RTEMS 6.1-rc4
video.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _VIDEO_H
31#define _VIDEO_H
32
33/*----------------------------------------------------------------------------
34 * Definitions
35 *----------------------------------------------------------------------------*/
37#define YUV 0
39#define RGB 1
40
41/*----------------------------------------------------------------------------
42 * Type
43 *----------------------------------------------------------------------------*/
44typedef struct _isi_Video {
46 uint32_t lcd_vsize;
48 uint32_t lcd_hsize;
50 uint32_t lcd_nbpp;
52 uint32_t lcd_fb_addr;
54 uint32_t Isi_fbd_base;
56 uint32_t Hblank;
58 uint32_t Vblank;
60 uint32_t codec_vsize;
62 uint32_t codec_hsize;
64 uint32_t codec_fb_addr;
70 uint8_t rgb_or_yuv;
72
73/*----------------------------------------------------------------------------
74 * Exported functions
75 *----------------------------------------------------------------------------*/
76extern void VIDEO_Ycc2Rgb(uint8_t *ycc, uint16_t *rgb, uint32_t len);
77
78#endif
79
Definition: video.h:44
uint32_t lcd_hsize
Definition: video.h:48
Definition: video.h:64
Definition: video.h:52
uint32_t codec_fbd_base
Definition: video.h:66
uint32_t IsiPrevBuffIndex
Definition: video.h:68
Definition: video.h:60
uint32_t Vblank
Definition: video.h:58
uint32_t Hblank
Definition: video.h:56
Definition: video.h:62
uint32_t lcd_vsize
Definition: video.h:46
uint32_t lcd_nbpp
Definition: video.h:50
uint8_t rgb_or_yuv
Definition: video.h:70
Definition: video.h:54
