0x0004)
336#define AE_CTRL_FALSE EXCEP_CTL (0x0005)
337#define AE_CTRL_DEPTH EXCEP_CTL (0x0006)
338#define AE_CTRL_END EXCEP_CTL (0x0007)
339#define AE_CTRL_TRANSFER EXCEP_CTL (0x0008)
340#define AE_CTRL_BREAK EXCEP_CTL (0x0009)
341#define AE_CTRL_CONTINUE EXCEP_CTL (0x000A)
342#define AE_CTRL_PARSE_CONTINUE EXCEP_CTL (0x000B)
343#define AE_CTRL_PARSE_PENDING EXCEP_CTL (0x000C)
345#define AE_CODE_CTRL_MAX 0x000C
350#ifdef ACPI_DEFINE_EXCEPTION_TABLE
358 EXCEP_TXT (
"AE_OK",
"No error"),
359 EXCEP_TXT (
"AE_ERROR",
"Unspecified error"),
360 EXCEP_TXT (
"AE_NO_ACPI_TABLES",
"ACPI tables could not be found"),
361 EXCEP_TXT (
"AE_NO_NAMESPACE",
"A namespace has not been loaded"),
362 EXCEP_TXT (
"AE_NO_MEMORY",
"Insufficient dynamic memory"),
363 EXCEP_TXT (
"AE_NOT_FOUND",
"A requested entity is not found"),
364 EXCEP_TXT (
"AE_NOT_EXIST",
"A required entity does not exist"),
365 EXCEP_TXT (
"AE_ALREADY_EXISTS",
"An entity already exists"),
366 EXCEP_TXT (
"AE_TYPE",
"The object type is incorrect"),
367 EXCEP_TXT (
"AE_NULL_OBJECT",
"A required object was missing"),
368 EXCEP_TXT (
"AE_NULL_ENTRY",
"The requested object does not exist"),
369 EXCEP_TXT (
"AE_BUFFER_OVERFLOW",
"The buffer provided is too small"),
370 EXCEP_TXT (
"AE_STACK_OVERFLOW",
"An internal stack overflowed"),
371 EXCEP_TXT (
"AE_STACK_UNDERFLOW",
"An internal stack underflowed"),
372 EXCEP_TXT (
"AE_NOT_IMPLEMENTED",
"The feature is not implemented"),
373 EXCEP_TXT (
"AE_SUPPORT",
"The feature is not supported"),
374 EXCEP_TXT (
"AE_LIMIT",
"A predefined limit was exceeded"),
375 EXCEP_TXT (
"AE_TIME",
"A time limit or timeout expired"),
376 EXCEP_TXT (
"AE_ACQUIRE_DEADLOCK",
"Internal error, attempt was made to acquire a mutex in improper order"),
377 EXCEP_TXT (
"AE_RELEASE_DEADLOCK",
"Internal error, attempt was made to release a mutex in improper order"),
378 EXCEP_TXT (
"AE_NOT_ACQUIRED",
"An attempt to release a mutex or Global Lock without a previous acquire"),
379 EXCEP_TXT (
"AE_ALREADY_ACQUIRED",
"Internal error, attempt was made to acquire a mutex twice"),
380 EXCEP_TXT (
"AE_NO_HARDWARE_RESPONSE",
"Hardware did not respond after an I/O operation"),
381 EXCEP_TXT (
"AE_NO_GLOBAL_LOCK",
"There is no FACS Global Lock"),
382 EXCEP_TXT (
"AE_ABORT_METHOD",
"A control method was aborted"),
383 EXCEP_TXT (
"AE_SAME_HANDLER",
"Attempt was made to install the same handler that is already installed"),
384 EXCEP_TXT (
"AE_NO_HANDLER",
"A handler for the operation is not installed"),
385 EXCEP_TXT (
"AE_OWNER_ID_LIMIT",
"There are no more Owner IDs available for ACPI tables or control methods"),
386 EXCEP_TXT (
"AE_NOT_CONFIGURED",
"The interface is not part of the current subsystem configuration"),
387 EXCEP_TXT (
"AE_ACCESS",
"Permission denied for the requested operation"),
388 EXCEP_TXT (
"AE_IO_ERROR",
"An I/O error occurred"),
389 EXCEP_TXT (
"AE_NUMERIC_OVERFLOW",
"Overflow during string-to-integer conversion"),
390 EXCEP_TXT (
"AE_HEX_OVERFLOW",
"Overflow during ASCII hex-to-binary conversion"),
391 EXCEP_TXT (
"AE_DECIMAL_OVERFLOW",
"Overflow during ASCII decimal-to-binary conversion"),
392 EXCEP_TXT (
"AE_OCTAL_OVERFLOW",
"Overflow during ASCII octal-to-binary conversion"),
393 EXCEP_TXT (
"AE_END_OF_TABLE",
"Reached the end of table")
398 EXCEP_TXT (NULL, NULL),
399 EXCEP_TXT (
"AE_BAD_PARAMETER",
"A parameter is out of range or invalid"),
400 EXCEP_TXT (
"AE_BAD_CHARACTER",
"An invalid character was found in a name"),
401 EXCEP_TXT (
"AE_BAD_PATHNAME",
"An invalid character was found in a pathname"),
402 EXCEP_TXT (
"AE_BAD_DATA",
"A package or buffer contained incorrect data"),
403 EXCEP_TXT (
"AE_BAD_HEX_CONSTANT",
"Invalid character in a Hex constant"),
404 EXCEP_TXT (
"AE_BAD_OCTAL_CONSTANT",
"Invalid character in an Octal constant"),
405 EXCEP_TXT (
"AE_BAD_DECIMAL_CONSTANT",
"Invalid character in a Decimal constant"),
406 EXCEP_TXT (
"AE_MISSING_ARGUMENTS",
"Too few arguments were passed to a control method"),
407 EXCEP_TXT (
"AE_BAD_ADDRESS",
"An illegal null I/O address")
412 EXCEP_TXT (NULL, NULL),
413 EXCEP_TXT (
"AE_BAD_SIGNATURE",
"An ACPI table has an invalid signature"),
414 EXCEP_TXT (
"AE_BAD_HEADER",
"Invalid field in an ACPI table header"),
415 EXCEP_TXT (
"AE_BAD_CHECKSUM",
"An ACPI table checksum is not correct"),
416 EXCEP_TXT (
"AE_BAD_VALUE",
"An invalid value was found in a table"),
417 EXCEP_TXT (
"AE_INVALID_TABLE_LENGTH",
"The FADT or FACS has improper length")
422 EXCEP_TXT (NULL, NULL),
423 EXCEP_TXT (
"AE_AML_BAD_OPCODE",
"Invalid AML opcode encountered"),
424 EXCEP_TXT (
"AE_AML_NO_OPERAND",
"A required operand is missing"),
425 EXCEP_TXT (
"AE_AML_OPERAND_TYPE",
"An operand of an incorrect type was encountered"),
426 EXCEP_TXT (
"AE_AML_OPERAND_VALUE",
"The operand had an inappropriate or invalid value"),
427 EXCEP_TXT (
"AE_AML_UNINITIALIZED_LOCAL",
"Method tried to use an uninitialized local variable"),
428 EXCEP_TXT (
"AE_AML_UNINITIALIZED_ARG",
"Method tried to use an uninitialized argument"),
429 EXCEP_TXT (
"AE_AML_UNINITIALIZED_ELEMENT",
"Method tried to use an empty package element"),
430 EXCEP_TXT (
"AE_AML_NUMERIC_OVERFLOW",
"Overflow during BCD conversion or other"),
431 EXCEP_TXT (
"AE_AML_REGION_LIMIT",
"Tried to access beyond the end of an Operation Region"),
432 EXCEP_TXT (
"AE_AML_BUFFER_LIMIT",
"Tried to access beyond the end of a buffer"),
433 EXCEP_TXT (
"AE_AML_PACKAGE_LIMIT",
"Tried to access beyond the end of a package"),
434 EXCEP_TXT (
"AE_AML_DIVIDE_BY_ZERO",
"During execution of AML Divide operator"),
435 EXCEP_TXT (
"AE_AML_BAD_NAME",
"An ACPI name contains invalid character(s)"),
436 EXCEP_TXT (
"AE_AML_NAME_NOT_FOUND",
"Could not resolve a named reference"),
437 EXCEP_TXT (
"AE_AML_INTERNAL",
"An internal error within the interpreter"),
438 EXCEP_TXT (
"AE_AML_INVALID_SPACE_ID",
"An Operation Region SpaceID is invalid"),
439 EXCEP_TXT (
"AE_AML_STRING_LIMIT",
"String is longer than 200 characters"),
440 EXCEP_TXT (
"AE_AML_NO_RETURN_VALUE",
"A method did not return a required value"),
441 EXCEP_TXT (
"AE_AML_METHOD_LIMIT",
"A control method reached the maximum reentrancy limit of 255"),
442 EXCEP_TXT (
"AE_AML_NOT_OWNER",
"A thread tried to release a mutex that it does not own"),
443 EXCEP_TXT (
"AE_AML_MUTEX_ORDER",
"Mutex SyncLevel release mismatch"),
444 EXCEP_TXT (
"AE_AML_MUTEX_NOT_ACQUIRED",
"Attempt to release a mutex that was not previously acquired"),
445 EXCEP_TXT (
"AE_AML_INVALID_RESOURCE_TYPE",
"Invalid resource type in resource list"),
446 EXCEP_TXT (
"AE_AML_INVALID_INDEX",
"Invalid Argx or Localx (x too large)"),
447 EXCEP_TXT (
"AE_AML_REGISTER_LIMIT",
"Bank value or Index value beyond range of register"),
448 EXCEP_TXT (
"AE_AML_NO_WHILE",
"Break or Continue without a While"),
449 EXCEP_TXT (
"AE_AML_ALIGNMENT",
"Non-aligned memory transfer on platform that does not support this"),
450 EXCEP_TXT (
"AE_AML_NO_RESOURCE_END_TAG",
"No End Tag in a resource list"),
451 EXCEP_TXT (
"AE_AML_BAD_RESOURCE_VALUE",
"Invalid value of a resource element"),
452 EXCEP_TXT (
"AE_AML_CIRCULAR_REFERENCE",
"Two references refer to each other"),
453 EXCEP_TXT (
"AE_AML_BAD_RESOURCE_LENGTH",
"The length of a Resource Descriptor in the AML is incorrect"),
454 EXCEP_TXT (
"AE_AML_ILLEGAL_ADDRESS",
"A memory, I/O, or PCI configuration address is invalid"),
455 EXCEP_TXT (
"AE_AML_LOOP_TIMEOUT",
"An AML While loop exceeded the maximum execution time"),
456 EXCEP_TXT (
"AE_AML_UNINITIALIZED_NODE",
"A namespace node is uninitialized or unresolved"),
457 EXCEP_TXT (
"AE_AML_TARGET_TYPE",
"A target operand of an incorrect type was encountered"),
458 EXCEP_TXT (
"AE_AML_PROTOCOL",
"Violation of a fixed ACPI protocol"),
459 EXCEP_TXT (
"AE_AML_BUFFER_LENGTH",
"The length of the buffer is invalid/incorrect")
464 EXCEP_TXT (NULL, NULL),
465 EXCEP_TXT (
"AE_CTRL_RETURN_VALUE",
"A Method returned a value"),
466 EXCEP_TXT (
"AE_CTRL_PENDING",
"Method is calling another method"),
467 EXCEP_TXT (
"AE_CTRL_TERMINATE",
"Terminate the executing method"),
468 EXCEP_TXT (
"AE_CTRL_TRUE",
"An If or While predicate result"),
469 EXCEP_TXT (
"AE_CTRL_FALSE",
470 EXCEP_TXT (
"AE_CTRL_DEPTH",
"Maximum search depth has been reached"),
471 EXCEP_TXT (
"AE_CTRL_END",
"An If or While predicate is false"),
472 EXCEP_TXT (
"AE_CTRL_TRANSFER",
"Transfer control to called method"),
473 EXCEP_TXT (
"AE_CTRL_BREAK",
"A Break has been executed"),
474 EXCEP_TXT (
"AE_CTRL_CONTINUE",
"A Continue has been executed"),
475 EXCEP_TXT (
"AE_CTRL_PARSE_CONTINUE",
"Used to skip over bad opcodes"),
476 EXCEP_TXT (
"AE_CTRL_PARSE_PENDING",
"Used to implement AML While loops")
Definition: acexcep.h:184
