RTEMS 6.1-rc4
z85c30.h
1
8/*
9 * COPYRIGHT (c) 1998 by Radstone Technology
10 *
11 *
12 * THIS FILE IS PROVIDED TO YOU, THE USER, "AS IS", WITHOUT WARRANTY OF ANY
13 * KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
14 * IMPLIED WARRANTY OF FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK
15 * AS TO THE QUALITY AND PERFORMANCE OF ALL CODE IN THIS FILE IS WITH YOU.
16 *
17 * You are hereby granted permission to use, copy, modify, and distribute
18 * this file, provided that this notice, plus the above copyright notice
19 * and disclaimer, appears in all copies. Radstone Technology will provide
20 * no support for this code.
21 *
22 * COPYRIGHT (c) 1989-1997.
23 * On-Line Applications Research Corporation (OAR).
24 *
25 * The license and distribution terms for this file may in
26 * the file LICENSE in this distribution or at
27 * http://www.rtems.org/license/LICENSE.
28 */
29
30#ifndef __Z85C30_H
31#define __Z85C30_H
32
33#include <stdint.h>
34
35#include <libchip/serial.h>
36
37#ifdef __cplusplus
38extern "C" {
39#endif
40
41/*
42 * Driver function table
43 */
44
45extern const console_fns z85c30_fns;
46extern const console_fns z85c30_fns_polled;
47
48/*
49 * Flow control function tables
50 */
51
52extern const console_flow z85c30_flow_RTSCTS;
53extern const console_flow z85c30_flow_DTRCTS;
54
55/*
56 * Default register access routines
57 */
58
59uint8_t z85c30_get_register( /* registers are byte-wide */
60 uintptr_t ulCtrlPort,
61 uint8_t ucRegNum
62);
63
64void z85c30_set_register(
65 uintptr_t ulCtrlPort,
66 uint8_t ucRegNum,
67 uint8_t ucData
68);
69
70uint8_t z85c30_get_data(
71 uint32_t ulDataPort
72);
73
74void z85c30_set_data(
75 uint32_t ulDataPort,
76 uint8_t ucData
77);
78
79#ifdef __cplusplus
80}
81#endif
82
83#endif
The generic libchip serial driver interface.
Definition: serial.h:113
Definition: serial.h:95
