RTEMS
6.1-rc4
bsps
microblaze
include
dev
serial
uartlite.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
37
#define LIBBSP_MICROBLAZE_SHARED_UARTLITE_H
38
39
#include <bspopts.h>
40
rtems/termiostypes.h
41
42
#include <dev/serial/uartlite_l.h>
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
48
typedef
struct
49
rtems_termios_device_context
base;
50
uintptr_t address;
51
uint32_t initial_baud;
52
uint32_t enabled;
53
#ifdef BSP_MICROBLAZE_FPGA_CONSOLE_INTERRUPTS
54
struct
rtems_termios_tty
*tty;
55
bool
transmitting;
56
size_t
tx_queued;
57
uint32_t irq;
58
#endif
59
uart_lite_context
60
61
extern
const
rtems_termios_device_handler
microblaze_uart_fns;
62
63
#ifdef __cplusplus
64
65
#endif
/* __cplusplus */
66
67
#endif
/* LIBBSP_MICROBLAZE_SHARED_UARTLITE_H */
Termios device context.
Definition:
termiosdevice.h:68
Termios device handler.
Definition:
termiosdevice.h:100
rtems_termios_tty
Definition:
termiostypes.h:94
uart_lite_context
Definition:
uartlite.h:48
termiostypes.h
