RTEMS 6.1-rc4
zynq-uart.h
1
9/*
10 * SPDX-License-Identifier: BSD-2-Clause
11 *
12 * Copyright (C) 2013, 2024 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_XILINX_ZYNQ_UART_H
37#define LIBBSP_ARM_XILINX_ZYNQ_UART_H
38
39#include <rtems/termiosdevice.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
51typedef struct {
53 volatile struct zynq_uart *regs;
54 int tx_queued;
55 bool transmitting;
58
59extern const rtems_termios_device_handler zynq_uart_handler;
60
63#ifdef __cplusplus
64}
65#endif /* __cplusplus */
66
67#endif /* LIBBSP_ARM_XILINX_ZYNQ_UART_H */
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
Definition: zynq-uart.h:51
Definition: zynq-uart-regs.h:55
This header file provides the interfaces of the RTEMS Termios Device Support.
